Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Vinyl CacheVinyl Cache
Vinyl Cache
Vinyl Cache
Monitor the statistics of your Vinyl Cache instances.
Extension
Free trial
Platform Overview DashboardClassic Overview DashboardInstance Overview
  • Product information
  • Release notes
Overview
Monitor the statistics of Vinyl Cache instances
Use cases
  • Monitor the health and state of Vinyl cache instances
  • Detect and alert on anomalous behavior
  • Understand the load and operational performance of the cache
Get started
For more information on the installation and configuration, please see Vinyl Cache extension in the Dynatrace Documentation.
Details
Compatibility information
Vinyl v. 9.0.0+
Dynatrace
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
In usevinyl.cache.mempool.liveIn useCount
In Poolvinyl.cache.mempool.poolIn PoolCount
Size requestedvinyl.cache.mempool.sz_wantedSize requestedByte
Size allocatedvinyl.cache.mempool.sz_actualSize allocatedByte
Allocationsvinyl.cache.mempool.allocs.countAllocationsCount
Freesvinyl.cache.mempool.frees.countFreesCount
Recycled from poolvinyl.cache.mempool.recycle.countRecycled from poolCount
Timed out from poolvinyl.cache.mempool.timeout.countTimed out from poolCount
Too small to recyclevinyl.cache.mempool.toosmall.countToo small to recycleCount
Too many for poolvinyl.cache.mempool.surplus.countToo many for poolCount
Pool ran dryvinyl.cache.mempool.randry.countPool ran dryCount
Created locksvinyl.cache.lck.creat.countCreated locksCount
Destroyed locksvinyl.cache.lck.destroy.countDestroyed locksCount
Lock Operationsvinyl.cache.lck.locks.countLock OperationsCount
Contended lock operationsvinyl.cache.lck.dbg_busy.countIf the lck debug bit is set: Lock operations which returned EBUSY on the first locking attempt. If the lck debug bit is unset, this counter will never be incremented even if lock operations are contended.Count
Contended trylock operationsvinyl.cache.lck.dbg_try_fail.countIf the lck debug bit is set: Trylock operations which returned EBUSY. If the lck debug bit is unset, this counter will never be incremented even if lock operations are contended.Count
Happy health probesvinyl.cache.vbe.happyRepresents the last probe results as a bitmap. Happy probes are bits set to 1, and the unhappy ones are set to 0. The highest bits represent the oldest probes.Unspecified
Request header bytesvinyl.cache.vbe.bereq_hdrbytes.countTotal backend request header bytes sentByte
Request body bytesvinyl.cache.vbe.bereq_bodybytes.countTotal backend request body bytes sentByte
Response header bytesvinyl.cache.vbe.beresp_hdrbytes.countTotal backend response header bytes receivedByte
Response body bytesvinyl.cache.vbe.beresp_bodybytes.countTotal backend response body bytes receivedByte
Pipe request header bytesvinyl.cache.vbe.pipe_hdrbytes.countTotal request bytes sent for piped sessionsByte
Piped bytes to backendvinyl.cache.vbe.pipe_out.countTotal number of bytes forwarded to backend in pipe sessionsByte
Piped bytes from backendvinyl.cache.vbe.pipe_in.countTotal number of bytes forwarded from backend in pipe sessionsByte
Concurrent connections usedvinyl.cache.vbe.connThe number of currently used connections to the backend. This number is always less or equal to the number of connections to the backend (as, for example shown as ESTABLISHED for TCP connections in netstat) due to connection pooling.Count
Backend requests sentvinyl.cache.vbe.req.countBackend requests sentCount
Fetches not attempted due to backend being unhealthyvinyl.cache.vbe.unhealthy.countFetches not attempted due to backend being unhealthyCount
Fetches not attempted due to backend being busyvinyl.cache.vbe.busy.countNumber of times the max_connections limit was reached .. === Anything below is actually per VCP entry, but collected per === backend for simplicityCount
Connections failedvinyl.cache.vbe.fail.countCounter of failed opens. Detailed reasons are given in the fail_* counters (DIAG level) and in the log under the FetchError tag. This counter is the sum of all detailed fail_* counters. All fail_* counters may be slightly inaccurate for efficiency.Count
