Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Sonatype LifecycleSonatype Lifecycle
Sonatype Lifecycle
Sonatype Lifecycle
Ingest Sonatype vulnerability findings, scans, and audit logs.
Extension
Free trialDocumentation
Architecture diagram.Vulnerabilities sample dashboard.Security coverage sample dashboard.
  • Product information
  • Release notes
Overview
Dynatrace integrates with Sonatype Lifecycle to enable visibility, orchestration, and prioritization of code, library, and container vulnerability findings.
Capabilities:
  • Single pane of glass: Ingest vulnerability findings, scan events, and audit logs from Sonatype Lifecycle into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps the findings to a unified format for vulnerability findings (powered by Dynatrace Semantic Dictionary)
  • Findings operationalization: Prioritize, visualize, and automate vulnerability findings with runtime context
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC)
Use cases
  • Overview: Visualize and report your current security posture and trends around vulnerability findings across vulnerability scanners with Dashboards.
  • Prioritization: Analyze and prioritize vulnerability findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical vulnerability findings with Workflows.
  • Investigation: Use vulnerability findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
For more information on the installation and configuration, please see Sonatype Lifecycle extension in the Dynatrace Documentation.
Details
Compatibility information
REST API (release 188)
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Sonatype Lifecycle
ActiveGate logo
ActiveGate
Route traffic, monitor clouds and remote technologies & run Synthetic monitors.
Dashboards logo
Dashboards
Extensions logo
Extensions
Manage Dynatrace extensions for hundreds of technologies.
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
🚀 Improved in this version:
  • Added support for custom SSL certificates to connect to Sonatype.
ℹ️ This version requires ActiveGate version 1.313.0 or higher.
  • Vulnerability finding events now have vulnerability.cvss.base_score and vulnerability.cvss.vector fields.
  • Ingested security events are now enriched with the fields dt.security_context, dt.cost.costcenter and dt.cost.product defined in the monitoring configuration.
🪲 Fixed in this version:
  • Added internal metadata.
  • Fixed issue where non-standard characters in audit log lines would cause audit log fetching to fail.
  • Fixed issue where event fetching frequency would not be correctly parsed.
  • Fixed issue where a large amount of events would return a 413 on the Dynatrace API.
  • Fixed issue where selecting the default Dynatrace endpoint could prevent the extension from starting.
✨ New in this version:
  • Added vulnerability finding and scan event extraction.
  • Added audit log monitoring.
Dynatrace Hub
All (951)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
