Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
AWS Security HubAWS Security Hub
AWS Security Hub
AWS Security Hub
Ingest AWS Security Hub vulnerabilities, detections, and compliance findings.
Technology
Free trialDocumentation
Sample generic security findings dashboard.Sample security products coverage dashboard.Sample workflow.
  • Product information
Overview
Dynatrace integrates with AWS Security Hub to enable visibility, orchestration, and prioritization of security findings over cross-tools and environments.
Capabilities:
  • Single pane of glass: Ingest security findings from AWS Security Hub into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps the security findings to a unified format (powered by Dynatrace Semantic Dictionary)
  • Findings operationalization: Prioritize, visualize, and automate security findings with runtime context
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC)
Use cases
  • Overview: Visualize and report your current security posture and trends around security findings across environments with Dashboards.
  • Prioritization: Analyze and prioritize security findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical security findings with Workflows.
  • Investigation: Use security findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
To ingest AWS Security Hub security findings into Dynatrace, you need to set up a forwarding rule in Amazon EventBridge.
For instructions, go to Ingest AWS Security Hub security findings.
Details
This integration delivers several sample dashboards and workflows to help you
  • Visualize security findings (dashboard)
  • Summarize product security coverage (dashboard)
  • Send email notification for critical security findings (workflow)
Compatibility information
AWS Security Finding Format.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to AWS Security Hub
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Security Operations logo
Security Operations
Ingest and operationalize security data.
Workflows logo
Workflows
Dynatrace Hub
All (950)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
