Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Palo Alto firewallsPalo Alto firewalls
Palo Alto firewalls
Palo Alto firewalls
Palo Alto extension for problems detection
Extension
Free trialDocumentation
  • Product information
  • Release notes
Overview
This extension leverages the SNMP protocol to provide a complete solution to monitor your Palo Alto Firewalls. The complete configuration is provided out-of-the-box.
This is intended for users, who:
  • Would like to monitor health state and performance of their Palo Alto Firewalls and provide unified analysis for Ops, DevOps and IT Admins.
This enables you to:
  • Monitor health and performance of your Palo Alto Firewalls
  • Use included alerts for fan speed, as well as temperature.
Use cases
Monitor health state and performance of your Palo Alto firewalls and provide unified analysis for Ops, DevOps and IT Admins.
Get started
For more information on the installation and configuration, please see Palo Alto firewalls extension in the Dynatrace Documentation.
Details
Compatibility information
  • This extension is to be used with Palo Alto Firewalls only.
  • SNMPv2c and SNMPv3 supported only.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.in.errors.count--
-com.dynatrace.extension.network_device.if.out.errors.count--
-com.dynatrace.extension.network_device.if.in.discards.count--
-com.dynatrace.extension.network_device.if.out.discards.count--
-com.dynatrace.extension.network_device.if.status--
-com.dynatrace.extension.network_device.sysuptime--
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.memory_total--
-com.dynatrace.extension.network_device.memory_used--
System uptimecom.dynatrace.extension.palo-alto.generic.sys.uptime-MilliSecond
CPU Management Plane Utilizationcom.dynatrace.extension.palo-alto.generic.cpu.management.utilization-Percent
CPU System Plane Utilizationcom.dynatrace.extension.palo-alto.generic.cpu.system.utilization-Percent
Memory Allocation Unitscom.dynatrace.extension.palo-alto.generic.mem.allocation.unitsThe size in bytes of the data objects allocated from this pool.Byte
Memory Sizecom.dynatrace.extension.palo-alto.generic.mem.size-Byte
Memory Usedcom.dynatrace.extension.palo-alto.generic.mem.used-Byte
Memory Allocation Failurescom.dynatrace.extension.palo-alto.generic.mem.allocation.failures.countThe number of requests for storage represented by this entry that could not be honored due to not enough storage.Count
-com.dynatrace.extension.palo-alto.generic.if.entity--
Interface Incoming Octets Countcom.dynatrace.extension.palo-alto.generic.if.in.octets.count-Count
Interface Incoming Ucast Packets Countcom.dynatrace.extension.palo-alto.generic.if.in.ucast.packets.count-Count
Interface Outgoing Octets Countcom.dynatrace.extension.palo-alto.generic.if.out.octets.count-Count
Interface Outgoing Packets Countcom.dynatrace.extension.palo-alto.generic.if.out.ucast.packets.count-Count
Interface Incoming Errorscom.dynatrace.extension.palo-alto.generic.if.in.err.count-Count
Interface Outgoing Errorscom.dynatrace.extension.palo-alto.generic.if.out.err.count-Count
Interface Incoming Discardscom.dynatrace.extension.palo-alto.generic.if.in.discards.count-Count
Interface Outgoing Discardscom.dynatrace.extension.palo-alto.generic.if.out.discards.count-Count
Incoming log ratecom.dynatrace.extension.palo-alto.generic.pandeviceincominglograteThe incoming rate in logs/s on the Device. PAN-COMMON-MIBPerSecond
Write log ratecom.dynatrace.extension.palo-alto.generic.pandevicewritelograteThe write rate in logs/s on the Device. PAN-COMMON-MIBPerSecond
Zone active TCP connections per secondcom.dynatrace.extension.palo-alto.generic.zone.active.tcp.cpsNumber of active TCP connections per second for this zone. panZoneActiveTcpCps - PAN-COMMON-MIBPerSecond
Zone active UDP connections per secondcom.dynatrace.extension.palo-alto.generic.zone.active.udp.cpsNumber of active UDP connections per second for this zone. panZoneActiveUdpCps - PAN-COMMON-MIBPerSecond
