Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Oracle DatabaseOracle Database
Oracle Database
Oracle Database
Observe, analyze and optimize the usage, health and performance of your database.
Extension
Free trialDocumentation
The Overview Dashboard is provided by the extension as an entry point to Oracle entities monitored across all configurations of the extension.For each of your monitored databases, get insights into SQL query execution hotspots by tracking the longest running queries.Backup monitoring gives you a complete history of backups as well as automated alerting in case of any backup failures.Database level monitoring allows you to dig into database-specific metrics like datafiles and tablespaces.
  • Product information
  • Release notes
Overview
Dynatrace automatically detects all applications and microservices deployed in your system and how your system uses Oracle Database.
Dynatrace diagnoses anomalies in real time with AI and pinpoints the root cause in slow-performing or erroneous SQL statements. Deep code-level insights combined with cloud-native database server monitoring help you ensure a robust production environment.
The Oracle Database extension complements the client-side database usage insights by providing server-side observability starting with availability and performance statistics, down to individual SQL statements and log insights.
Use cases
  • Understand all database dependencies of your applications, which database statements are executed, and their performance.
  • Improve the performance of your application by reducing or optimizing typical database patterns like the 1+N query problem
  • Understand the resource impact that your applications have on your database.
  • Understand the impact that resource shortages or other database issues have on your application by observing the database server itself.
  • Manage and analyze DB audit logs to spot invalid login attempts
  • Track the health and performance of Oracle Database servers (either standalone or multi-tenant)
  • Track the most time consuming queries performance
  • Speed up application-problem diagnosis when issues are caused by the database
Get started
For more information on the installation and configuration, please see Oracle Database extension in the Dynatrace Documentation.
Details
Compatibility information
The following Oracle versions are supported:
  • Oracle DB 12.2+
The following architectures are supported:
  • Oracle standalone servers
  • Oracle Multitenant (CDB/PDB)
    • Configure monitoring for CDB to detect all PDBs
  • Oracle AWS RDS
  • Oracle RAC
    • Configure monitoring for the SCAN listener to detect all instances and databases.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Cluster topologycom.dynatrace.extension.sql-oracle.cluster_topologyA state metric whose dimensions represent all Oracle clusters and their linked instances and hostsNotApplicable
Database topologycom.dynatrace.extension.sql-oracle.database_topologyA state metric whose dimensions represent all Oracle instances and their linked databasesNotApplicable
Instance statuscom.dynatrace.extension.sql-oracle.statusA state metric representing the details of the connected Oracle instance.State
Instance Uptimecom.dynatrace.extension.sql-oracle.uptimeThe uptime of the Oracle instance in seconds.Second
Database statuscom.dynatrace.extension.sql-oracle.db_statusA state metric representing details of the connected Oracle database.State
Sessions utilizationcom.dynatrace.extension.sql-oracle.limits.sessions_utilizationUtilization of sessions on the instance. This is a percentage of current utilization relative to the limit.Percent
Processes utilizationcom.dynatrace.extension.sql-oracle.limits.processes_utilizationUtilization of processes on the instance. This is a percentage of current utilization relative to the limit.Percent
Dataguard severe eventscom.dynatrace.extension.sql-oracle.dataguard.severeEventsCounts the number of fatal and severe Data guard events occurred in the last day. If this count is greater than 0, check its dimensions to take action for the specific events.Count
NOLOGGING activitycom.dynatrace.extension.sql-oracle.dataguard.nologgingActivityCounts the number of files which contain NOLOGGING activity in the last day. If the count is greater than 0 then the standby database is vulnerable; check the dimensions to find out which files must be refreshed on the standby.Count
