Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Live DebuggerLive Debugger
Live Debugger
Live Debugger
Get real-time debug data from production or any remote environment.
App
Free trialDocumentation
Real-time snapshot of debug data created once a non-breaking breakpoint has been triggered.Real-time snapshots with VS Code PlugInReal-time snapshots with JetBrains PlugIn
  • Product information
  • Release notes
Overview
Dynatrace Live Debugger is a Cloud-Native and live data collection application that gives you instant access to the code-level data you need to troubleshoot and debug quickly in any environment, from dev to production. With a single click, access the necessary and relevant data without needing to add additional code, wait for redeploy, or attempt to reproduce issues locally. Additionally, using non-breaking breakpoints allows you to instantly see the complete state of your app, including stack trace, variable values, and more, all without stopping or breaking your running code.
Use cases
Capture real-time debug data
  • Instantly understand the state of your application using non-breaking breakpoints and get instant output, including your full stack trace, local and global variables, tracing data and context, and server metrics (CPU, memory, time measurements, and more).
Troubleshoot faster
  • Instantly debug the most complex flows.
  • Fix bugs with zero friction, overhead, or risk.
  • Get real-time data without stopping your app.
  • Gain visibility into third-party dependencies and overcome debugging challenges from using open source components, external dependencies, or your legacy code.
Dev-friendly debugging experience
  • Empower your developers with on-demand access to code-level data.
  • Get full visibility into your code with a simple and intuitive experience.
Optimize R&D efficiency: Spend less time fixing bugs and more time developing value for your organization and customers.
  • Never leave your comfort zone with the choice of either an IDE plugin or the Live Debugger web app.
Test and optimize your code faster
  • Instantly understand if specific line of code was reached at all with exploratory analytics
Get started
You can choose to get live snapshots of remote environments and debug or validate fixes from the Live Debugger web-app or directly in the IDE—including through our VSCode and JetBrains IDE plugins, wherever works best.
Download the Live Debugger plugIn from the Microsoft VS Code Marketplace
Download the Live Debugger plugIn from the JetBrains Marketplace
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Live Debugger
OneAgent logo
OneAgent
The simplest way to capture all observation signals automatically and in context.
GitHub logo
GitHub
Automate GitHub issues, pull requests, and workflows from Dynatrace.
GitHub Enterprise - SNMP logo
Monitor your GitHub Enterprise instance remotely with SNMP.
More resources
IDE PlugIns - JetBrains
Jetbrains Live Debugger PlugIn
IDE PlugIns - VSCode
VSCode Live Debugger PlugIn
Full version history
ReleaseDate
Minor Changes
  • Support User-Scoped Breakpoints View
  • Added the Dynatrace in-product feedback pop-up to the "Share feedback" Help menu entry, and renamed the previous feedback link to "Community".
Patch Changes
  • Fixed a crash when clicking Retry on the "Failed to sync Git On Premise settings" toast and the sync fails again.
Minor Changes
  • IDE connector button added to the app header
Patch Changes
  • Snapshots opened from a plugin link show the correct session in the snapshots page
Minor Changes
  • Opt-in settings now show the actual reason a scope can't be configured: unsupported type, Kubernetes metadata enrichment missing required attributes, or missing read permission (lock icon and "Unknown" chip instead of a misleading toggle).
Patch Changes
  • Support regional date formatting throughout the application
Minor Changes
  • Snapshots page now includes a session picker that displays snapshots from different sources (dtctl, IDE plugins, Web app).
