Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
VS Code Copilot Chat MonitoringVS Code Copilot Chat Monitoring
Monitor VS Code Copilot Chat agents, tokens, and cost with native OTel.
Technology
Free trialDocumentation
Trace-level debug view showing agentic span hierarchy, tool calls, prompt and response content for a single AI agent run.Prompts stream showing Agent and LLM interactions with model version, token count, and prompt and response content.AI Observability Explorer showing VS Code Copilot Chat models, agents, token usage, and cost.
  • Product information
Overview
GitHub Copilot Chat in VS Code ships a first-party OpenTelemetry exporter that sends traces, metrics, and OTel events for every agent invocation, LLM call, tool run, and hook. It emits OpenTelemetry GenAI semantic conventions (gen_ai.*) directly, alongside Copilot-specific github.copilot.* attributes.
Dynatrace ingests this telemetry over OTLP with no extension, plugin, or code changes. Point VS Code at your Dynatrace OTLP endpoint and Copilot Chat activity appears in the AI Observability app: models, agents, token usage, cost, and tool calls across your developer fleet.
Use cases
Understand Copilot usage and cost across teams
  • Track token consumption with gen_ai.usage.input_tokens and gen_ai.usage.output_tokens, broken down by gen_ai.request.model.
  • Attribute cost and adoption to teams and environments using resource attributes such as service.namespace and deployment.environment.name.
Trace agent sessions end to end
  • Follow invoke_agent, chat, execute_tool, and execute_hook spans for every Copilot Chat agent turn.
  • Group interactions into conversations with gen_ai.conversation.id and identify which tools (gen_ai.tool.name) agents call most.
Detect errors and slow responses
  • Pinpoint failed LLM calls and tool executions with error.type.
  • Monitor gen_ai.client.operation.duration to spot latency regressions by model or provider.
Govern telemetry centrally
  • Roll out the exporter through Copilot managed settings (MDM, GitHub organization or enterprise settings, or managed-settings.json).
  • Keep prompt and response content capture disabled by default; enable it only where your organization has approved it.
Get started
  1. Create a Dynatrace API token with the openTelemetryTrace.ingest, metrics.ingest, and logs.ingest scopes.
  2. Set COPILOT_OTEL_ENABLED=true, point OTEL_EXPORTER_OTLP_ENDPOINT at https://<environment-id>.live.dynatrace.com/api/v2/otlp, use the http/protobuf protocol, and set OTEL_EXPORTER_OTLP_METRICS_TEMPORALITY_PREFERENCE=delta.
  3. Launch VS Code from that shell, or configure the same options under github.copilot.chat.otel.* in user or managed settings.
For the full setup, see the VS Code Copilot Chat example on GitHub. Once data arrives, open the AI Observability app to explore models, agents, prompts, and traces.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