Connections failed with EACCES or EPERMvinyl.cache.vbe.fail_eacces.countConnections failed with EACCES or EPERMCount
Connections failed with EADDRNOTAVAILvinyl.cache.vbe.fail_eaddrnotavail.countConnections failed with EADDRNOTAVAILCount
Connections failed with ECONNREFUSEDvinyl.cache.vbe.fail_econnrefused.countConnections failed with ECONNREFUSEDCount
Connections failed with ENETUNREACHvinyl.cache.vbe.fail_enetunreach.countConnections failed with ENETUNREACHCount
Connections failed ETIMEDOUTvinyl.cache.vbe.fail_etimedout.countConnections failed ETIMEDOUTCount
Connections failed for other reasonvinyl.cache.vbe.fail_other.countConnections failed for other reasonCount
Connection opens not attemptedvinyl.cache.vbe.helddown.countConnections not attempted during the backend_local_error_holddown or backend_remote_error_holddown interval after a fundamental connection issue.Count
Management process uptimevinyl.cache.mgt.uptime.countUptime in seconds of the management processSecond
Child process startedvinyl.cache.mgt.child_start.countNumber of times the child process has been startedCount
Child process normal exitvinyl.cache.mgt.child_exit.countNumber of times the child process has been cleanly stoppedCount
Child process unexpected exitvinyl.cache.mgt.child_stop.countNumber of times the child process has exited with an unexpected return codeCount
Child process died (signal)vinyl.cache.mgt.child_died.countNumber of times the child process has died due to signalsCount
Child process core dumpedvinyl.cache.mgt.child_dump.countNumber of times the child process has produced core dumpsCount
Child process panicvinyl.cache.mgt.child_panic.countNumber of times the management process has caught a child panicCount
Return codevinyl.cache.returncodeReturn code of the vinylstat commandUnspecified
Allocator requestsvinyl.cache.smf.c_req.countNumber of times the storage has been asked to provide a storage segment.Count
Allocator failuresvinyl.cache.smf.c_fail.countNumber of times the storage has failed to provide a storage segment.Count
Bytes allocatedvinyl.cache.smf.c_bytes.countNumber of total bytes allocated by this storage.Byte
Bytes freedvinyl.cache.smf.c_freed.countNumber of total bytes returned to this storage.Byte
Allocations outstandingvinyl.cache.smf.g_allocNumber of storage allocations outstanding.Count
Bytes outstandingvinyl.cache.smf.g_bytesNumber of bytes allocated from the storage.Byte
Bytes availablevinyl.cache.smf.g_spaceNumber of bytes left in the storage.Byte
N struct smfvinyl.cache.smf.g_smfN struct smfCount
N small free smfvinyl.cache.smf.g_smf_fragN small free smfCount
N large free smfvinyl.cache.smf.g_smf_largeN large free smfCount
Allocator requestsvinyl.cache.smu.c_req.countNumber of times the storage has been asked to provide a storage segment.Count
Allocator failuresvinyl.cache.smu.c_fail.countNumber of times the storage has failed to provide a storage segment.Count
Bytes allocatedvinyl.cache.smu.c_bytes.countNumber of total bytes allocated by this storage.Byte
Bytes freedvinyl.cache.smu.c_freed.countNumber of total bytes returned to this storage.Byte
Allocations outstandingvinyl.cache.smu.g_allocNumber of storage allocations outstanding.Count
Bytes outstandingvinyl.cache.smu.g_bytesNumber of bytes allocated from the storage.Byte
Bytes availablevinyl.cache.smu.g_spaceNumber of bytes left in the storage.Byte
Allocator requestsvinyl.cache.sma.c_req.countNumber of times the storage has been asked to provide a storage segment.Count
Allocator failuresvinyl.cache.sma.c_fail.countNumber of times the storage has failed to provide a storage segment.Count
Bytes allocatedvinyl.cache.sma.c_bytes.countNumber of total bytes allocated by this storage.Byte
Bytes freedvinyl.cache.sma.c_freed.countNumber of total bytes returned to this storage.Byte
Allocations outstandingvinyl.cache.sma.g_allocNumber of storage allocations outstanding.Count
Bytes outstandingvinyl.cache.sma.g_bytesNumber of bytes allocated from the storage.Byte
