Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Palo Alto PanoramaPalo Alto Panorama
Palo Alto Panorama
Palo Alto Panorama
Observe Palo Alto Panorama-managed devices in Dynatrace.
Extension
Free trialDocumentation
Palo Alto Panorama dashboardPanorama devices view
  • Product information
  • Release notes
Overview
Monitor your Palo Alto firewalls and their interfaces through Palo Alto's centralized management platform, Panorama. Use the Unified Analysis pages and Infrastructure & Operations app to analyze the health of your firewalls and drill down into individual metrics.
Use cases
  • Monitor health and performance of Palo Alto firewalls and their interfaces
  • Identify problems with invividual network interfaces
  • Detect and alert on hardware issues such as fan speed or temperature
Get started
Follow Palo Alto Panorama extension in the Dynatrace Documentation.
Details
This extension is intended to work remotely by accessing metrics over the Panorama XML API. This extension uses the same metric keys as the SNMP based Palo Alto firewalls extension for compatability.
  • Custom entities are created for Palo Alto Firewalls, Interfaces and Virtual Systems
  • Generic network device metrics are also imported for compatability with the Infrastructure & Operations app
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Disk Sizecom.dynatrace.extension.palo-alto.generic.disk_size-Byte
Disk Availablecom.dynatrace.extension.palo-alto.generic.disk_available-Byte
Disk Usedcom.dynatrace.extension.palo-alto.generic.disk_used-Byte
Disk Usagecom.dynatrace.extension.palo-alto.generic.disk_usage-Percent
Free Memorycom.dynatrace.extension.palo-alto.generic.mem.free-MebiByte
Reclaimable Memorycom.dynatrace.extension.palo-alto.generic.mem.reclaimable-MebiByte
Used Memorycom.dynatrace.extension.palo-alto.generic.mem.used-MebiByte
Total Memorycom.dynatrace.extension.palo-alto.generic.mem.size-MebiByte
Memory Utilizationcom.dynatrace.extension.palo-alto.generic.mem.usage-Percent
Active Sessionscom.dynatrace.extension.palo-alto.generic.sessions.active-Count
Max Sessionscom.dynatrace.extension.palo-alto.generic.sessions.max-Count
TCP Sessionscom.dynatrace.extension.palo-alto.generic.sessions.tcp-Count
UDP Sessionscom.dynatrace.extension.palo-alto.generic.sessions.udp-Count
ICMP Sessionscom.dynatrace.extension.palo-alto.generic.sessions.icmp-Count
Predict Sessionscom.dynatrace.extension.palo-alto.generic.sessions.predict-Count
Broadcast Sessionscom.dynatrace.extension.palo-alto.generic.sessions.broadcast-Count
Sessions - SSL Proxycom.dynatrace.extension.palo-alto.generic.sessions.proxy-Count
Session SSL proxy utilizationcom.dynatrace.extension.palo-alto.generic.sessions.proxy.utilSSL proxt session utilization percentagePercent
Gateway Utilization Percentcom.dynatrace.extension.palo-alto.generic.gateway.utilization-Percent
Session Utilizationcom.dynatrace.extension.palo-alto.generic.sessions.utilizationSession table utilization percentagePercent
Max Tunnelscom.dynatrace.extension.palo-alto.generic.tunnels.max-Count
Active Tunnelscom.dynatrace.extension.palo-alto.generic.tunnels.active-Count
Interface Incoming Packets Countcom.dynatrace.extension.palo-alto.generic.if.in.pkts.count-Count
Interface Outgoing Packets Countcom.dynatrace.extension.palo-alto.generic.if.out.pkts.count-Count
Interface Incoming Dropped Packets Countcom.dynatrace.extension.palo-alto.generic.if.in.pkts.dropped.count-Count
-com.dynatrace.extension.network_device.if.in.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.out.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.in.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.out.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.in.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.out.ucast_pkts.count--
Interface Incoming Ucast Packets Countcom.dynatrace.extension.palo-alto.generic.if.in.ucast.packets.count-Count
Interface Outgoing Ucast Packets Countcom.dynatrace.extension.palo-alto.generic.if.out.ucast.packets.count-Count
System Uptimecom.dynatrace.extension.palo-alto.generic.sys.uptime-MilliSecond
System Userscom.dynatrace.extension.palo-alto.generic.sys.host.num_usersThe number of user sessions for which this host is storing state information.Count
Total Processescom.dynatrace.extension.palo-alto.generic.sys.host.max_processes-Count
Running Processescom.dynatrace.extension.palo-alto.generic.sys.host.num_processes-Count
Load Average 1mincom.dynatrace.extension.palo-alto.generic.sys.host.load_averageThe 1 minute load averageCount
Sensor Valuecom.dynatrace.extension.palo-alto.generic.sensor.valueRepresents fan speed, temperature, and PSU voltage railsUnspecified
Total Swapcom.dynatrace.extension.palo-alto.generic.swap.total-MebiByte
Free Swapcom.dynatrace.extension.palo-alto.generic.swap.free-MebiByte
Used Swapcom.dynatrace.extension.palo-alto.generic.swap.used-MebiByte
Swap Usagecom.dynatrace.extension.palo-alto.generic.swap.usage-Percent
CPU Usercom.dynatrace.extension.palo-alto.generic.cpu.user-Percent
CPU Idlecom.dynatrace.extension.palo-alto.generic.cpu.idle-Percent
CPU Systemcom.dynatrace.extension.palo-alto.generic.cpu.system-Percent
CPU I/O waitcom.dynatrace.extension.palo-alto.generic.cpu.iowait-Percent
