Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Palo Alto Cortex XDRPalo Alto Cortex XDR
Ingest Palo Alto Cortex XDR detection findings and audit logs.
Extension
Free trialDocumentation
Architecture diagram.Findings dashboard.Coverage dashboard.
  • Product information
  • Release notes
Overview
Dynatrace integrates with the Palo Alto Cortex XDR to enable visibility, unified analysis, and operationalization of security findings across your monitored environments.
The integration ingests detection findings, and maps them to the Dynatrace Semantic Dictionary as security finding events. This helps SRE teams to get security insights and additional context; and security teams to enrich security findings with runtime context to drive a more efficient remediation.
Capabilities:
  • Single pane of glass: Ingest security findings into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps both detection findings to a unified format, so you can analyze and process security data consistently across multiple sources (powered by Dynatrace Semantic Dictionary)
  • Runtime exposure analysis: Search and correlate detection findings across various data sources in Dynatrace — natively captured and third-party ingested — including logs, traces, and events, to reveal where threats surface in your environment
  • Findings operationalization: Prioritize, visualize, and automate security response with runtime context.
  • Unveil blind spots: Discover and eliminate coverage gaps in your security product deployment and assessments
Use cases
  • Overview: Visualize and report your current security posture and trends around security findings across environments with Dashboards.
  • Prioritization: Analyze and prioritize security findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical security findings with Workflows.
  • Investigation: Use security findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
For instructions, go to Ingest Palo Alto Cortex XDR detection findings and audit logs.
Details
This integration comes with several sample dashboards and workflows to help you, for example:
  • Visualize security findings
  • Summarize product security coverage
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Palo Alto Cortex XDR
Dashboards logo
Dashboards
Extensions logo
Extensions
Manage Dynatrace extensions for hundreds of technologies.
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Security Operations logo
Security Operations
Ingest and operationalize security data.
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
What's new: - Initial release.
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
