Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Agentic Optimization and TuningAgentic Optimization and Tuning
Forecast-driven performance and cost tuning, based on live utilization.
Technology
Free trialDocumentation
Stop guessing. Start right-sizing.Ask which hosts are oversized and read the gap in gigabytes.Each finding carries a saving priced at list rates.Run the same analysis on a schedule and mail the report.
  • Product information
Overview
Stop guessing. Start right-sizing. Forecast-driven performance and cost tuning, based on live utilization.
Start from a conversation and the agent becomes your expert assistant, in Dynatrace Assist or through the Dynatrace MCP server, wherever you work. Or let it run autonomously on a schedule: utilization, query cost, ingest volume and token spend are gathered continuously, and the analysis is routed to the person who can optimize it, so savings can be realized fast.
Waste found and routed. Scheduled right-sizing and query-cost cleanup, delivered to the owner with real numbers and an estimated saving.
  • Forecast ahead. Dynatrace's predictive AI plans capacity before demand hits, not after.
  • Right-size compute. Hosts and clusters matched to real utilization and future demand.
  • Cut cloud waste. Idle and orphaned resources found across every account.
  • Tune data, query and AI cost. Log ingest, retention, and the queries actually driving spend, with token spend traced back to the workloads driving it.
  • Fully explained and actionable. Real numbers per resource, the reason it costs what it does, and an estimated saving, delivered to the owner of the resource or the query, so nothing waits on a central team.
Use cases
  • Right-size oversized hosts: compare allocation against actual usage and find every host that is oversized.
  • Capacity planning: model a traffic scenario against live usage and see exactly where headroom runs out.
  • Cloud cost waste report: sweep every cloud account in one ask and surface the idle and orphaned resources.
  • Explain a cost spike: ask about a cost increase and get the host group and change behind it.
  • Query cost attribution: ask what is driving your DPS consumption and get the exact queries responsible.
  • AI token spend, today and ahead: ask what is driving your spend today, and see it projected into next quarter.
  • Scheduled right-sizing report: a scheduled agent classifies every resource and emails a right-sizing report.
  • Slow database queries: a slowdown triggers the agent and it writes the slow query, its plan, and a fix onto the problem.
  • Chronic problem patterns: the agent ranks 30 days of problem signatures by accumulated downtime, and tells you which to fix and which to tune.
Get started
Ask interactively
  1. Enable generative AI and agentic AI for your environment and assign the permissions through a policy. See the getting started documentation.
  2. Open Dynatrace Assist and ask which hosts are oversized. To ask from your IDE or terminal, install the Dynatrace MCP server.
Run it on a schedule
  1. In Dynatrace Intelligence for Workflows, add the ready-made agents for optimization to a workflow, scoped to what you own.
  2. The agent does the analysis, and the workflow adds the schedule and the routing. Set the recipients, test with a manual run, then move the trigger to a schedule and pick email, Slack or a Git repository.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Agentic Optimization and Tuning
Cloud Cost Optimization (Agentic Workflow) logo
Customer-ready cloud cost savings report from Cloud Native Connection data.
Dynatrace Assist logo
Dynatrace Assist
Dynatrace MCP Server logo
Infrastructure Optimization (Agentic Workflow) logo
Gain insights and recommendations to drive cost and performance optimization.
Dynatrace Hub
All (953)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
