Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
OCSFOCSF
OCSF
OCSF
Ingest security findings in Open Cybersecurity Schema Framework (OCSF) format.
Technology
Free trialDocumentation
Security findings dashboard.Sample workflow.
  • Product information
Overview
Dynatrace integrates with third-party tools by supporting the Open Cybersecurity Schema Framework (OCSF) for security findings. This provides users with:
  • Single pane of glass: Ingest security findings in OCSF into Dynatrace (powered by OpenPipeline™).
  • Unified analysis: Dynatrace transforms and maps the OCSF security findings to a unified format (powered by Semantic Dictionary).
  • Findings operationalization: Prioritize, visualize, and automate security findings with runtime context.
Use cases
  • Overview: Visualize and report your current security posture and trends around vulnerability findings across container registries with Dashboards.
  • Prioritization: Analyze and prioritize vulnerability findings across multiple tools and products uniformly with Notebooks.
  • Automation: Automate the orchestration of the critical vulnerability findings by creating notifications and tickets using Workflows.
  • Investigation: Use vulnerability findings as an additional dimension for the threat hunting and incident forensics using Security Investigator.
Get started
You can ingest OCSF security findings from any third-party tool by forwarding the individual findings to our built-in security events endpoint. For instructions, go to OCSF security findings.
Details
This integration delivers several sample dashboards and workflows to help you
  • Visualize security findings (dashboard)
  • Summarize product security coverage (dashboard)
  • Send email notification for critical security findings (workflow)
Compatibility information
  • OCSF version 1.1.0
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to OCSF
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Security Operations logo
Security Operations
Ingest and operationalize security data.
Workflows logo
Workflows
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