Patch Changes
  • New Logs tab is added to the Snapshot details
  • Reduce amount of scrollable space beyond the last line of the file viewer
dynatrace.devobs.debugger
1.17.2
Patch Changes
  • Fix crash when opening a snapshot containing a binary variable
1.17.1
Patch Changes
  • Fix an edge case issue with Bitbucket SaaS not fetching repositories correctly
1.17.0
Minor Changes
  • Add a guide toast for blocked local network access in Firefox when using the desktop app for code fetching
Patch Changes
  • Fix breakpoint status popup positioning issues
  • Fixed tab colors in the Snapshots page snapshot details panel to match the Debugger page
  • Opt-in settings: each tab now persists its own filters independently
1.16.5
Patch Changes
  • Fixed agent groups appearing empty when grouping by anything other than "None" in session configuration
  • Updated "Show inactive" toggle layout in the Server Selection dialog
  • Fixed "Live Debugger is not enabled" message being incorrectly shown when it is enabled
  • Fixed blank screen sometimes appearing when Live Debugger is not enabled
  • Fixed invalid filter error in opt-in settings after a search with no results
  • Fixed Watch icon — clicking it on a watched attribute now correctly removes the column from the Snapshots table
  • Fixed "Open in Bitbucket" opening the repository root instead of the specific file
  • Opening images and binary files in the source viewer now shows a warning instead of getting stuck loading
1.16.4
Patch Changes
  • Fix missing servers in session configuration when a grouping mode is active
1.16.3
Patch Changes
  • Fixed tenant-level opt-in settings toggling not working for new tenants
  • Fixed missing files after loading a local filesystem folder
  • Redirect users without required permissions to the welcome page instead of crashing
1.16.2
Minor Changes
  • Open the correct entity tab in Opt-In Settings when navigating with a predefined filter
Patch Changes
  • Fix IDE plugin redirect to app not showing the correct snapshots
  • Fix tooltip overlap in Edit Breakpoint modal
  • Add architecture-specific download link for the Desktop Application on first-time setup
  • Improve input UI for server selection
  • Fix process groups incorrectly shown as unsupported in Opt-In Settings
  • Fixed issue where repo names would sometimes show undefined/undefined in the breakpoints tab
  • Fix occasional crash when selecting branches when manually fetching source code
1.15.0
Minor Changes
  • Added new UI for configuring Git On-Prem settings, improving the setup flow for on-premises and SaaS Git configurations
  • Added Host Group and Kubernetes Deployments scopes support in the Opt-In settings
  • Introduces new in-app onboarding screens, including opt-in scenarios for users facing permission-related issues
  • Improved variable tree and file tree UI
Patch Changes
  • Updated the intent payload schema to enforce a single filter
  • Fixed branch selection in manual source fetching not being properly applied
1.14.0
Minor Changes
  • Add support for lightmode
  • Add class variables support
  • Added new settings page for enabling Observability for Developers
Patch Changes
  • Optimized repo fetching performance for Bitbucket SaaS.
  • Fix case-sensitive search on Breakpoints management page
  • Fix Breakpoints page toolbar unreachable when rows per page is greater than 10
  • Fix a crash + visual bug in the Breakpoint page
  • Improved snapshots table UI in the Debugger page
1.13.0
Minor Changes
  • Code fetching:
    • Improved setup flow with clearer SaaS vs. On-Prem guidance, including the ability to pick from multiple On-Prem servers.
    • Added manual search support in the owner, repository, and branch picker.
    • You can now fetch code by pasting a remote origin URL directly.
    • Fixes included for GitLab subgroup search and Bitbucket SaaS integration.
  • Enabled intent‑based automatic service filtering on the Server Selection page and automatic navigation to relevant files and lines.
Patch Changes
  • Fixed Trace and Span ID UI bug in Snapshot View.
  • Fixed UI issues in the Breakpoint Table filter column.
1.12.2
Patch Changes
  • Add a horizontal scroll in source code panel.
  • Fixed an issue that could affect signing in with OAuth providers, improving overall login stability.
1.12.1
Patch Changes
  • Fix OAuth authentication error
1.12.0
Minor Changes
  • Dynatrace Desktop App upgrade is now only required when outdated by a major version.
  • Fixed Snapshots page UX.
  • Fixed a bug in Snapshots page to show the newest data.
1.11.0
Minor Changes
  • Improved server selection performance
  • Fixed an issue that caused duplicate autocomplete suggestions in "edit breakpoint" form inputs.