Zone Other IP connections per secondcom.dynatrace.extension.palo-alto.generic.zone.active.otherip.cpsNumber of active Other IP connections per second for this zone. panZoneActiveOtherIpCps - PAN-COMMON-MIBPerSecond
VSYS - Max Sessionscom.dynatrace.extension.palo-alto.generic.vsys.sessions.max-Count
VSYS - Active Sessionscom.dynatrace.extension.palo-alto.generic.vsys.sessions.active-Count
VSYS - Session Utilizationcom.dynatrace.extension.palo-alto.generic.vsys.sessions.utilization-Percent
System Userscom.dynatrace.extension.palo-alto.generic.sys.host.num_usersThe number of user sessions for which this host is storing state information. hrSystemNumUsersCount
System Processescom.dynatrace.extension.palo-alto.generic.sys.host.num_processesThe number of process contexts currently loaded or running on this system. hrSystemProcessesCount
System Max Processescom.dynatrace.extension.palo-alto.generic.sys.host.max_processesThe maximum number of process contexts this system can support. hrSystemMaxProcessesCount
Load Average 1mincom.dynatrace.extension.palo-alto.generic.sys.host.load_averageThe 1 minute load average. laLoadCount
-com.dynatrace.extension.network_device.if.in.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.out.multicast_pkts.count--
-com.dynatrace.extension.network_device.if.in.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.out.broadcast_pkts.count--
-com.dynatrace.extension.network_device.if.in.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.out.ucast_pkts.count--
-com.dynatrace.extension.network_device.if.lastchange--
PAN LC Log Ratecom.dynatrace.extension.palo-alto.generic.lc.log_rateThe write rate in logs/s on the Log Collection.PerSecond
PAN LC Disk Usagecom.dynatrace.extension.palo-alto.generic.lc.disk_usageThe Log disk usage for logical disks on the Log CollectorMegaByte
PAN LC Log Durationcom.dynatrace.extension.palo-alto.generic.lc.log_durationThe Log duration (in days) for the logs on the Log CollectorDay
Sys release date infocom.dynatrace.extension.palo-alto.generic.sys.release.datesDimensions: panSysSwVersion panSysAppVersion, panSysAppReleaseDate, panSysThreatVersion, panSysThreatReleaseDate, panSysAvVersion, panSysAvReleaseDate, panSysWildfireVersion, panSysWfReleaseDate, panSysUrlFilteringVersion, panSysHAState, panSysHAPeerState, chassis.type . PAN-COMMON-MIBPerSecond
Active Tunnelscom.dynatrace.extension.palo-alto.generic.tunnels.active-Count
Max Tunnelscom.dynatrace.extension.palo-alto.generic.tunnels.max-Count
Gateway Utilization %com.dynatrace.extension.palo-alto.generic.gateway.utilization-Percent
Active Sessionscom.dynatrace.extension.palo-alto.generic.sessions.active-Count
Session utilizationcom.dynatrace.extension.palo-alto.generic.sessions.utilizationSession table utilization percentage.Percent
Max Sessionscom.dynatrace.extension.palo-alto.generic.sessions.max-Count
Sessions - TCPcom.dynatrace.extension.palo-alto.generic.sessions.tcp-Count
Sessions - UDPcom.dynatrace.extension.palo-alto.generic.sessions.udp-Count
Sessions - ICMPcom.dynatrace.extension.palo-alto.generic.sessions.icmp-Count
Sessions - SSL Proxycom.dynatrace.extension.palo-alto.generic.sessions.proxy-Count
Session SSL proxy utilizationcom.dynatrace.extension.palo-alto.generic.sessions.proxy.utilSSL proxy Session utilization percentage. panSessionSslProxyUtilization PAN-COMMON-MIBPercent
Total Power Available (Watts)com.dynatrace.extension.palo-alto.generic.power.available-Count
Total Power Used (Watts)com.dynatrace.extension.palo-alto.generic.power.used-Count
Sensor Valuecom.dynatrace.extension.palo-alto.generic.sensor.valueentPhySensorValue objects, represent fan speed and temperature.Unspecified
Full version history
ReleaseDate
🚀 Improved in this version:
  • Platform dashboard links now point to the Infrastructure and Operations app.
ℹ️ This version requires ActiveGate version 1.313.0 or higher.
