Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Claude Code CLIClaude Code CLI
Claude Code CLI
Claude Code CLI
Investigate production issues from Claude Code with one plugin install.
Technology
Free trialDocumentation
Investigate failures with live Dynatrace context: error rates, impacted services, and root causes, without leaving your terminal
  • Product information
Overview
Dynatrace ships as a plugin for the Claude Code CLI, and a single install connects the Claude Code agent to your Dynatrace environment through the Model Context Protocol server while loading 30 Dynatrace skills alongside it, so the agent gets live access to your production data together with the expertise to query it correctly.
Main capabilities include:
  • One install covers both halves of the problem: the MCP server gives the agent access to your live environment, while the 30 bundled skills carry the knowledge of how Dynatrace is organized so that queries land on fields that actually exist. Skills load only when a task calls for them, so installing all 30 does not crowd the context window.
  • The bundled skills include dt-dql-essentials for DQL syntax and query patterns, dt-app-dashboards and dt-app-notebooks for building platform assets, and dt-alerting for anomaly detector setup. These are the same skills released as Dynatrace for AI, now packaged for a single install.
  • Claude Code becomes another surface for the conversational analysis you already run in Dynatrace Assist, so a question asked in the terminal reaches the same data through the same MCP server.
  • Root cause comes from deterministic causal analysis over your Smartscape topology, so the agent explains a cause instead of reporting a correlation, and it pulls the related logs, metrics, traces, and CPU and memory profiling data into the session alongside it.
  • dtctl, the open source CLI for the Dynatrace platform, runs next to the MCP server, so you can manage dashboards, trigger workflows, and execute DQL from the same terminal.
Use cases
  • Debug a failing service without leaving the terminal: ask in plain language why a service started returning 5xx errors after your last deploy, narrow by impact, filter to the service, and ask for remediation suggestions, all without writing a line of DQL.
  • Answer exposure questions against production: ask whether you are vulnerable to a specific CVE and get the answer measured against the workloads actually running in your environment rather than against a dependency manifest.
  • Investigate incidents in context: root cause for a problem ID, log patterns on a Kubernetes workload, service-to-service dependencies, and the real user impact of a regression you shipped.
  • Optimize and tune with evidence: find oversized hosts, surface database calls that are slow at p99, and check forecast headroom before you scale.
Get started
Install the plugin
Open a terminal and run claude plugin install dynatrace@claude-plugins-official. The plugin is also surfaced automatically from the Anthropic marketplace on first launch of the Claude Code CLI. Configure your environment and token as described in the documentation.
Note: some skills (those that perform write operations such as managing dashboards, triggering workflows, or executing DQL) require dtctl to be installed alongside the plugin.
Try it on a failing service
  • Ask why the service is failing, in plain language, from the repository you are working in.
  • The agent pulls the root cause into the session along with the related logs, metrics, traces, and CPU and memory profiling data from your live environment.
  • Narrow by impact, filter to the service, and ask for remediation suggestions.
  • Fix the code without leaving the terminal.
Details
A single Claude Code plugin can ship MCP servers, agent skills, commands, and hooks together, and the Dynatrace plugin carries one MCP server and 30 skills.
Consumption is priced on data rather than per user, so onboarding a second or a fiftieth developer into this workflow does not change what you are billed.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Claude Code CLI
AI Skills and MCP Tools logo
Dynatrace tools and skills for the AI agents you run in any MCP client.
Claude Code Agent monitoring logo
Monitor your Claude Code coding agents with OTel.
Cursor (MCP) logo
Cursor (MCP)
Investigate production issues from Cursor with one plugin install.
Dynatrace Assist logo
Dynatrace Assist
Dynatrace MCP Server logo
Local MCP Server logo
Local MCP Server
[DEPRECATED] Run an MCP Server locally as a playground or to customize modules.
More resources
Dynatrace agentic ecosystem: Drive real outcomes, not AI pilots
Real agentic ecosystem use cases for developers, SREs, and IT Ops engineers you can implement today
Read more
Dynatrace MCP Server: Empower your AI assistants to interact with Dynatrace and access live production insights
Get real-time insights from your digital systems right inside your processes
Read more
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
