Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
LevelBlue (AlienVault) OTXLevelBlue (AlienVault) OTX
Ingest LevelBlue (AlienVault) OTX threat reports.
Extension
Free trialDocumentation
Architectural diagram.Threat reports dashboard.Threat exposure dashboard.Threat exposure dashboard (IOCs).
  • Product information
  • Release notes
Overview
Dynatrace integrates with LevelBlue (AlienVault) Open Threat Exchange (OTX) to enable visibility, unified analysis, and operationalization of open threat intelligence across your monitored environments. The integration collects OTX pulses and their related indicators of compromise, such as IP addresses, domains, URLs, and file hashes, maps them to the Dynatrace Semantic Dictionary, and ingests them as normalized threat report events. This helps security teams investigate threats, correlate external intelligence with monitored environments, and automate response workflows.
Capabilities:
  • Single pane of glass: Ingest threat reports and their indicators of compromise (IOCs) into Dynatrace (powered by OpenPipeline™)
  • Unified threat intelligence: Dynatrace transforms and maps threat reports to a unified format, so you can analyze and process threat exposure the same way across multiple threat intelligence sources (powered by Dynatrace Semantic Dictionary)
  • Runtime exposure analysis: Search and correlate indicators of compromise (IOCs) across all data in Dynatrace — both natively captured and ingested from third-party sources — including logs, traces, and events, to reveal where threats surface in your environment
  • Threat operationalization: Prioritize, visualize, and automate proactive emerging-threat exposure analysis and remediation with runtime context
Use cases
  • Overview: Visualize and report your current threat exposure and trends across your threat intelligence sources with ready-made Dashboards.
  • Runtime insights: Connect threat indicators of compromise (IOCs) to Dynatrace native apps to reveal where external threats intersect with your monitored environment, using Distributed Tracing, Logs, Vulnerabilities, and Threats & Exploits.
  • Automation: Drive proactive threat remediation and create notifications and tickets for critical threats with Workflows.
  • Investigation: Use threat reports as an additional dimension for threat hunting and incident forensics with Security Investigator.
Get started
For instructions, go to Ingest LevelBlue (AlienVault) OTX threat reports.
Details
LevelBlue (AlienVault) OTX integration comes with a couple of ready-made documents:
  • Emerging threat intelligence reports - Overview of the ingested threat intelligence reports and their indicators of compromise.
  • Threat exposure analysis - Analysis of a selected threat intelligence report against your runtime environment.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to LevelBlue (AlienVault) OTX
ActiveGate logo
ActiveGate
Route traffic, monitor clouds and remote technologies & run Synthetic monitors.
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
What's new: - Remove dashboards from the extensions, which are now served by the Security Operations app in a central fashion.
New in this version
  • Hardened HTTP proxy support with validated proxy URLs, credential URL-encoding, and redacted proxy error messages.
  • Rejected custom security events ingest endpoints that use localhost or 127.0.0.1.
  • Improved fastcheck and connection status reporting for proxy and authentication failures.
What's new: - Initial release of integration.
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
