Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Security OperationsSecurity Operations
Security Operations
Security Operations
Ingest and operationalize security data.
App
Free trialDocumentation
Sample security findings dashboard.Sample threat intelligence dashboard.Sample threat intelligence dashboard.
  • Product information
  • Release notes
Overview
Security Operations connects your existing security toolchain to Dynatrace, breaking the silos between security teams and operations teams by bringing all third-party security findings into a single, shared view — providing the context where it is needed.
  • Single pane of glass: Ingest findings from cloud-native security products, threat intelligence platforms, and vulnerability scanners into Dynatrace. See all security signals alongside service health, infrastructure, and application data in one platform.
  • Unified analysis and noise reduction: Contextualize findings with full-stack observability data using the Dynatrace Semantic Dictionary. Understand what is real, what is noise, and what requires immediate action.
  • Findings operationalization: Go beyond ingestion. Turn incoming findings into automated actions — notifications, remediation workflows, ticketing — without switching tools.
Ready-made dashboards and workflows are available in Dynatrace immediately after setup, giving security and operations teams shared, actionable visibility with no additional configuration.
Use cases
  • Visualize and report on security findings: Use ready-made dashboards in the Dashboards app to give security and operations teams a shared view of incoming findings, coverage posture, and vulnerability trends — surfaced in the same platform already used for service health and infrastructure monitoring.
  • Prioritize with runtime context: Use Notebooks and DQL to contextualize incoming security events with real-time runtime data — deployed versions, exposed services, network reachability — to focus remediation where it matters most and cut through alert noise.
  • Automate response and notifications: Connect findings to Dynatrace Workflows to automate common responses: send Slack or email alerts on critical findings, create Jira tickets, or trigger custom remediation steps.
  • Investigate threats across your stack: Use Dynatrace Investigations to trace findings across your full observability stack — from a detected threat event to the affected service, host, or Kubernetes workload.
  • Discover coverage gaps: Use the Security product coverage dashboard to identify which hosts, workloads, and container images are not yet monitored by any connected security product, and address blind spots proactively.
Get started
Open Settings → Collect & Capture → Security events, or find the integration you want in the Dynatrace Hub.
Add a connection
  1. Select Add connection and choose the security product to connect.
  2. Follow the step-by-step onboarding wizard. Depending on the integration, this involves configuring cloud-side infrastructure using the provided templates and a Dynatrace API token.
  3. Run the built-in validation to confirm findings are arriving in security.events.
For a full list of supported integrations and per-integration setup instructions, see the Security events documentation.
Ready-made documents
After setup, relevant dashboards and workflows are immediately available in the Dashboards and Workflows apps, attributed to Security Operations — no extra configuration required.
Details
All findings are stored in the security.events Grail table, where they can be queried with DQL alongside logs, metrics, and traces from the rest of your environment.
Sample dashboards
  • Security findings — findings overview across all connected products
  • Security product coverage — entity and workload coverage map
  • Vulnerability findings — vulnerability-specific findings view
  • Container vulnerability findings — container image CVE tracking
  • Container image alert reduction — runtime-contextualized alert reduction
  • Container scan events coverage — scan coverage report
Sample workflows
  • Email on new critical security findings — email alert triggered on critical-severity events
Dashboards and workflows are attributed to the Security Operations app and accessible from the Dashboards and Workflows apps in Dynatrace.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Security Operations
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Workflows logo
Workflows
Full version history
ReleaseDate
Patch Changes
  • Fixed an issue where findings from third-party scanners that report only a host name (no IP address) were not matched to your monitored hosts. Findings are now matched by IP address and by host name, so they appear in the Security Findings and Vulnerability Findings dashboards and in the third-party detection workflow's affected-hosts results.
  • Fixed the Security Product Coverage dashboard counting hosts with multiple IP addresses as both covered and not covered, so host totals now match your actual host count.
  • Fixed host counts and repeated scan results in the Vulnerability Findings Reduction dashboard being inflated or collapsed when a finding resolved to several IP addresses.
1.3.0
Minor Changes
  • You can now see a record trend sparkline for each integration and each connection, so you can tell at a glance whether data is still flowing; the related columns are now labelled "Records" and "Last record".
  • The integrations table now shows a "Data type" column indicating whether each integration ingests events or logs.
  • The timeframe selector and the add buttons now sit in the table toolbar next to the search box on both the integrations and connections tables, and the timeframe selector stays available even before any integrations are set up.
  • Users without write permission now see the add-integration and add-connection buttons disabled, with a tooltip explaining which permission is missing.
Patch Changes
  • Fixed an issue where the integrations table jumped back to the first page while you were paging through it.
  • Fixed misaligned page title spacing when opening the connections page directly from a link.
  • Fixed an issue where the ready-made security dashboards could fail to open in some environments.
1.2.1
New Features
  • New workflow template: Added "[Sample] Email on host detections with runtime impact", a third-party detection affected-hosts workflow
Fixes and maintenance
  • Ingest endpoint: The production ingest endpoint now uses the .live host
  • Security Hub CSPM template: Fixed an incorrect startswith call in the template's lambda function
Patch changes
  • Fixed issue in migration process
What's new:
  • Fix small bugs in the shipped dashboards and workflows.
  • Added separate sections for ready-made dashboards and workflows.
First app release.
Dynatrace Hub
All (957)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