  • Bug fix: Header disappears after opening a snapshot and pressing on info tab
1.10.3
Patch Changes
  • Corrected the link used for Local Network Settings so it now points to the proper domain path.
1.10.2
Patch Changes
  • Improved app stability: the app now recovers gracefully from unexpected errors, while automatically reporting issues to help us resolve them faster.
  • Resolved an issue causing unrelated repositories to appear when filters were changed.
1.10.1
Patch Changes
  • Fixed tracing data not shown in recently received snapshots
  • File search UI visual tweaks
1.10.0
Minor Changes
  • Added “Watch” option for Trace/Span IDs in Snapshots View
  • Improved handling of 403 & 404 errors
  • Added source indication for IDE-created breakpoints
  • Fixed app crash on edit link
  • Fixed welcome screen bug
  • Reworked timeframe picker in the Snapshots page
1.9.0
Minor Changes
  • Fixed issues with the "Download Desktop App" button
  • Improved performance when fetching large repositories
  • Corrected owner evaluation during repo fetch
  • Fixed broken documentation link
  • Removed "Under Construction" notice from Playground
  • Resolved Firefox UI bugs
  • Fixed DPS documentation link
Patch Changes
  • Fixed some UI quirks with Desktop App verification
  • UI fixes for Server Selection modal
  • mproving repository tree loading time
  • Add a check for browser Local Network Access permission, and prompt when not allowed
  • Fixed fetching repositories from Git On Premise servers with paths in the base URL
1.8.3
Patch Changes
  • Escaping gitHub file Decode failure to prevent application crash
1.8.2
Patch Changes
  • GitLab PAT Link Fix: Updated PAT links to align with different GitLab versions for accurate navigation.
  • HTTPS Requirement: Documented that Git on-prem integrations require HTTPS URLs (no HTTP support).
  • Tracing App Fix: Resolved error when navigating to Tracing app via trace/span ID.
  • Demo Video Improvements: Increased demo video size for readability.
1.8.1
Patch Changes
  • Prevent unnecessary requests to Desktop App, Chrome v142+ users will only be prompted for Local Network Access when it's actually needed.
  • Stack Trace: Changed highlight color for better visibility.
  • Panels have wider range of resizing.
  • Bitbucket: Fixed fetching repositories using tags (requires latest Desktop App).
1.8.0
Minor Changes
  • Fixed a bug when using "group by" in the snapshots table caused a crash
  • Fixed search-facet input losing focus
  • Restored Bitbucket "Tags" selector for source fetching parity with GitHub
  • Removed unused permission requirement settings:objects:write
  • Stack Trace in Snapshots is now read-only (removed misleading code-navigation links)
1.7.0
Minor Changes
  • App no longer requires storage:buckets:read and storage:application.snapshots:read permissions
  • "Tracing" tab in the snapshots view now clearly displays the trace ID and span ID of the snapshot and has a button to view the span/trace in the Distributed Tracing app
Patch Changes
  • Snapshots page - fixed snapshot filtering not working
  • Snapshots page - fixed issue where snapshot details would not load properly
1.6.6
Patch Changes
  • Removed share snapshot function, it will return in the future
  • Added validation for message format, detecting illegal characters
1.6.5
Minor Changes
  • Onboarding functionality fix
  • Added option to group messages by trace ID
  • Fixed repositories unexpectedly disappearing from the repositories view
1.6.4
Patch Changes
  • LiveDebugger 1.6.4 Release Notes
    Bug Fixes
    • Fixed live tail functionality in snapshots page
    • Resolved breakpoint management issues
    • Fixed application crash in snapshots page
    • Corrected tenant redirect during OAuth authentication
    • Fixed repository picker display issues in Firefox
    UI Improvements
    • Fixed text overflow in buttons
    • Implemented Strato Checkbox and Radio button components
    • Add localization support
    Performance & Security
    • Moved Git authentication data to user app state
    • Set maximum object limit to 10 for on-premise Git instances
    • Removed legacy intent handling
1.6.2
Patch Changes
  • UI/UX fixes and fix for download locals as JSON
1.6.1
Patch Changes
  • Bug fixes.
