Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Outbound Connections SettingOutbound Connections Setting
Manage forwarding to private endpoints and restrict access to external hosts.
App
Free trialDocumentation
Manage connections to private endpoints using EdgeConnectConfigure the Outbound connection settings for App functions and ad-hoc functions.
  • Product information
  • Release notes
Overview
Securely connect and interact with your IT environment from within Dynatrace® apps or workflows, whether it is on running on-premises or a private cloud network. This enables you to e.g. access your private network's Jira instance from a workflow and create or update a Jira issue.
Use cases
  • create and manage outbound connections as external requests using allow lists
outbound connection
  • connect to private network endpoints using EdgeConnect
  • define which requests are forwarded to which EdgeConnect connection
  • perform health tests
  • Limit the accessibility of public endpoints from functions running in the Dynatrace JavaScript runtime, whether it's App functions (which build the backend of Dynatrace Apps) or Ad-hoc functions (used in Notebooks, Dashboards, Workflows or via API).
Get started
Outbound Connections Settings comes pre-installed with every Dynatrace environment and extends the capabilities of Settings, which can be found under "General - Environment management - External requests"
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
1.13.0
Minor Changes
  • Dependency updates
  • Toast messages displayed after changes were successfully saved
  • Documentation link displayed in table footer when there are no EdgeConnects configured
1.12.0
Minor Changes
  • Dependency updates.
1.11.1
Minor Changes
  • Move loading indicators for matching URLs and testing http requests into the respective button.
  • Ask user for confirmation if navigating away during modal opened
Patch Changes
  • render EdgeConnect details accordion no longer as surface to align to design draft
1.9.0
  • EdgeConnect configurations can be configured
  • New Verify-URL feature previews whether a URL is accessible given the current configurations
1.5.7
  • Number of host patterns is displayed above table showing host patterns
  • Host pattern property is required in add-on modal for adding a host pattern
1.5.5
Minor Changes
  • Display more striking warning concerning removal of host patterns when allowlist is disabled
  • Display breadcrumbs and button to browse history of configuration changes
1.4.0
Minor Changes
  • Add-on intent shows a better styled error message in the edge case where allowlist is disabled
  • Table interactions are disabled when users are missing the necessary permissions for writing the setting
1.3.2
Initial version
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