Fixed in this version:
  • sys.name and mac.address dimensions are required on all network metrics and filtered for empty values. This caused unnecessary stress on topology engine
⚠️ IMPORTANT: This version requires a minimum Dynatrace version of 1.318
✨ New in this version (3.2.1):
  • Added Davis anomaly detector templates to extension package
    • Palo-Alto fan speed
    • Palo-Alto temperature alert
✨ New in this version (3.1.0):
  • Added the following new metrics to the Advanced interfaces feature set:
    • com.dynatrace.extension.network_device.if.in.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.out.multicast_pkts.count
    • com.dynatrace.extension.network_device.if.in.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.out.broadcast_pkts.count
    • com.dynatrace.extension.network_device.if.in.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.out.ucast_pkts.count
    • com.dynatrace.extension.network_device.if.lastchange
🪲 Fixed in this version:
  • Removed generic entities from the built-in dashboard to align with other network extensions.
✨ New in this version (3.0.1):
  • The following metrics from the default feature set were regrouped into a new control-plane feature set:
  • com.dynatrace.extension.palo-alto.generic.sys.uptime
  • com.dynatrace.extension.palo-alto.generic.cpu.management.utilization
  • com.dynatrace.extension.palo-alto.generic.cpu.system.utilization
  • com.dynatrace.extension.palo-alto.generic.mem.allocation.units
  • com.dynatrace.extension.palo-alto.generic.mem.size
  • com.dynatrace.extension.palo-alto.generic.mem.used
  • com.dynatrace.extension.palo-alto.generic.mem.allocation.failures.count
⚠️ WARNING: if you want to keep monitoring these metrics, you must manually toggle on the new feature set in the updated extension configuration.
  • Corrected key of interface errors metric for proper display in the Infrastructure & Operations app, from if.in/out.err.count to if.in/out.errors.count.
  • Removed redundant com.dynatrace.extension.palo-alto.generic.device.entity metric to align with our standards.
⚠️ WARNING: you will have to manually change any dashboard, alert, or other dependent configuration that uses the old metric keys.
  • Assigned correct OID to the com.dynatrace.extension.palo-alto.generic.cpu.system.utilization metric.
  • Cleaned up duplicate attributes in the Infrastructure & Operations app.
✨ New in this version:
  • To align with other network extensions, the following metrics were added default feature set:
    • com.dynatrace.extension.network_device.if.bytes_in.count
    • com.dynatrace.extension.network_device.if.bytes_out.count
    • com.dynatrace.extension.network_device.if.in.err.count
    • com.dynatrace.extension.network_device.if.out.err.count
    • com.dynatrace.extension.network_device.if.in.discards.count
    • com.dynatrace.extension.network_device.if.out.discards.count
    • com.dynatrace.extension.network_device.if.status
    This means that interfaces will now be monitored as part of the default feature set. It is still possible to disable interface monitoring by using the filter $eq() in the Pattern to filter capturing of Interfaces by Name field of the monitoring configuration.
  • Added out-of-the-box Platform dashboard.
  • The dt.security_context property will now be propagated to all entities created by this extension.
Version 2.9.7 (09 May 2025)
  • Added dimensions sw.version and chassis.type to the metric com.dynatrace.extension.palo-alto.generic.sys.release.dates.
  • These dimension values will now show as attributes of the Palo Alto Device entity.
ℹ️ This version requires ActiveGate version 1.290.0 or higher.
  • Added dimensions ha.peerstate, app.version, threat.version, av.version, wf.version and urlfiltering.version to the metric com.dynatrace.extension.palo-alto.generic.sys.release.dates. These dimension values will now show as attributes of the Palo Alto Device entity.
  • Added charts for logging metrics to the Palo Alto Device entity screen.
  • The com.dynatrace.extension.network_device.sysuptime and com.dynatrace.extension.palo-alto.generic.sys.uptime now represent the time since the device was started (OID 1.3.6.1.2.1.25.1.1.0) as opposed to the time since the SNMP service was started (OID 1.3.6.1.2.1.1.3.0).
  • To better control licensing costs the following changes have been made to the extension's feature sets:
    • The generic interface metrics were moved from the default feature set to interface.
    • Added new feature set hardware to which the power consumption and sensor metrics were moved.
      • ⚠️ When automatically upgrading existing configurations, the new feature set will be disabled by default. To continue monitoring power consumption and sensor metrics you will need to manually update each monitoring configuration and enable the new feature set after upgrading. ⚠️
  • Added a status dimension to the com.dynatrace.extension.palo-alto.generic.cpu.system.utilization and com.dynatrace.extension.palo-alto.generic.cpu.management.utilization metrics corresponding to OID 1.3.6.1.2.1.25.3.2.1.5.
  • Fixed bug where interface attributes would sometimes not be populated.