Bytes availablevinyl.cache.sma.g_spaceNumber of bytes left in the storage.Byte
stat summ operationsvinyl.cache.main.summs.countNumber of times per-thread statistics were summed into the global counters.Count
Child process uptimevinyl.cache.main.uptime.countHow long the child process has been running.Second
Sessions acceptedvinyl.cache.main.sess_conn.countCount of sessions successfully acceptedCount
Session accept failuresvinyl.cache.main.sess_fail.countCount of failures to accept TCP connection. This counter is the sum of the sess_fail_* counters, which give more detailed information.Count
Session accept failures: connection abortedvinyl.cache.main.sess_fail_econnaborted.countDetailed reason for sess_fail: Connection aborted by the client, usually harmless.Count
Session accept failures: interrupted system callvinyl.cache.main.sess_fail_eintr.countDetailed reason for sess_fail: The accept() call was interrupted, usually harmlessCount
Session accept failures: too many open filesvinyl.cache.main.sess_fail_emfile.countDetailed reason for sess_fail: No file descriptor was available. Consider raising RLIMIT_NOFILE (see ulimit -n).Count
Session accept failures: bad file descriptorvinyl.cache.main.sess_fail_ebadf.countDetailed reason for sess_fail: The listen socket file descriptor was invalid. Should never happen.Count
Session accept failures: not enough memoryvinyl.cache.main.sess_fail_enomem.countDetailed reason for sess_fail: Most likely insufficient socket buffer memory. Should never happenCount
Session accept failures: othervinyl.cache.main.sess_fail_other.countDetailed reason for sess_fail: neither of the above, see SessError log (vinyllog -g raw -i SessError).Count
Client requests received, subject to 400 errorsvinyl.cache.main.client_req_400.count400 means we couldn't make sense of the request, it was malformed in some drastic way.Count
Client requests received, subject to 417 errorsvinyl.cache.main.client_req_417.count417 means that something went wrong with an Expect: header.Count
Good client requests receivedvinyl.cache.main.client_req.countThe count of parseable client requests seen.Count
ESI subrequestsvinyl.cache.main.esi_req.countNumber of ESI subrequests made.Count
Cache hitsvinyl.cache.main.cache_hit.countCount of cache hits. A cache hit indicates that an object has been delivered to a client without fetching it from a backend server.Count
Cache grace hitsvinyl.cache.main.cache_hit_grace.countCount of cache hits with grace. A cache hit with grace is a cache hit where the object is expired. Note that such hits are also included in the cache_hit counter.Count
Cache hits for pass.vinyl.cache.main.cache_hitpass.countCount of hits for pass. A cache hit for pass indicates that Vinyl is going to pass the request to the backend and this decision has been cached in it self. This counts how many times the cached decision is being used.Count
Cache hits for miss.vinyl.cache.main.cache_hitmiss.countCount of hits for miss. A cache hit for miss indicates that Vinyl is going to proceed as for a cache miss without request coalescing, and this decision has been cached. This counts how many times the cached decision is being used.Count
Cache missesvinyl.cache.main.cache_miss.countCount of misses. A cache miss indicates the object was fetched from the backend before delivering it to the client.Count
Uncacheable backend responsesvinyl.cache.main.beresp_uncacheable.countCount of backend responses considered uncacheable.Count
Shortlived objectsvinyl.cache.main.beresp_shortlived.countCount of objects created with ttl+grace+keep shorter than the 'shortlived' runtime parameter.Count
Backend conn. successvinyl.cache.main.backend_conn.countHow many backend connections have successfully been established.Count
Backend conn. not attemptedvinyl.cache.main.backend_unhealthy.countBackend conn. not attemptedCount
Backend conn. too manyvinyl.cache.main.backend_busy.countBackend conn. too manyCount
Backend conn. failuresvinyl.cache.main.backend_fail.countBackend conn. failuresCount
