Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Service Graph Connector for DynatraceService Graph Connector for Dynatrace
Sync Dynatrace topology and service dependencies into ServiceNow CMDB.
Technology
Free trialDocumentation
Host insight to be sent to Service Graph ConnectorHost data initiated in Dynatrace and synced by Service Graph Connector
  • Product information
Overview
The Service Graph Connector for Dynatrace populates your ServiceNow CMDB with the entities and relationships Dynatrace discovers, replacing manual import processes with continuous, automated synchronization. As Dynatrace maps your infrastructure and application topology, the connector translates that data into the correct CI types and dependency records in ServiceNow.
The connector is leveraging all dependencies and relationship information from Smartscape, Dynatrace's real-time topology model.
What the connector syncs:
  • Hosts and processes with improved CI classification and reduced duplicate records across your environment.
  • Kubernetes entities: cluster, namespace, node, workload, pod, and service CIs created for each entity Dynatrace monitors.
  • Frontend entities: web application components appear in CMDB as configuration items.
  • Azure VM-to-server mappings: Azure VMs are linked to their correct server CIs, improving correlation accuracy and impact analysis.
Third-generation ITOM Workflows are compatible with the updated connector, supporting tag-based CI mapping so event notifications reach the right business service CIs in ServiceNow.
Use cases
  • Keep CMDB current with Dynatrace-discovered entities, so operations teams always work from an accurate service, host, and process map without manual imports.
  • Map Kubernetes cluster topology into ServiceNow so platform engineers and SREs can run impact analysis and incident routing against cluster, namespace, and workload CIs.
  • Reduce CMDB noise from container churn with duplicate prevention that stabilizes process and service CIs across pod restarts and redeployments.
  • Control which entities are sent to CDMB using Segments.
*Kubernetes Pods and Containers are automatically marked absent in CMDB.
Get started
The Service Graph Connector for Dynatrace is available from the ServiceNow Store. Install it in your ServiceNow instance, configure a connection to your Dynatrace environment, and define the scope of entities to synchronize using Grail tags or Segments.
  • For installation steps and configuration options of the new Service Graph Connector, see the ServiceNow product documentation
  • For ServiceNow Marketplace, see the ServiceNow Connector for Dynatrace SaaS
Details
  • Service Graph Connector for Dynatrace is currently in preview with limited functionality.
  • If you are on Dynatrace managed or classic SaaS, see the ServiceNow previous Service Graph Connector product documentation
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Service Graph Connector for Dynatrace
ServiceNow logo
ServiceNow
Create and manage ServiceNow incidents from Dynatrace Workflows.
ServiceNow Assist logo
ServiceNow Assist
AI‑driven alert clarity for Now Assist for IT Operations Management (ITOM).
Smartscape logo
Smartscape
Real-time dependency graph, accurately representing your digital system.
Smartscape logo
Smartscape
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
