Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Chronic Problem Pattern Advisor (Agentic Workflow)Chronic Problem Pattern Advisor (Agentic Workflow)
Ranks the problems costing the most downtime and says what to fix.
Technology
Free trialDocumentation
Tells you what to fix and what to tune.
  • Product information
Overview
The agent ranks 30 days of problem signatures by accumulated downtime, and tells you which to fix and which to tune. It is a workflow template for the Optimize and Tune use case of Agentic Operations, where analysis runs on a schedule and reaches the person who can act on it.
  • FIX, TUNE or SUPPRESS. Every recommendation is labelled, each with the evidence that would confirm the cause before you act.
  • Flapping separated from real impact. Detection uses occurrences per active day against median downtime.
  • Downtime added up. No more living with a signature that has fired 300 times because nobody added up what it costs.
Use cases
  • Find the problem signature that costs the most downtime over 30 days.
  • Tell a threshold set too tight from a defect that keeps recurring.
  • Review the result with the owner of the alert configuration.
Get started
  1. Enable Dynatrace Intelligence for Workflows and the generative and agentic AI functionality in your environment.
  2. Get the workflow template from the community examples on GitHub, import it in Workflows and add the recipients.
  3. Run it once from the editor, then activate it.
The agent runs inside the permissions of its operator, and every execution is recorded.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Chronic Problem Pattern Advisor (Agentic Workflow)
Agentic Reporting logo
Agentic Reporting
Get summaries on what matters, with trends against the past.
Alert Reduction (Agentic Workflow) logo
Weekly report that pinpoints noisy alert configurations causing alert fatigue.
Dynatrace Intelligence for Workflows logo
Add agentic AI, prompts and built-in analysis to your workflows.
Dynatrace Hub
All (953)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