  • Added power usage metrics com.dynatrace.extension.palo-alto.generic.power.available and com.dynatrace.extension.palo-alto.generic.power.used and corresponding charts as part of the general feature set.
  • Added metrics com.dynatrace.extension.palo-alto.generic.gateway.utilization, com.dynatrace.extension.palo-alto.generic.sessions.utilization, com.dynatrace.extension.palo-alto.generic.sessions.proxy as part of the gateway feature set.
  • Added interface packet metrics com.dynatrace.extension.palo-alto.generic.if.in.ucast.packets.count and com.dynatrace.extension.palo-alto.generic.if.out.ucast.packets.count and corresponding charts as part of the interface feature set.
  • Added metrics com.dynatrace.extension.palo-alto.generic.mem.allocation.units and com.dynatrace.extension.palo-alto.generic.mem.allocation.failures.count as part of the memory feature set.
  • Added a new feature set zone with metrics com.dynatrace.extension.palo-alto.generic.zone.active.tcp.cps, com.dynatrace.extension.palo-alto.generic.zone.active.udp.cps and com.dynatrace.extension.palo-alto.generic.zone.active.otherip.cps.
  • Added a new feature set device-logging with metrics com.dynatrace.extension.palo-alto.generic.pandeviceincominglograte and com.dynatrace.extension.palo-alto.generic.pandevicewritelograte.
  • Added a new feature set pan-sys with the metric com.dynatrace.extension.palo-alto.generic.sys.release.dates.
  • New entities and metrics were added to represent Palo Alto as a network device
  • Changed the interface speed dimension to use the ifHighSpeed OID 1.3.6.1.2.1.31.1.1.1.15 instead of 1.3.6.1.2.1.2.2.1.5.
Fixed bug where metrics weren't being picked up in management zones with Palo Alto entities.
Breaking changes
Dropped support for 32-bit counter octet in/out interface metrics. Only 64-bit counters are now supported. Only devices with Firewall PAN-OS version earlier than 8.1 will be affected.
The interface_high_capacity feature set was dropped as those metrics are now in the interface feature set. Before being able to upgrade your monitoring configurations you will need to manually disable the interface-high-capacity on those configurations (if enabled).
Breaking changes
The following metrics of the interface_high_capacity feature set are renamed
  • com.dynatrace.extension.palo-alto.generic.if.in.octets to com.dynatrace.extension.palo-alto.generic.if.hc.in.octets
  • com.dynatrace.extension.palo-alto.generic.if.out.octets to com.dynatrace.extension.palo-alto.generic.if.hc.out.octets
  • com.dynatrace.extension.palo-alto.generic.if.in.err to com.dynatrace.extension.palo-alto.generic.if.hc.in.err
  • com.dynatrace.extension.palo-alto.generic.if.out.err to com.dynatrace.extension.palo-alto.generic.if.hc.out.err
  • com.dynatrace.extension.palo-alto.generic.if.in.discards to com.dynatrace.extension.palo-alto.generic.if.hc.in.discards
  • com.dynatrace.extension.palo-alto.generic.if.out.discards to com.dynatrace.extension.palo-alto.generic.if.hc.out.discards
Any dashboards or metric events relying on these metrics will need to be reconfigured.
Customers not using the interface_high_capacity feature set are not affected.
Description
Renamed high capacity interface metrics, to fix a bug where having both the interface and interface_high_capacity feature sets enabled at the same time would cause inaccurate metrics to be ingested.
No release notes
No release notes
Fix for dashboard to be compatible with feature flags
  • bugfix: added missing chartCards
  • bugfix: added featureSet with high capacity interface metrics to fix data discrepancy
v0.4.0
  • Added ability to use filters for Interface Name, Admin and Operational Status
Substract of suffix ".count" in metric com.dynatrace.extension.palo-alto.generic.sys.uptime and changed it type to gauge
  1. New calculated metrics:
    • func:com.dynatrace.extension.palo-alto.generic.if.in.octets.bitpersec
    • func:com.dynatrace.extension.palo-alto.generic.if.out.octets.bitpersec
    • func:com.dynatrace.extension.palo-alto.generic.mem.utilization
  2. Corrected oid for dimension: if.keyx
  3. New dimension if.descr for subgroup interface
  4. Added topology, relationships and screens
Version 0.1.15 (initial):
  • SNMP DataSource configuration
  • dashboard template
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