Archive destination statuscom.dynatrace.extension.sql-oracle.dataguard.archiveDestErrStatusCounts the number of invalid or errored statuses of archive destinations. If the count is greater than 0, use the dimensions to understand the status and destination it refers to.Count
Seq. differencecom.dynatrace.extension.sql-oracle.dataguard.seqDifferenceTracks the difference in sequence number between the latest archived and applied redo log. Use this count along with the dimensions to identify gaps between the primary and archive destination.Count
Total sizecom.dynatrace.extension.sql-oracle.pdb-total_sizeShows the disk space (in bytes) used by the PDB, including both data and temp files.Byte
Block sizecom.dynatrace.extension.sql-oracle.pdb-block_sizeThe current block size for the PDBByte
Diagnostic sizecom.dynatrace.extension.sql-oracle.pdb-diagnostic_sizeShows the current disk space usage (in bytes) of the diagnostic traces generated in the PDB.Byte
Audit files sizecom.dynatrace.extension.sql-oracle.pdb-audit_files_sizeShows the current disk space usage (in bytes) by Unified Audit files (.bin format) in the current PDB.Byte
Max sizecom.dynatrace.extension.sql-oracle.pdb-max_sizeShows the maximum amount of disk space (in bytes) that can be used by data and temp files in the PDB. If the value is 0 then there is no limit.Byte
Max diagnostic sizecom.dynatrace.extension.sql-oracle.pdb-max_diagnostic_sizeShows the maximum amount of disk space (in bytes) that can be used by diagnostic traces generated in the PDB. If the value is 0 then there is no limit.Byte
Max audit sizecom.dynatrace.extension.sql-oracle.pdb-max_audit_sizeShows the maximum amount of disk space (in bytes) that can be used by Unified Audit files (.bin format) in the PDB. If the value is 0 then there is no limit.Byte
Active Sessionscom.dynatrace.extension.sql-oracle.sessions.activeActive sessions countCount
Blocked Sessionscom.dynatrace.extension.sql-oracle.sessions.blockedBlocked sessions countCount
Total sessionscom.dynatrace.extension.sql-oracle.sessions.allTotal sessions countCount
User callscom.dynatrace.extension.sql-oracle.sessions.userCalls.countTotal number of logins, parses, or execute callsCount
Deadlockscom.dynatrace.extension.sql-oracle.sessions.deadlocks.countTotal number deadlocksCount
Total sizecom.dynatrace.extension.sql-oracle.tablespaces.totalSpaceTotal size of tablespace, including extensibility. This covers both allocated an unallocated space as large as the tablespace can expand.Byte
Free spacecom.dynatrace.extension.sql-oracle.tablespaces.freeSpaceTotal free space available in the tablespace, in bytes. This includes space that is currently allocated and available for reuse and space that is currently unallocated.Byte
Used spacecom.dynatrace.extension.sql-oracle.tablespaces.usedSpaceTotal space in use within the tablespace, in bytes.Byte
Allocated spacecom.dynatrace.extension.sql-oracle.tablespaces.allocatedSpaceTotal space in use within the tablespace, in bytes.Byte
Tablespace usagecom.dynatrace.extension.sql-oracle.tablespaces.usageThe percentage of tablespace in use, relative to the total size (including extensibility).Percent
Instance pingcom.dynatrace.extension.sql-oracle.rac.instance_pingRepresents the current inter-instance ping of 8K messages as provided in GV$INSTANCE_PING.MicroSecond
-com.dynatrace.extension.sql-oracle.rac.interconnects--
Connection management timecom.dynatrace.extension.sql-oracle.queries.connectionManagement.countTime spent on performing session connect and disconnect callsMicroSecond
PL SQL exec timecom.dynatrace.extension.sql-oracle.queries.plSqlExec.countTime spent on running the PL/SQL interpreterMicroSecond
SQL exec timecom.dynatrace.extension.sql-oracle.queries.sqlExec.countTime spent on executing SQLMicroSecond
SQL parse timecom.dynatrace.extension.sql-oracle.queries.sqlParse.countTime spent on parsing SQLMicroSecond
DB Timecom.dynatrace.extension.sql-oracle.queries.dbTime.countTime spent on performing Database user-level callsMicroSecond
DB CPUcom.dynatrace.extension.sql-oracle.queries.cpuTime.countCPU time spent on performing database user-level callsMicroSecond
Free spacecom.dynatrace.extension.sql-oracle.asm.disk.free_mbFree disk space available on this Oracle ASM DiskMegaByte
Total spacecom.dynatrace.extension.sql-oracle.asm.disk.total_mbTotal disk space available on this Oracle ASM DiskMegaByte
Used spacecom.dynatrace.extension.sql-oracle.asm.disk.usagePercentage of disk space used on this Oracle ASM DiskPercent