Backend conn. reusesvinyl.cache.main.backend_reuse.countCount of backend connection reuses. This counter is increased whenever we reuse a recycled connection.Count
Backend conn. recyclesvinyl.cache.main.backend_recycle.countCount of backend connection recycles. This counter is increased whenever we have a keep-alive connection that is put back into the pool of connections. It has not yet been used, but it might be, unless the backend closes it.Count
Backend conn. retryvinyl.cache.main.backend_retry.countBackend conn. retryCount
Fetch no body (HEAD)vinyl.cache.main.fetch_head.countberesp with no body because the request is HEAD.Count
Fetch with Lengthvinyl.cache.main.fetch_length.countberesp.body with Content-Length.Count
Fetch chunkedvinyl.cache.main.fetch_chunked.countberesp.body with Chunked.Count
Fetch EOFvinyl.cache.main.fetch_eof.countberesp.body with EOF.Count
Fetch bad T-Evinyl.cache.main.fetch_bad.countberesp.body length/fetch could not be determined.Count
Fetch no bodyvinyl.cache.main.fetch_none.countberesp.body emptyCount
Fetch no body (1xx)vinyl.cache.main.fetch_1xx.countberesp with no body because of 1XX response.Count
Fetch no body (204)vinyl.cache.main.fetch_204.countberesp with no body because of 204 response.Count
Fetch no body (304)vinyl.cache.main.fetch_304.countberesp with no body because of 304 response.Count
Fetch failed (all causes)vinyl.cache.main.fetch_failed.countberesp fetch failed.Count
Background fetch failed (no thread)vinyl.cache.main.bgfetch_no_thread.countA bgfetch triggered by a grace hit failed, no thread available.Count
Number of thread poolsvinyl.cache.main.poolsNumber of thread pools. See also parameter thread_pools. NB: Presently pools cannot be removed once created.Count
Total number of threadsvinyl.cache.main.threadsNumber of threads in all pools. See also parameters thread_pools, thread_pool_min and thread_pool_max.Count
Threads hit maxvinyl.cache.main.threads_limited.countNumber of times more threads were needed, but limit was reached in a thread pool. See also parameter thread_pool_max.Count
Threads createdvinyl.cache.main.threads_created.countTotal number of threads created in all pools.Count
Threads destroyedvinyl.cache.main.threads_destroyed.countTotal number of threads destroyed in all pools.Count
Thread creation failedvinyl.cache.main.threads_failed.countNumber of times creating a thread failed. See VSL::Debug for diagnostics. See also parameter thread_fail_delay.Count
Length of session queuevinyl.cache.main.thread_queue_lenLength of session queue waiting for threads. NB: Only updates once per second. See also parameter thread_queue_limit.Count
Number of requests sent to sleep on busy objhdrvinyl.cache.main.busy_sleep.countNumber of requests sent to sleep without a worker thread because they found a busy object.Count
Number of requests woken after sleep on busy objhdrvinyl.cache.main.busy_wakeup.countNumber of requests taken off the busy object sleep list and rescheduled.Count
Number of requests killed after sleep on busy objhdrvinyl.cache.main.busy_killed.countNumber of requests killed from the busy object sleep list due to lack of resources.Count
Sessions queued for threadvinyl.cache.main.sess_queued.countNumber of times session was queued waiting for a thread. See also parameter thread_queue_limit.Count
Sessions dropped for threadvinyl.cache.main.sess_dropped.countNumber of times an HTTP/1 session was dropped because the queue was too long already. See also parameter thread_queue_limit.Count
Requests droppedvinyl.cache.main.req_dropped.countNumber of times an HTTP/2 stream was refused because the queue was too long already. See also parameter thread_queue_limit.Count
object structs madevinyl.cache.main.n_objectApproximate number of HTTP objects (headers + body, if present) in the cache.Count
unresurrected objectsvinyl.cache.main.n_vampireobjectNumber of unresurrected objectsCount
objectcore structs madevinyl.cache.main.n_objectcoreApproximate number of object metadata elements in the cache. Each object needs an objectcore, extra objectcores are for hit-for-miss, hit-for-pass and busy objects.Count
