Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
RabbitMQ (Management API)RabbitMQ (Management API)
Monitor your Clusters, Nodes, Virtual Hosts and Queues.
Extension
Free trialDocumentation
Built-in dashboard provides high level insights and links for easy navigationThe Node screen contains important metrics about a RabbitMQ Node. It also lets you drill down to the individual queues running on that node.Easily view all of your queues runningQueue details page
  • Product information
  • Release notes
Overview
This python extension connects to your RabbitMQ cluster via the Nodes Management API, to collect metrics for:
  • Clusters
  • Nodes
  • Virtual Hosts
  • Queues
These entities are then created in Dynatrace with relationships between them. The extension provides customized screens and metrics for each entity.
Use cases
With this extension you are able to monitor your RabbitMQ clusters directly via the Management API.
Get individual details about queues, virtual hosts, nodes and clusters.
Get started
For more information on the installation and configuration, please see RabbitMQ (Management API) extension in the Dynatrace Documentation.
Details
Compatibility information
Your RabbitMQ broker must have the management plugin enabled. This is enabled by default.
The extension has been tested on clusters running:
  • 3.13.7
  • 4.0.9
  • 4.1.0
And the user must have rights to see the queues and nodes.
This extensions requires EEC 1.313+
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Messages (Cluster)rabbitmq.cluster.messagesTotal messages (ready + unacknowledged) in the clusterCount
Messages Ready (Cluster)rabbitmq.cluster.messages_readyTotal messages ready in the clusterCount
Messages Unacknowledged (Cluster)rabbitmq.cluster.messages_unacknowledgedTotal messages unacknowledged in the clusterCount
Consumers (Cluster)rabbitmq.cluster.consumersNumber of consumersCount
Connections (Cluster)rabbitmq.cluster.connectionsNumber of connectionsCount
Queuesrabbitmq.cluster.queuesNumber of queuesCount
Exchangesrabbitmq.cluster.exchangesNumber of exchangesCount
Channelsrabbitmq.cluster.channelsNumber of channelsCount
Messages Acknowledged (Cluster)rabbitmq.cluster.ack.countTotal messages acknowledged in the clusterCount
Messages Unacknowledged (Cluster)rabbitmq.cluster.unack.countTotal messages unacknowledged in the clusterCount
Messages Delivered (Cluster)rabbitmq.cluster.deliver_get.countTotal messages delivered in the clusterCount
Messages Published (Cluster)rabbitmq.cluster.publish.countTotal messages published in the clusterCount
Messages (Virtual Host)rabbitmq.vhost.messagesSum of ready and unacknowledged messages for all queues in the Virtual Host.Count
Messages Ready (Virtual Host)rabbitmq.vhost.messages_readyNumber of messages ready to be delivered to clients for all queues in the Virtual Host.Count
Messages Unacknowledged (Virtual Host)rabbitmq.vhost.messages_unacknowledgedNumber of messages delivered to clients but not yet acknowledged for all queues in the Virtual Host.Count
Bytes Received (Virtual Host)rabbitmq.vhost.recv_oct.countTotal number of bytes received on the network for all queues in the Virtual Host.Byte
Bytes Sent (Virtual Host)rabbitmq.vhost.send_oct.countTotal number of bytes sent on the network for all queues in the Virtual Host.Byte
Messagesrabbitmq.queue.messagesSum of ready and unacknowledged messages (queue depth).Count
Messages Readyrabbitmq.queue.messages_readyNumber of messages ready to be delivered to clients.Count
Messages Unacknowledgedrabbitmq.queue.messages_unacknowledgedNumber of messages delivered to clients but not yet acknowledged.Count
Message Bytesrabbitmq.queue.message_bytesSum of the size of all message bodies in the queue. This does not include the message properties (including headers) or any overhead.Byte
Memoryrabbitmq.queue.memoryBytes of memory allocated by the runtime for the queue, including stack, heap and internal structures.Byte
Consumersrabbitmq.queue.consumersNumber of consumers.Count
Publishrabbitmq.queue.publish.countCount of messages published.Count
