Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Recorded FutureRecorded Future
Recorded Future
Recorded Future
Ingest Recorded Future threat reports.
Extension
Free trialDocumentation
Architectural diagram.Threat reports dashboard.Emerging threat dashboard.
  • Product information
  • Release notes
Overview
Dynatrace integrates with Recorded Future to enable visibility, unified analysis, and operationalization of threat intelligence across your monitored environments.
Capabilities:
  • Single pane of glass: Ingest threat reports and their indicators of compromise (IOCs) into Dynatrace (powered by OpenPipeline™)
  • Unified threat intelligence: Dynatrace transforms and maps threat reports to a unified format, so you can analyze and process threat exposure the same way across multiple threat intelligence sources (powered by Dynatrace Semantic Dictionary)
  • Runtime exposure analysis: Search and correlate indicators of compromise (IOCs) across all data in Dynatrace — both natively captured and ingested from third-party sources — including logs, traces, and events, to reveal where threats surface in your environment
  • Threat operationalization: Prioritize, visualize, and automate proactive emerging-threat exposure analysis and remediation with runtime context
Use cases
  • Overview: Visualize and report your current threat exposure and trends across your threat intelligence sources with ready-made Dashboards.
  • Runtime insights: Connect threat indicators of compromise (IOCs) to Dynatrace native apps to reveal where external threats intersect with your monitored environment, using Distributed Tracing, Logs, Vulnerabilities, and Threats & Exploits.
  • Automation: Drive proactive threat remediation and create notifications and tickets for critical threats with Workflows.
  • Investigation: Use threat reports as an additional dimension for threat hunting and incident forensics with Security Investigator.
Get started
For instructions, go to Ingest Recorded Future threat reports.
Details
Recorded Future integration comes with a couple of ready-made documents:
  • Emerging threat intelligence reports - Overview of the ingested threat intelligence reports and their indicators of compromise.
  • Threat exposure analysis - Analysis of a selected threat intelligence report against your runtime environment.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Recorded Future
Dashboards logo
Dashboards
Extensions logo
Extensions
Manage Dynatrace extensions for hundreds of technologies.
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
What's new: - Remove dashboards from the extensions, which are now served by the Security Operations app in a central fashion.
What's new:
  • Initial release.
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
