Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Jira Service Management ConnectorJira Service Management Connector
Send Dynatrace problems to JSM and keep responders informed via alert lifecycle.
App
Free trialDocumentation
Set up your JSM connection once, use it in any workflow.Get started fast with a ready-made workflow template.The complete workflow, from problem trigger to a fully configured JSM alert.No detail left behind, forward everything to JSM.The alert lands in JSM, ready for your on-call team.Automate the full JSM alert lifecycle, from problem detection to resolution.
  • Product information
  • Release notes
Overview
Connect Dynatrace to your Atlassian Jira Service Management (JSM) for workflows. Whenever a problem, security vulnerability, or attack is detected by Dynatrace, a workflow using this app automatically creates, updates, or closes a JSM alert. No manual handoff is required.
This app tracks the Dynatrace problem through its entire lifecycle: react to a JSM alert when a problem opens, update it as conditions change, and acknowledge and close it automatically when Dynatrace resolves the problem. A stable alias ties all three actions to the same JSM alert, keeping your on-call view clean and free from duplicate notifications.
By using the JSM app you get to:
  • Keep the JSM alert lifecycle aligned with the Dynatrace Problem lifecycle
  • Reduce duplicate alerts and manual coordination for on-call teams
  • Give responders root-cause and impact context in every alert
  • Configure alert mapping and routing directly in Dynatrace Workflows
Use cases
  1. Automate the full alert lifecycle: Respond to Dynatrace problems without manual intervention, from detection to resolution.
  2. Route alerts to the right team: Make sure the right responders are notified the moment a problem occurs.
  3. Give your on-call team the full picture: Forward rich Dynatrace context directly into JSM so responders have everything they need without switching tools.
Get started
Install Jira Service Management. Then follow the instructions detailed in Dynatrace Documentation.
Before you start, make sure that Jira Service Management is installed, outbound connections are configured, and the connection to Jira Service Management is authorized.
Details
Full alert lifecycle automation:
  • Automatically create a JSM alert when Dynatrace detects a problem, with priority mapped from Dynatrace severity (P1–P5).
  • Close the JSM alert automatically when Dynatrace resolves the problem. No manual follow-up needed.
  • Use a stable alias across create, update, and close actions to prevent duplicate alerts and keep your on-call view clean.
Ensuring that the right responders are notified:
  • Specify JSM responders (users, teams, escalation policies, or schedules) directly in the workflow step.
  • Store credentials once as a managed connection, so API tokens never appear in workflow definitions.
Dynatrace rich context directly into JSM:
  • Forward affected entity names, tags, impact level, root cause, and problem links as structured properties on the JSM alert.
  • Include dynamic notes with direct links to the Dynatrace problem and workflow execution for fast triage.
  • Use Jinja expressions to map any Dynatrace event data into JSM alert fields without writing custom scripts.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Jira Service Management Connector
Jira logo
Jira
Workflows logo
Workflows
Full version history
ReleaseDate
  • Fixed the workflow template to handle problems without a severity
  • Released Jira Service Management Connector 1.0
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