  • Change logic for redirect depended on tenantID/alias/"friendly name"
  • Fixes for form validation for advanced rule-editor
1.6.0
Minor Changes
  • Getting Git On Prem settings now updates CSP settings accordingly
  • UI and visual changes
1.5.0
Minor Changes
  • Fixed various bugs with Snapshot fetching edge cases.
1.4.2
Patch Changes
  • Bugs fixes & Improvements
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
  • Includes bugs fixes and UI improvements
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
  • Use Grail as db by default in all environments
1.1.1
Patch Changes
  • Enable Grail by default as DB in stage environment
1.1.0
Minor Changes
  • Add temporary flag for Grail DB
1.0.12
Patch Changes
  • Enable querying grail db - using flag to be false by default
1.0.11
Patch Changes
  • Add supprot for grail DB
1.0.10
Patch Changes
  • Fix for grail enablement
1.0.9
Patch Changes
  • Added initial support for Grail
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
  • Added dependency for Live Debugger API version
1.0.4
Patch Changes
  • Support for the Live Debugger Desktop App
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
  • Live Debugger Initial Release
1.8.3
Patch Changes
1.8.2
Patch Changes
1.8.1
Patch Changes
1.8.0
Minor Changes
1.7.0
Minor Changes
Patch Changes
1.6.6
Patch Changes
1.6.5
Minor Changes
1.6.4
Patch Changes
    Bug Fixes
    UI Improvements
1.6.2
Patch Changes
1.6.1
Patch Changes
  • Bug fixes.
1.6.0
Minor Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.8.2
Patch Changes
1.8.1
Patch Changes
1.8.0
Minor Changes
1.7.0
Minor Changes
Patch Changes
1.6.6
Patch Changes
1.6.5
Minor Changes
1.6.4
Patch Changes
    Bug Fixes
    UI Improvements
1.6.2
Patch Changes
1.6.1
Patch Changes
  • Bug fixes.
1.6.0
Minor Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.8.1
Patch Changes
1.8.0
Minor Changes
1.7.0
Minor Changes
Patch Changes
1.6.6
Patch Changes
1.6.5
Minor Changes
1.6.4
Patch Changes
    Bug Fixes
    UI Improvements
1.6.2
Patch Changes
1.6.1
Patch Changes
  • Bug fixes.
1.6.0
Minor Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.7.0
Minor Changes
Patch Changes
1.6.6
Patch Changes
1.6.5
Minor Changes
1.6.4
Patch Changes
    Bug Fixes
    UI Improvements
1.6.2
Patch Changes
1.6.1
Patch Changes
  • Bug fixes.
1.6.0
Minor Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.6.6
Patch Changes
1.6.5
Minor Changes
1.6.4
Patch Changes
    Bug Fixes
    UI Improvements
1.6.2
Patch Changes
1.6.1
Patch Changes
  • Bug fixes.
1.6.0
Minor Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.6.5
Minor Changes
1.6.4
Patch Changes
    Bug Fixes
    UI Improvements
1.6.2
Patch Changes
  • Fixed the "Download Locals as JSON" button not working
1.6.0
Minor Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.5.0
Minor Changes
1.4.2
Patch Changes
1.4.1
Patch Changes
  • Tests
1.4.0
Minor Changes
1.3.0
Minor Changes
  • Includes Fixes
1.2.0
Minor Changes
1.1.1
Patch Changes
1.1.0
Minor Changes
1.0.12
Patch Changes
1.0.11
Patch Changes
1.0.10
Patch Changes
1.0.9
Patch Changes
1.0.8
Patch Changes
  • Fixed crash
1.0.7
Patch Changes
  • Various bug fixes
1.0.6
Patch Changes
  • Various bug fixes
1.0.5
Patch Changes
1.0.4
Patch Changes
  • Various bug fixes
1.0.3
Patch Changes
  • Various bug fixes
1.0.2
Patch Changes
  • Various bug fixes
1.0.1
Patch Changes
1.3.0
Minor Changes
  • Releasing app for general availability
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
