Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Arize AXArize AX
Arize AX
Arize AX
Technology by Arize
Documentation
Observe: Trace LLM and agent calls end to end to spot slow or failing steps.Evaluate: Score LLM outputs with evals to track quality over time.Learn: Use eval results and feedback to improve prompts and agent behavior.Alyx: Ask Alyx, the Arize AI assistant, to help debug traces and set up evals.
  • Product information
Overview
Arize AX, from Arize, a Dynatrace company, is the AI engineering platform for improving AI agents and applications. It gives AI engineers one workflow to capture what their agents actually do, find where they fail, measure quality, and prove every change before it ships.
Arize AX captures traces of real agent behavior, including inputs, outputs, tool calls, and costs. Signal automatically groups recurring failures into ranked issues with trace evidence and a proposed fix. Evaluators score quality continuously against criteria you define, and experiments turn every prompt, model, or retrieval change into a controlled comparison.
Alyx, the AI engineering agent built into Arize AX, works across every step. Ask it in plain language which tool calls are failing, which requests your agent can't handle, or how to build an evaluator.
This is intended for teams who:
  • Build AI agents or LLM applications and need to understand why they fail in production.
  • Want to move from ad hoc prompt tweaks to measurable, repeatable improvement.
Use cases
Find where your agents fail
  • Capture every agent run as a trace, including inputs, outputs, tool calls, and costs.
  • Enable Signal to group recurring failures into ranked issues, each with trace evidence and a proposed fix.
  • Ask Alyx in plain language to find failing runs, and add dashboards and alerts for ongoing visibility.
Score quality against your own criteria
  • Evaluate agent performance with LLM-as-a-judge, agent-as-a-judge, or code evaluators.
  • Turn a Signal issue into an evaluator that continuously scores new traces for that failure.
  • Annotate outputs and calibrate automated scores against human judgment.
Prove every change before you ship
  • Curate datasets of test cases that capture how your agent should behave.
  • Run prompt, model, or retrieval changes as experiments and compare versions side by side.
  • Run datasets against your deployed agent with remote agent experiments to measure real impact.
Use AI across the workflow
  • Work with Alyx in the product to build evaluators and investigate traces.
  • Instrument and operate Arize AX from Bluebox,Claude, Cursor, or Codex with the Arize AX CLI, skills, and MCP servers.
Get started
Instrument with OpenInference. Arize AX tracing is built on OpenInference, the open, OpenTelemetry-based standard for AI tracing created by Arize, with pre-built auto-instrumentation for 30+ providers and frameworks.
Get started for free in one command
Run npx evals from your terminal. It launches your coding agent, signs you up for a free Arize AX account, and instruments your app. Python users can run uvx arize-ax-cli instrument instead.
Or set up step by step
  1. Sign up for a free Arize AX account.
  2. Instrument your agent with auto-instrumentation to capture your first trace.
  3. Enable Signal on your project and review your first issue.
  4. Create evaluators and run experiments to prove a fix.
Using Claude, Cursor, or Codex? See coding agent setup.
Arize
DocumentationMore Information
By the partner
Contact ArizeRequest support
Copy to clipboard
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
