Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Agentic Security AnalysisAgentic Security Analysis
Validate security findings, correlate vulnerabilities, and triage real threats.
Technology
Free trialDocumentation
Ask once and get the libraries ranked by how much risk they carry.Dependabot alerts matched to what is running, then verified and filed.
  • Product information
Overview
Act on exposure. Build resilience. Validate security findings, correlate vulnerabilities, and triage real threats.
Start from a conversation and the agent becomes your expert assistant, in Dynatrace Assist or through the Dynatrace MCP server, wherever you work. Or let it run autonomously when an event triggers it: detections, vulnerabilities, compliance findings, logs and spans are joined to live topology, real exposure is scored against your runtime, and the agent proposes a fix a human approves.
Improve resilience with autonomous triage and correlation across detections, vulnerabilities, and topology, with a governed, human-approved fix.
  • Inventory what you have. Count and rank vulnerabilities.
  • Check a specific exposure. Does this CVE touch production?
  • Prioritize and remediate. The active set with a fix direction.
  • Prove compliance. Top gaps for a scope.
  • Understand context. Exposure, confidence, entities named, the reasoning shown, and a YAML diff, a Jira ticket or a GitHub issue, created for review rather than applied.
Use cases
  • CVE exposure check: get a runtime-grounded yes or no, with the exact services and hosts that run the vulnerable library.
  • Vulnerability inventory: ask once and get the count and the libraries carrying the most risk.
  • Runtime-proven GitHub vulnerabilities: get the critical GitHub findings that are proven to run in production.
  • Hunt an indicator across your environment: get everywhere an indicator showed up, every entity, log, and event tied to that address.
  • Misconfigurations on related entities: check whether the related entities of a CVE have known misconfigurations that could enable its exploitation.
  • SDLC scan coverage: check whether a service was scanned for security vulnerabilities as part of the SDLC.
  • Threat alert triage: it breaks a threat alert into indicators of compromise and matches them across your own data in Grail.
  • Code-time vulnerability verification: it maps GitHub Dependabot alerts to what is actually running and confirms or dismisses each one.
  • Prioritize problems with security insights: it asks whether security findings caused the problem and scores its own confidence in the answer.
  • Weekly exposure change report: a weekly read on what actually changed in exposure, rather than another list of findings.
Get started
Ask interactively
  1. Enable generative AI and agentic AI for your environment and assign the permissions through a policy. See the getting started documentation.
  2. In Dynatrace Assist, ask whether you are exposed to a CVE you are tracking, then follow up on the related entities. To ask from your IDE or terminal, install the Dynatrace MCP server.
Run it autonomously
  1. In Dynatrace Intelligence for Workflows, add the ready-made security agents to a workflow triggered on security alerts.
  2. The agent triages, and the workflow adds the approval gate. Keep it in front of anything that changes a running configuration, and run the workflow as a reduced-scope service user.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Agentic Security Analysis
Dynatrace Assist logo
Dynatrace Assist
Dynatrace MCP Server logo
Threat Triage (Agentic Workflow) logo
Proactively reduce risk by automating threat detection and correlating findings.
Vulnerability Verification (Agentic Workflow) logo
Validate third-party findings that matter – focus smarter, remediate faster.
Dynatrace Hub
All (953)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
