Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cloud Cost Optimization (Agentic Workflow)Cloud Cost Optimization (Agentic Workflow)
Customer-ready cloud cost savings report from Cloud Native Connection data.
Technology
Free trialDocumentation
A cloud cost report you can hand over.
  • Product information
Overview
Generate a cloud cost optimization report from a Dynatrace tenant with the Cloud Native Connection enabled. Two prompt variants are available: one for Dynatrace Assist, which needs no local tooling, and one for Claude Code with dtctl. Both discover which clouds and Kubernetes clusters are present before they build the report.
  • AWS and Azure idle resources. EBS volumes, EC2 instances and VMs, Elastic IPs, NAT gateways, Lambda functions and managed disks.
  • Kubernetes over-provisioning. Requests compared with what the workloads actually use, on clusters monitored by Dynatrace.
  • Estimated savings. On-demand list prices, with disaster recovery and high availability resources excluded.
  • A report to hand over. HTML output that you can print to PDF, written in a collaborative tone.
Use cases
  • Prepare a cloud cost review for a customer conversation.
  • Find idle and dangling cloud resources across accounts.
  • Size the savings of Kubernetes over-provisioning.
Get started
  1. Enable the Cloud Native Connection for AWS, Azure or both.
  2. Open the prompts and pick a variant.
  3. In Dynatrace Assist, paste the prompt and answer "Continue investigation" when Assist asks. With Claude Code, set your dtctl context and run the prompt.
The prices are list-price estimates. Reserved Instances, Savings Plans and other discounts lower the actual bill, and the report says so.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Cloud Cost Optimization (Agentic Workflow)
Agentic Optimization and Tuning logo
Forecast-driven performance and cost tuning, based on live utilization.
Dynatrace Assist logo
Dynatrace Assist
Dynatrace CLI - dtctl logo
Terminal-native CLI for operating Dynatrace, for AI agents and humans alike.
Dynatrace Hub
All (953)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
