Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Generic network deviceGeneric network device
Gain insights into the performance of your network devices.
Extension
Free trialDocumentation
Get a high level overview of your monitored Network Infrastructure with the included dashboard.Monitor network device traffic with pre-built charts for all of your relevant metrics.
  • Product information
  • Release notes
Overview
This extension leverages the SNMP protocol to provide a complete solution to monitor network infrastructure. The complete configuration is provided out-of-the-box.
This is intended for users, who:
  • Would like to monitor health state and performance of their core network infrastructure and provide unified analysis for Ops, DevOps and IT Admins.
This enables you to:
  • Monitor health and performance of your network devices
  • Set up alerts to be notified by traffic anomalies
Use cases
  • Monitor core network infrastructure by polling data for Network Devices and Interfaces.
  • Enable alerting on detected anomalies
  • Capture traps by integrating with the SNMP Traps extension.
Get started
For more information on the installation and configuration, please see Generic network device extension in the Dynatrace Documentation.
Details
Compatibility information
  • Standard network devices supporting common MIB files
  • SNMPv2c and SNMPv3 supported only
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.if.status--
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.in.errors.count--
-com.dynatrace.extension.network_device.if.in.discards.count--
-com.dynatrace.extension.network_device.if.out.errors.count--
-com.dynatrace.extension.network_device.if.out.discards.count--
-com.dynatrace.extension.network_device.if.lastchange--
Time since the last re-startcom.dynatrace.extension.snmp-generic-device.sys.uptimeThe time (in hundredths of a second) since the network management portion of the system was last re-initializedUnspecified
-com.dynatrace.extension.network_device.if.in.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.out.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.in.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.out.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.in.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.out.ucast_pkts.count--
Interface speedcom.dynatrace.extension.snmp-generic-device.if.highspeedSpeed of the network interface in MegaBits per second.MegaBitPerSecond
Octets received (high capacity)com.dynatrace.extension.snmp-generic-device.if.hc.in.octets.countThe total number of octets received on the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices.Count
Octets transmitted (high capacity)com.dynatrace.extension.snmp-generic-device.if.hc.out.octets.countThe total number of octets transmitted out of the interface including framing characters. This metric uses 64 bit counter and should be used for highspeed devices.Count
Last interface status changecom.dynatrace.extension.snmp-generic-device.if.lastchangeValue of 'sysUpTime' when the interface entered its current stateCount
Octets receivedcom.dynatrace.extension.snmp-generic-device.if.in.octets.countThe total number of octets received on the interface including framing charactersCount
Octets transmittedcom.dynatrace.extension.snmp-generic-device.if.out.octets.countThe total number of octets transmitted out of the interface including framing charactersCount
Inbound errorscom.dynatrace.extension.snmp-generic-device.if.in.errors.countNumber of inbound packets/transmission units with errorsCount
Inbound discardscom.dynatrace.extension.snmp-generic-device.if.in.discards.countNumber of inbound packets discardedCount
Outbound errorscom.dynatrace.extension.snmp-generic-device.if.out.errors.countNumber of outbound packets/transmission units with errorsCount
Outbound discardscom.dynatrace.extension.snmp-generic-device.if.out.discards.countNumber of outbound packets discardedCount
Messages deliveredcom.dynatrace.extension.snmp-generic-device.snmp.in.pkts.countTotal number of messages delivered from the transport serviceCount
Messages passedcom.dynatrace.extension.snmp-generic-device.snmp.out.pkts.countTotal number of messages passed to the transport serviceCount
Silently dropped PDUscom.dynatrace.extension.snmp-generic-device.snmp.silentdrops.countNumber of silently dropped PDUs due to the large reply sizeCount
Proxy dropped PDUscom.dynatrace.extension.snmp-generic-device.drops.proxy.countNumber of silently dropped PDUs due to the other than a time-outCount
Unsupported SNMP version messagescom.dynatrace.extension.snmp-generic-device.in.bad.versions.countTotal number of messages delivered with an unsupported SNMP versionCount
