Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Amazon ECRAmazon ECR
Amazon ECR
Amazon ECR
Ingest Amazon Elastic Container Registry vulnerability findings and scan events.
Technology
Free trialDocumentation
Sample dashboard with a summary of vulnerability findings.Sample dashboard for the security coverage.Sample workflow.
  • Product information
Overview
Dynatrace integrates with Amazon ECR to enable visibility, orchestration, and prioritization of cross-container registry vulnerability findings.
  • Single pane of glass: Ingest vulnerability findings from Amazon ECR into Dynatrace (powered by OpenPipeline™).
  • Unified analysis: Dynatrace transforms and maps the findings to a unified format for vulnerability findings (powered by Dynatrace Semantic Dictionary).
  • Findings operationalization: Prioritize, visualize, and automate vulnerability findings with runtime context.
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC).
Use cases
  • Overview: Visualize and report your current security posture and trends around vulnerability findings across container registries with Dashboards.
  • Prioritization: Analyze and prioritize vulnerability findings across multiple tools and products uniformly with Notebooks.
  • Automation: Automate the orchestration of the critical vulnerability findings by creating notifications and tickets using Workflows.
  • Investigation: Use vulnerability findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
You can ingest Amazon ECR vulnerability findings and scan events (basic or enhanced scanning) into Dynatrace via AWS EventBridge using the CloudFormation template provided by Dynatrace. For instructions, go to Ingest Amazon ECR vulnerability findings and scan events.
Details
This integration delivers several sample dashboards and workflows to help you
  • Visualize container vulnerability findings (dashboard)
  • Discover container scanning gaps (dashboard)
  • Automatically create Slack notifications for critical findings (workflow)
  • Automatically create Jira tickets for critical findings (workflow)
Compatibility information
  • Amazon ECR (basic scanning) EventBridge events format - completed image scan events and the corresponding security findings.
  • Amazon ECR (enhanced scanning) EventBridge events format - individual findings and scan events reported by AWS Inspector.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Amazon ECR
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Security Operations logo
Security Operations
Ingest and operationalize security data.
Workflows logo
Workflows
Dynatrace Hub
All (955)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