objecthead structs madevinyl.cache.main.n_objectheadApproximate number of different hash entries in the cache.Count
Number of backendsvinyl.cache.main.n_backendNumber of backends known to us.Count
Number of expired objectsvinyl.cache.main.n_expired.countNumber of objects that expired from cache because of old age.Count
Number of LRU nuked objectsvinyl.cache.main.n_lru_nuked.countHow many objects have been forcefully evicted from storage to make room for a new object.Count
Number of LRU moved objectsvinyl.cache.main.n_lru_moved.countNumber of move operations done on the LRU list.Count
Reached nuke_limitvinyl.cache.main.n_lru_limited.countNumber of times more storage space were needed, but limit was reached in a nuke_limit. See also parameter nuke_limit.Count
HTTP header overflowsvinyl.cache.main.losthdr.countHTTP header overflowsCount
Total sessions seenvinyl.cache.main.s_sess.countTotal sessions seenCount
Number of ongoing pipe sessionsvinyl.cache.main.n_pipeNumber of ongoing pipe sessionsCount
Pipes hit pipe_sess_maxvinyl.cache.main.pipe_limited.countNumber of times more pipes were needed, but the limit was reached. See also parameter pipe_sess_max.Count
Total pipe sessions seenvinyl.cache.main.s_pipe.countTotal pipe sessions seenCount
Total pass-ed requests seenvinyl.cache.main.s_pass.countTotal pass-ed requests seenCount
Total backend fetches initiatedvinyl.cache.main.s_fetch.countTotal backend fetches initiated, including background fetches.Count
Total backend background fetches initiatedvinyl.cache.main.s_bgfetch.countTotal backend background fetches initiatedCount
Total synthetic responses madevinyl.cache.main.s_synth.countTotal synthetic responses madeCount
Request header bytesvinyl.cache.main.s_req_hdrbytes.countTotal request header bytes receivedByte
Request body bytesvinyl.cache.main.s_req_bodybytes.countTotal request body bytes receivedByte
Response header bytesvinyl.cache.main.s_resp_hdrbytes.countTotal response header bytes transmittedByte
Response body bytesvinyl.cache.main.s_resp_bodybytes.countTotal response body bytes transmittedByte
Pipe request header bytesvinyl.cache.main.s_pipe_hdrbytes.countTotal request bytes received for piped sessionsByte
Piped bytes from clientvinyl.cache.main.s_pipe_in.countTotal number of bytes forwarded from clients in pipe sessionsByte
Piped bytes to clientvinyl.cache.main.s_pipe_out.countTotal number of bytes forwarded to clients in pipe sessionsByte
Session Closedvinyl.cache.main.sess_closed.countSession ClosedCount
Session Closed with errorvinyl.cache.main.sess_closed_err.countTotal number of sessions closed with errors. See sc_* diag counters for detailed breakdownCount
Session Read Aheadvinyl.cache.main.sess_readahead.countSession Read AheadCount
Session herdvinyl.cache.main.sess_herd.countNumber of times the timeout_linger triggeredCount
Session OK REM_CLOSEvinyl.cache.main.sc_rem_close.countNumber of session closes with REM_CLOSE (Client Closed)Count
Session OK REQ_CLOSEvinyl.cache.main.sc_req_close.countNumber of session closes with REQ_CLOSE (Client requested close)Count
Session Err REQ_HTTP10vinyl.cache.main.sc_req_http10.countNumber of session closes with Error REQ_HTTP10 (Proto < HTTP/1.1)Count
Session Err RX_BADvinyl.cache.main.sc_rx_bad.countNumber of session closes with Error RX_BAD (Received bad req/resp)Count
Session Err RX_BODYvinyl.cache.main.sc_rx_body.countNumber of session closes with Error RX_BODY (Failure receiving req.body)Count
Session Err RX_JUNKvinyl.cache.main.sc_rx_junk.countNumber of session closes with Error RX_JUNK (Received junk data)Count
Session Err RX_OVERFLOWvinyl.cache.main.sc_rx_overflow.countNumber of session closes with Error RX_OVERFLOW (Received buffer overflow)Count
Session Err RX_TIMEOUTvinyl.cache.main.sc_rx_timeout.countNumber of session closes with Error RX_TIMEOUT (Receive timeout)Count
Session Err RX_CLOSE_IDLEvinyl.cache.main.sc_rx_close_idle.countNumber of session closes with Error RX_CLOSE_IDLE: timeout_idle has been exceeded while waiting for a client request.Count