Messages with bad community namescom.dynatrace.extension.snmp-generic-device.in.bad.community.names.countNumber of messages with an unknown SNMP communityCount
Messages not allowed in communitycom.dynatrace.extension.snmp-generic-device.in.bad.community.uses.countNumber of messages not allowed for the used SNMP communityCount
'noSuchName' errorscom.dynatrace.extension.snmp-generic-device.in.nosuchnames.countNumber of PDUs delivered PDUs with 'noSuchName' errorCount
'badValue' errorscom.dynatrace.extension.snmp-generic-device.in.bad.values.countNumber of PDUs delivered with 'badValue' errorCount
Traps processedcom.dynatrace.extension.snmp-generic-device.snmp.in.traps.countTotal number of SNMP Trap PDUs accepted and processedCount
Traps generatedcom.dynatrace.extension.snmp-generic-device.snmp.out.traps.countTotal number of SNMP Trap PDUs generatedCount
TCP active openscom.dynatrace.extension.snmp-generic-device.tcp.activeopens.countNumber of transitions of TCP connections from CLOSED to SYN-SENTCount
TCP passive openscom.dynatrace.extension.snmp-generic-device.tcp.passiveopens.countNumber of transitions of TCP connections from CLOSED to SYN-RCVDCount
TCP failed attemptscom.dynatrace.extension.snmp-generic-device.tcp.attemptfails.countNumber of transitions of TCP connections from SYN-SENT/SYN-RCVD to CLOSED and from SYN-RCVD to LISTENCount
TCP resetscom.dynatrace.extension.snmp-generic-device.tcp.estab.resets.countNumber of transitions of TCP connections from ESTABLISHED/CLOSE-WAIT to CLOSEDCount
TCP connectionscom.dynatrace.extension.snmp-generic-device.tcp.curr.estabNumber of TCP connections in the ESTABLISHED/CLOSE-WAIT stateCount
TCP segments receivedcom.dynatrace.extension.snmp-generic-device.tcp.hc.in.segs.countTotal number of segments received (including errors)Count
TCP segments sentcom.dynatrace.extension.snmp-generic-device.tcp.hc.out.segs.countTotal number of segments sent (excluding retransmissions)Count
TCP segments retransmittedcom.dynatrace.extension.snmp-generic-device.tcp.retrans.segs.countTotal number of segments retransmittedCount
TCP segment errorscom.dynatrace.extension.snmp-generic-device.tcp.in.errs.countTotal number of segments received in errorCount
TCP segment resetscom.dynatrace.extension.snmp-generic-device.tcp.out.rsts.countNumber of TCP segments sent containing the RST flagCount
UDP datagrams receivedcom.dynatrace.extension.snmp-generic-device.udp.hc.in.datagrams.countTotal number of UDP datagrams receivedCount
UDP datagrams received without portcom.dynatrace.extension.snmp-generic-device.udp.noports.countNumber of received UDP datagrams (no application at the destination port)Count
UDP datagram errorscom.dynatrace.extension.snmp-generic-device.udp.in.errors.countNumber of received and not delivered UDP datagrams (other than no application at the destination port)Count
UDP datagrams sentcom.dynatrace.extension.snmp-generic-device.udp.hc.out.datagrams.countTotal number of UDP datagrams sentCount
Full version history
ReleaseDate
🚀 Improved in this version (3.1.5):
  • Removed legacy interface metrics from Interfaces feature set:
    • com.dynatrace.extension.snmp-generic-device.if.lastchange, com.dynatrace.extension.snmp-generic-device.if.in.errors.count, com.dynatrace.extension.snmp-generic-device.if.in.discards.count, com.dynatrace.extension.snmp-generic-device.if.out.errors.count, com.dynatrace.extension.snmp-generic-device.if.out.discards.count are now in the Interfaces (32-bit) feature set.
    • com.dynatrace.extension.snmp-generic-device.if.highspeed is now in the Interfaces (64-bit) feature set.
  • Adjusted alert templates to support both gen 2 entities and Smartscape nodes.
✨ New in this version (3.1.3):
  • Added 1 new Smartscape-based screens to Generic EXT_NETWORK_DEVICE nodes in the Infrastructure & Operations app:
    • Traffic: displaying TCP/UDP metrics and SNMP-related information.
  • Adapted gen 3 dashboard to incorporate new Smartscape nodes.
🪲 Fixed in this version:
  • Corrected wrong assignment of in/out traffic metrics in gen 3 dashboard.
  • Enriched network device nodes with snmp.ip field.
⚠️WARNING⚠️: Possible breaking changes and warnings - PLEASE READ before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC version of 1.333.0.
  • This version includes a potentially breaking change for Dynatrace on Grail.
    • With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline instead of the default pipeline.
    • This means that any created custom dynamic rules will no longer be used on metrics ingested from the extension. If you want to keep enforcing them, please create pipeline groups.
New in this version:
  • Smartscape on Grail. This extension will populate new Smartscape nodes and edges via OpenPipeline extraction.
  • Refactored feature sets according to the best practices established here.