CPU Stealcom.dynatrace.extension.palo-alto.generic.cpu.steal-Percent
Data Plane CPU Usagecom.dynatrace.extension.palo-alto.generic.data_plane.cpu_usage-Percent
CPU System Plane Utilizationcom.dynatrace.extension.palo-alto.generic.cpu.system.utilization-Percent
CPU Management Plane Utilizationcom.dynatrace.extension.palo-alto.generic.cpu.management.utilization-Percent
-com.dynatrace.extension.network_device.memory_total--
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_usage--
-com.dynatrace.extension.network_device.if.speed--
-com.dynatrace.extension.network_device.if.status--
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.in.errors.count--
-com.dynatrace.extension.network_device.if.out.errors.count--
-com.dynatrace.extension.network_device.if.in.discards.count--
-com.dynatrace.extension.network_device.if.out.discards.count--
-com.dynatrace.extension.network_device.sysuptime--
VSYS - Max Sessionscom.dynatrace.extension.palo-alto.generic.vsys.sessions.max-Count
VSYS - Active Sessionscom.dynatrace.extension.palo-alto.generic.vsys.sessions.active-Count
VSYS - Session Utilizationcom.dynatrace.extension.palo-alto.generic.vsys.sessions.utilization-Percent
Packet Drops: No arpcom.dynatrace.extension.palo-alto.generic.packet_drops.noarp-Count
Packet Drops: No routecom.dynatrace.extension.palo-alto.generic.packet_drops.noroute-Count
Device Management Sessions Deniedcom.dynatrace.extension.palo-alto.generic.packet_drops.session_denied-Count
Packet Drops: Layer2 receive errorcom.dynatrace.extension.palo-alto.generic.packet_drops.l2_parse_error-Count
Packet Drops: IP fragementation errorcom.dynatrace.extension.palo-alto.generic.packet_drops.ip_frag_error-Count
Packet Drops: QOS Timeoutcom.dynatrace.extension.palo-alto.generic.packet_drops.qos_timeouts-Count
Packet drops: Denied by policycom.dynatrace.extension.palo-alto.generic.packet_drops.policy_drops-Count
Incoming Interface Errorscom.dynatrace.extension.palo-alto.generic.if.in.err.count-Count
Outgoing Interface Errorscom.dynatrace.extension.palo-alto.generic.if.out.err.count-Count
Incoming Interface Discardscom.dynatrace.extension.palo-alto.generic.if.in.discards.count-Count
Outgoing Interface Discardscom.dynatrace.extension.palo-alto.generic.if.out.discards.count-Count
Interface Incoming Octets Countcom.dynatrace.extension.palo-alto.generic.if.in.octets.count-Count
Interface Outgoing Octets Countcom.dynatrace.extension.palo-alto.generic.if.out.octets.count-Count
Full version history
ReleaseDate
⚠️This version requires minimum ActiveGate version 1.338 and Dynatrace version 1.345.
New in this version:
Improved in this version:
  • Resolved a problem causing interface metrics not to be imported at all if the Advanced Interface feature set is disabled.
  • Resolved a problem causing EXT_NETWORK_INTERFACE Smartscape Nodes to be unlinked from their related EXT_NETWORK_DEVICE Node.
  • Some interface metrics that were incorrectly ingested with a wrong metric key are now ingested under the correct key. Here's a list of the affected metrics:
    • com.dynatrace.extension.network_device.in.multicast_pkts.count → com.dynatrace.extension.network_device.if.in.multicast_pkts.count
    • com.dynatrace.extension.network_device.out.multicast_pkts.count → com.dynatrace.extension.network_device.if.out.multicast_pkts.count
    • com.dynatrace.extension.network_device.in.broadcast_pkts.count → com.dynatrace.extension.network_device.if.in.broadcast_pkts.count
    • com.dynatrace.extension.network_device.out.broadcast_pkts.count → com.dynatrace.extension.network_device.if.out.broadcast_pkts.count
    • com.dynatrace.extension.network_device.in.ucast_pkts.count → com.dynatrace.extension.network_device.if.in.ucast_pkts.count
    • com.dynatrace.extension.network_device.out.ucast_pkts.count → com.dynatrace.extension.network_device.if.out.ucast_pkts.count
    • com.dynatrace.extension.palo-alto.generic.in.ucast.packets.count → com.dynatrace.extension.palo-alto.generic.if.in.ucast.packets.count
    • com.dynatrace.extension.palo-alto.generic.out.ucast.packets.count → com.dynatrace.extension.palo-alto.generic.if.out.ucast.packets.count
Update the certifi dependency to address CVE-2026-111943
  • Fix multiple InO app screens failing to query data.
  • Resolve issue with fastcheck failing due to SSL verificaton settings
  • Increased the maximum size of the API key text field
⚠️ WARNING ⚠️️: Possible breaking changes and warnings - PLEASE READ before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC version of 1.333.0.
  • This version includes a potentially breaking change for Dynatrace on Grail.
    • With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline instead of the default pipeline.
    • This means that any created custom dynamic rules will no longer be used on metrics ingested from the extension. If you want to keep enforcing them, please create pipeline groups.
  • Smartscape on Grail. This extension will populate new Smartscape nodes and edges via OpenPipeline extraction.
  • Added an option to bypass SSL certificate verification and accept SSL certificates
Initial release. Looking forward for your feedback via the Dynatrace Community!
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
