Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
SRE AgentSRE Agent
SRE Agent
SRE Agent
Analyze and triage incidents.
Technology
Free trialDocumentation
A problem fires, the agent investigates on its own.
  • Product information
Overview
Operations are moving from reactive to autonomous. The SRE Agent investigates end to end, and you approve.
The agent investigates and takes action on its own, with human oversight. Work that used to reach a person arrives already handled. A problem fires and the agent investigates on its own, and writes the root cause back onto the problem you already triage. You run the SRE Agent as a step in an agentic workflow with the Run agent action, and the workflow adds the trigger, the approval and the routing.
RESOLVE: the incident at 2 AM. Root cause is already computed. The agent prepares the fix; you approve from your phone.
  • Triage. Route. Remediate or Optimize. The whole response, from investigation to fix, end to end.
  • Assigns automatically. Reaches the responsible team or component owner, no manual dispatch.
  • Self-healing, with oversight. A human stays in the loop where it matters.
  • Root cause, not symptoms. Acts on the cause, not each alert, ending the storm.
  • Backed by deep analytics. Reasons across every signal and follows Smartscape as far as the evidence leads.
  • Autonomous when you want it. Human-approved when it matters.
Use cases
  • Autonomous investigation: get a root cause analysis built from the error and warning logs of the affected entities, returned in a fixed template: root cause, key findings, conclusion, recommendations.
  • Available within a minute, with the agent choosing its own queries.
  • Annotated on the Problem, so the next responder starts from the analysis instead of a blank tab.
  • Route it to the service desk: the incident arrives in ServiceNow, Jira or Jira Service Management with the cause already named.
  • Collaborate, the fix in your own cloud: Dynatrace triages and hands grounded context to your cloud SRE agent to act.
Get started
  1. Enable generative AI and agentic AI for your environment and assign the permissions through a policy. See the getting started documentation.
  2. In Dynatrace Intelligence for Workflows, start from the SRE Agent template or add the Run agent action to an agentic workflow triggered on a Dynatrace problem. The agent investigates and annotates the result onto the problem.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to SRE Agent
Agentic Incident Analysis logo
Root cause, blast radius, and the fix, in one pass.
Cloud SRE Agents logo
Cloud SRE Agents
Orchestrate cloud-native AI agents for autonomous incident resolution.
Dynatrace Intelligence logo
Action based on answers with deterministic insights and agentic operations.
Dynatrace Intelligence for Workflows logo
Add agentic AI, prompts and built-in analysis to your workflows.
Troubleshoot Kubernetes Agentic Workflow logo
Automated troubleshooting and root cause analysis of Kubernetes resources.
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