Redeliverrabbitmq.queue.redeliver.countCount of subset of messages in deliver_get which had the redelivered flag set.Count
Messages Deliveredrabbitmq.queue.messages_delivered.countMessages delivered to consumers.Count
Messages Delivered No Ackrabbitmq.queue.messages_deliver_no_ack.countCount of messages delivered in no-acknowledgement mode to consumers.Count
Messages Dropped Unroutablerabbitmq.queue.drop_unroutable.countCount of messages dropped as unroutable.Count
Messages Returned Unroutablerabbitmq.queue.return_unroutable.countCount of messages returned to the publisher as unroutable.Count
Memory Usedrabbitmq.node.mem_usedMemory used in bytes.Byte
Memory Limitrabbitmq.node.mem_limitPoint at which the memory alarm will go off.Byte
File Descriptors Usedrabbitmq.node.fd_usedUsed file descriptors.Count
File descriptors availablerabbitmq.node.fd_totalFile descriptors availableCount
Sockets Usedrabbitmq.node.sockets_usedFile descriptors used as sockets.Count
Sockets Availablerabbitmq.node.sockets_totalFile descriptors available to be used as sockets.Count
Disk Freerabbitmq.node.disk_freeDisk free space in bytes.Byte
Partitionsrabbitmq.node.partitionsNumber of network partitions this node is seeing.Count
Uptimerabbitmq.node.uptimeTime since the Erlang VM started, in milliseconds.MilliSecond
Garbage Collection Countrabbitmq.node.gc_num.countNumber of garbage collections.Count
Full version history
ReleaseDate
Version 3.2.2
  • The primary tags and primary fields configured on an endpoint are now attached as dimensions to every metric the extension reports (cluster, node, queue and virtual host).
  • Added a Properties tab, right after the overview tab, to the cluster, node, virtual host and queue detail screens.
Update the certifi dependency to address CVE-2026-111943
3.2.0
  • Updates to platform node inventory pages
3.1.0
Version 3.0.0
Adds Smartscape on Grail support.
This version introduces Smartscape on Grail support, with the following nodes and edges:
  • RABBITMQ_CLUSTER (was rabbitmq:cluster in the classic topology)
  • RABBITMQ_NODE (was rabbitmq:node in the classic topology)
    • runs_on RABBITMQ_CLUSTER
  • RABBITMQ_VHOST (was rabbitmq:vhost in the classic topology)
  • RABBITMQ_QUEUE (was rabbitmq:queue in the classic topology)
    • runs_on RABBITMQ_NODE
    • belongs_to RABBITMQ_VHOST
Notes
  • This feature is only relevant to SAAS customers.
  • This version requires a minimum Dynatrace version of 1.340 and a minimum ActiveGate/OneAgent version of 1.338.
  • You must have migrated OpenPipeline configurations to the Settings API, the extension can't be installed otherwise.
  • The existing classic entities still exist and are supported.
🐛 Bugs fixed in this version:
  • Fixed bug in which extension deployment failed due to missing Python module imports
  • New Platform/Gen3 dashboard bundled with extension
  • Enriched entities with dt.security_context attribute
  • Added support for gen3 charts/screens
Version 2.1.4
  • Fix an issue where a division by zero would occur when no total sockets metric was available
Version 2.1.3
  • Fix an issue where invalid characters like tabs were used on the virtual host name, creating invalid dimensions
Version 2.1.2
  • Fix an issue where queues with special characters like tabs in the name were not being ingested
Version 2.1.1
  • Fix an issue where certificates were validated even if the validate option was disabled.
Version 2.1.0
  • Allow the extension to run from the OneAgent
Note: Existing monitoring configurations must be recreated because of the schema change
Version 2.0.2
  • Add support for the credential vault
  • Add an option to ignore certificate validation
  • Add an option to provide the path to a custom certificate to validate the server ceritifcate
Version 2.0.1
  • Add the sourceEntityType for all metrics, allowing Management Zones to be created for the different entities
Version 2.0.0
Initial version with RabbitMQ Management API
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