⚠️ IMPORTANT: This version contains a change to feature sets that may require enabling a new feature set to continue collecting existing data
⚠️ Changes in this version:
  • Metric com.dynatrace.extension.snmp-generic-device.sys.uptime moved from default feature set to Control Plane feature set
✨ New in this version:
  • Update entity links on platform dashboard to link to I&O app
  • Add below dimensions to metric data for network:interface entity type:
    • if.type
    • if.alias
    • if.highspeed
    • if.promiscuousmode
    • if.mtu
🪲 Fixed in this version (2.5.4):
  • Setting identifying dimensions as required for generic devices and interfaces.
  • sys.name and mac.address dimensions are required on all network metrics and filtered for empty values. This caused unnecessary stress on topology engine
  • Added Davis anomaly detector templates to extension package
✨ New in this version (2.5.0):
  • Added the following new metrics to the Advanced interfaces feature set:
    • com.dynatrace.extension.network_device.if.in.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.out.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.in.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.out.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.in.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.out.ucast_pkts.count
🐛 Bug fixes:
  • Fixed DQL for Traffic chart in I&O app
✨ New in this version (2.4.3):
  • Added the following metric to the new Advanced interfaces feature set:
    • com.dynatrace.extension.network_device.if.lastchange
  • In some cases, the topology rules would end up creating extra network:interface entities which would be disconnected from the rest of the topology
⚠️ IMPORTANT CHANGE:
Metrics in "default" feature set will always be enabled and cannot be disabled. These metrics are mandatory. Take extra caution configuring devices and interfaces for which you are collecting data. Make use of Interface filters to limit the number of interfaces, otherwise, all interfaces on the device will be collected by default. In case you do not wish to collect interfaces on your device, enter $eq(!) in the "Interface Name" filter field on the Feature Sets screen during configuration.
  • Default network metrics moved into the "default" feature set, specifically Interface metrics.
⚠️ Additional notes:
  • You must disable the old "neighbor-discovery" feature set in order to update
  • SNMP Health metrics will be disabled by default when first updating (due to the feature set change)
  • Network charts for these devices in the Infrastructure Operations app would have DQL execution errors
Improved in this version:
  • SNMP Health metrics moved into a separate feature set for SNMP
  • Neighbour Discovery (LLDP) feature set was removed. This is now handled by the SNMP Autodiscovery extension for any kind of device
  • Security Context is applied to entities
  • Adds a platform dashboard
  • DQL fix for SaaS charts for interface high capacity charts
  • DQL fix on Network Interface Traffic chart
  • Corrected some of the DQL queries for AppEngine UI
  • Removed the filter to allow monitoring of network interfaces with missing MAC addresses
  • Invalid DQL in network statistics card, in AppEngine screens
  • Minimum schema is correctly enforced
  • Filtering fields limit increased to 50,000 characters
  • Recently introduced metrics for device and interface now apply the existing feature sets and filters to reduce license consumption.
  • New entities & metrics were added for representing network devices
  • Fixed: Network Interface metrics not visible in a Management Zone.
  • High capacity interface traffic metrics extracted to "Interfaces 64-bit" feature set.
  • Default interface traffic metrics extracted to "Interfaces 32-bit" feature set.
Check distribution of metrics in the new feature sets to avoid gaps in the data
v1.8.0
  • Removed a rule for creating an entity from SNMP traps. Now traps source entity is connected to the device entity only with SAME_AS relation.
v1.7.0
  • Added 4 new metrics:
    • Octets received (high capacity)
    • Octets transmitted (high capacity)
    • Interface outgoing traffic (high capacity)
    • Interface incoming traffic (high capacity)
  • Bandwidth utilization is now calculated with above metrics
v1.6.0
  • Ability to display traps send from the device and captured using SNMP Traps extension
  • Added traps statistics on the entity screen
  • Added relationships to SNMP Traps Extension & Trap Visualizations on Device Screen
  • Added inject message with back-link to the device on corresponding SNMP traps source
v1.5.0
  • Added ability to use filters for Interface Name, Admin and Operational Status
Device screen - added filtering for list of network interfaces.
  • added traffic metrics that shows traffic in bitsperseconds
  • added a metric with interface speed
  • added a metrics that calculate bandwidth utilization
  • added definition of UA screen for network interface
  • added alert definition for bandwidth utilization.
  • new metrics has been used on both screens
  • dashboard has been improved
Interval for sending the data is changed from 5 minutes to 1 minute.
Dashboard improvements - tile with errors contains a links to device screens.
No release notes
Dynatrace Hub
All (948)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