Session OK TX_PIPEvinyl.cache.main.sc_tx_pipe.countNumber of session closes with TX_PIPE (Piped transaction)Count
Session Err TX_ERRORvinyl.cache.main.sc_tx_error.countNumber of session closes with Error TX_ERROR (Error transaction)Count
Session OK TX_EOFvinyl.cache.main.sc_tx_eof.countNumber of session closes with TX_EOF (EOF transmission)Count
Session OK RESP_CLOSEvinyl.cache.main.sc_resp_close.countNumber of session closes with RESP_CLOSE (Backend/VCL requested close)Count
Session Err OVERLOADvinyl.cache.main.sc_overload.countNumber of session closes with Error OVERLOAD (Out of some resource)Count
Session Err PIPE_OVERFLOWvinyl.cache.main.sc_pipe_overflow.countNumber of session closes with Error PIPE_OVERFLOW (Session pipe overflow)Count
Session Err RANGE_SHORTvinyl.cache.main.sc_range_short.countNumber of session closes with Error RANGE_SHORT (Insufficient data for range)Count
Session Err REQ_HTTP20vinyl.cache.main.sc_req_http20.countNumber of session closes with Error REQ_HTTP20 (HTTP2 not accepted)Count
Session Err VCL_FAILUREvinyl.cache.main.sc_vcl_failure.countNumber of session closes with Error VCL_FAILURE (VCL failure)Count
Delivery failed due to insufficient workspace.vinyl.cache.main.client_resp_500.countNumber of times we failed a response due to running out of workspace memory during delivery.Count
workspace_backend overflowsvinyl.cache.main.ws_backend_overflow.countNumber of times we ran out of space in workspace_backend.Count
workspace_client overflowsvinyl.cache.main.ws_client_overflow.countNumber of times we ran out of space in workspace_client.Count
workspace_thread overflowsvinyl.cache.main.ws_thread_overflow.countNumber of times we ran out of space in workspace_thread.Count
workspace_session overflowsvinyl.cache.main.ws_session_overflow.countNumber of times we ran out of space in workspace_session.Count
SHM recordsvinyl.cache.main.shm_records.countNumber of log records written to the shared memory log.Count
SHM writesvinyl.cache.main.shm_writes.countNumber of individual writes to the shared memory log. A single write may batch multiple records for bufferred tasks.Count
SHM flushes due to overflowvinyl.cache.main.shm_flushes.countNumber of writes performed before the end of a bufferred task because adding a record to a batch would exceed vsl_buffer.Count
SHM lock contentionvinyl.cache.main.shm_cont.countNumber of times a write had to wait for the lock.Count
SHM cycles through VSL spacevinyl.cache.main.shm_cycles.countNumber of times a write of log records would reach past the end of the shared memory log, cycling back to the beginning.Count
SHM bytesvinyl.cache.main.shm_bytes.countNumber of bytes written to the shared memory log.Byte
Backend requests madevinyl.cache.main.backend_req.countBackend requests madeCount
Number of loaded VCLs in totalvinyl.cache.main.n_vclNumber of loaded VCLs in totalCount
Number of VCLs availablevinyl.cache.main.n_vcl_availNumber of VCLs availableCount
Number of discarded VCLsvinyl.cache.main.n_vcl_discardNumber of discarded VCLsCount
VCL failuresvinyl.cache.main.vcl_fail.countCount of failures which prevented VCL from completing.Count
Count of bansvinyl.cache.main.bansNumber of all bans in system, including bans superseded by newer bans and bans already checked by the ban-lurker.Count
Number of bans marked 'completed'vinyl.cache.main.bans_completedNumber of bans which are no longer active, either because they got checked by the ban-lurker or superseded by newer identical bans.Count
Number of bans using obj.*vinyl.cache.main.bans_objNumber of bans which use obj.* variables. These bans can possibly be washed by the ban-lurker.Count
Number of bans using req.*vinyl.cache.main.bans_reqNumber of bans which use req.* variables. These bans can not be washed by the ban-lurker.Count
Bans addedvinyl.cache.main.bans_added.countCounter of bans added to ban list.Count
Bans deletedvinyl.cache.main.bans_deleted.countCounter of bans deleted from ban list.Count
