Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Knowledge BaseKnowledge Base
Knowledge Base
Knowledge Base
Create and manage custom skills used by Assist, agents and agentic workflows.
App
Free trialDocumentation
The skills list shows the owner and enabled state of each skill.Edit the SKILL.md file and add reference files.
  • Product information
  • Release notes
Overview
Use Knowledge Base to give Dynatrace Intelligence the knowledge specific to your environment, such as runbooks, troubleshooting steps and naming conventions. You write it down as a skill. Dynatrace Assist and agentic workflows load the same skills, so your procedures and terms apply in both.
Main capabilities include:
  • Skills follow the agent skills format: a SKILL.md plus optional reference files.
  • Start a skill from a template or upload one you already have, then add reference files.
  • Edit skills, and switch a skill off without deleting it.
  • Skills apply to the whole environment. Everyone can view them; editing requires permission to write documents.
Use cases
  • Add your runbook as a skill: Assist uses its steps and context as guidance when it investigates.
  • Teach Assist your terms: describe service names, ownership and business terms once.
  • One skill for chat and automation: select it in an agentic workflow action, and the workflow run uses the same skill as Assist.
Get started
Open Knowledge Base and select New skill or Upload. You can also ask Dynatrace Assist: "What are the best practices for creating a custom skill?"
If you connect a coding agent or another AI tool outside the Dynatrace platform through the Dynatrace MCP Server, add the Dynatrace skills from AI Skills and MCP Tools to that agent.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Knowledge Base
Agentic Workflows logo
Agentic Workflows
Build agentic workflows to automate, orchestrate and govern operations at scale.
AI Skills and MCP Tools logo
Dynatrace tools and skills for the AI agents you run in any MCP client.
Dynatrace Assist logo
Dynatrace Assist
Dynatrace Intelligence for Workflows logo
Add agentic AI, prompts and built-in analysis to your workflows.
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Full version history
ReleaseDate
Knowledge Base — v1.2.2 Release Notes
Skills overview
  • Skills shipped by apps that Assist doesn't use are no longer listed, so the table only shows skills Assist can pick up
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