Bans tested against objects (lookup)vinyl.cache.main.bans_tested.countCount of how many bans and objects have been tested against each other during hash lookup.Count
Objects killed by bans (lookup)vinyl.cache.main.bans_obj_killed.countNumber of objects killed by bans during object lookup.Count
Bans tested against objects (lurker)vinyl.cache.main.bans_lurker_tested.countCount of how many bans and objects have been tested against each other by the ban-lurker.Count
Ban tests tested against objects (lookup)vinyl.cache.main.bans_tests_tested.countCount of how many tests and objects have been tested against each other during lookup. 'ban req.url == foo && req.http.host == bar' counts as one in 'bans_tested' and as two in 'bans_tests_tested'Count
Ban tests tested against objects (lurker)vinyl.cache.main.bans_lurker_tests_tested.countCount of how many tests and objects have been tested against each other by the ban-lurker. 'ban req.url == foo && req.http.host == bar' counts as one in 'bans_tested' and as two in 'bans_tests_tested'Count
Objects killed by bans (lurker)vinyl.cache.main.bans_lurker_obj_killed.countNumber of objects killed by the ban-lurker.Count
Objects killed by bans for cutoff (lurker)vinyl.cache.main.bans_lurker_obj_killed_cutoff.countNumber of objects killed by the ban-lurker to keep the number of bans below ban_cutoff.Count
Bans superseded by other bansvinyl.cache.main.bans_dups.countCount of bans replaced by later identical bans.Count
Lurker gave way for lookupvinyl.cache.main.bans_lurker_contention.countNumber of times the ban-lurker had to wait for lookups.Count
Bytes used by the persisted ban listsvinyl.cache.main.bans_persisted_bytesNumber of bytes used by the persisted ban lists.Byte
Extra bytes in persisted ban lists due to fragmentationvinyl.cache.main.bans_persisted_fragmentationNumber of extra bytes accumulated through dropped and completed bans in the persistent ban lists.Byte
Number of purge operations executedvinyl.cache.main.n_purges.countNumber of purge operations executedCount
Number of purged objectsvinyl.cache.main.n_obj_purged.countNumber of purged objectsCount
Number of objects mailed to expiry threadvinyl.cache.main.exp_mailed.countNumber of objects mailed to expiry thread for handling.Count
Number of objects received by expiry threadvinyl.cache.main.exp_received.countNumber of objects received by expiry thread for handling.Count
HCB Lookups without lockvinyl.cache.main.hcb_nolock.countHCB Lookups without lockCount
HCB Lookups with lockvinyl.cache.main.hcb_lock.countHCB Lookups with lockCount
HCB Insertsvinyl.cache.main.hcb_insert.countHCB InsertsCount
ESI parse errors (unlock)vinyl.cache.main.esi_errors.countESI parse errors (unlock)Count
ESI parse warnings (unlock)vinyl.cache.main.esi_warnings.countESI parse warnings (unlock)Count
Loaded VMODsvinyl.cache.main.vmodsLoaded VMODsCount
Gzip operationsvinyl.cache.main.n_gzip.countGzip operationsCount
Gunzip operationsvinyl.cache.main.n_gunzip.countGunzip operationsCount
Test gunzip operationsvinyl.cache.main.n_test_gunzip.countThose operations occur when Vinyl receives a compressed object from a backend. They are done to verify the gzip stream while it's inserted in storage.Count
Premature iovec flushesvinyl.cache.main.http1_iovs_flush.countNumber of additional writes performed on HTTP1 connections because the number of IO vectors was too small to submit all possible IO in one go. This number is configured through the http1_iovs parameter for client connections and implicitly defined by the amount of free workspace for backend connections.Count
Full version history
ReleaseDate
⚠️ Important Change:
  • This version requires a minimum Dynatrace version of 1.345.0
New in this release
  • This extension was relaunched after Varnish Cache forked into separate projects under separate names. Vinyl Cache is now a separately maintained open-source project.
  • More metrics for broader monitoring.
Initial release
Dynatrace Hub
All (953)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