Readscom.dynatrace.extension.sql-oracle.asm.disk.reads.countNumber of reads from this Oracle ASM DiskCount
Writescom.dynatrace.extension.sql-oracle.asm.disk.writes.countNumber of writes to this Oracle ASM DiskCount
Free spacecom.dynatrace.extension.sql-oracle.asm.disk_group.free_mbFree disk space available on this Oracle ASM Disk GroupMegaByte
Total spacecom.dynatrace.extension.sql-oracle.asm.disk_group.total_mbTotal disk space available on this Oracle ASM Disk GroupMegaByte
Used spacecom.dynatrace.extension.sql-oracle.asm.disk_group.usagePercentage of disk space used on this Oracle ASM Disk GroupPercent
PGA aggregate limitcom.dynatrace.extension.sql-oracle.memory.pga.size.pgaAggregateLimitLimit on the aggregate PGA memory consumed by the instanceByte
PGA aggregate targetcom.dynatrace.extension.sql-oracle.memory.pga.size.pgaAggregateTargetTarget aggregate PGA memory available to all server processes attached to the instanceByte
PGA memory usedcom.dynatrace.extension.sql-oracle.memory.pga.usedPGA memory consumed by work areasByte
Allocated PGAcom.dynatrace.extension.sql-oracle.memory.pga.allocatedCurrent amount of PGA memory allocated by the instanceByte
Shared pool freecom.dynatrace.extension.sql-oracle.memory.sga.cacheBuffer.sharedPoolFreeAmount of free system global area (SGA) memory available in shared poolPercent
Redo log space wait timecom.dynatrace.extension.sql-oracle.memory.sga.redoBuffer.redoLogSpaceWaitTime.countTotal elapsed time of waiting for redo log space requestMilliSecond
Redo size increasecom.dynatrace.extension.sql-oracle.memory.sga.redoBuffer.redoSizeIncrease.countTotal amount of redo generated in bytesByte
Redo write timecom.dynatrace.extension.sql-oracle.memory.sga.redoBuffer.redoWriteTime.countTotal elapsed time of the write from the redo log buffer to the current redo log fileMilliSecond
Logical readscom.dynatrace.extension.sql-oracle.memory.sessionLogicalReads.countThe sum of "db block gets" plus "consistent gets"Count
Physical readscom.dynatrace.extension.sql-oracle.memory.physicalReads.countTotal number of data blocks read from diskCount
Physical reads directcom.dynatrace.extension.sql-oracle.memory.physicalReadsDirect.countNumber of reads directly from disk, bypassing the buffer cacheCount
Sorts in memorycom.dynatrace.extension.sql-oracle.memory.memorySorts.countNumber of sort operations that were performed completely in memory and did not require any disk writesCount
Sorts on diskcom.dynatrace.extension.sql-oracle.memory.diskSorts.countNumber of sort operations that required at least one disk writeCount
DB Block gets from cachecom.dynatrace.extension.sql-oracle.memory.dbBlockGetsFromCache.countNumber of times a consistent read was requested for a block from the buffer cache.Count
Consistent gets from cachecom.dynatrace.extension.sql-oracle.memory.consistentGetsFromCache.countNumber of times a CURRENT block was requested from the buffer cache.Count
Physical reads into cachecom.dynatrace.extension.sql-oracle.memory.physicalReadsCache.countTotal number of data blocks read from disk into buffer cache.Count
Library cache hit ratiocom.dynatrace.extension.sql-oracle.memory.libraryCacheHitRatioLibrary cache hit ratioPercent
CPU corescom.dynatrace.extension.sql-oracle.cpu.coresNumber of CPU coresCount
Background CPU usage (per second)com.dynatrace.extension.sql-oracle.cpu.backgroundTotalCPU usage of background processes in centi seconds per secondUnspecified
Foreground CPU usage (per second)com.dynatrace.extension.sql-oracle.cpu.foregroundTotalCPU usage of foreground processes in centi seconds per secondUnspecified
Physical bytes readcom.dynatrace.extension.sql-oracle.io.bytesRead.countTotal size in bytes of disk reads by all database instance activity including application reads, backup, recovery, and other utilitiesByte
Physical bytes writtencom.dynatrace.extension.sql-oracle.io.bytesWritten.countTotal size in bytes of all disk writes for the database instance including application activity, backup, recovery, and other utilitiesByte
Total wait timecom.dynatrace.extension.sql-oracle.io.wait.countTotal time spent in all wait states except for Idle classMilliSecond
-com.dynatrace.extension.sql-oracle.datafile.max_parameter--
Datafile statuscom.dynatrace.extension.sql-oracle.datafile.statusState metric representing the status of Datafiles and Tempfiles across containers (database and any PDBs).NotApplicable
Datafile number of corrupted blockscom.dynatrace.extension.sql-oracle.datafile.corrupted_blocksMetric representing the number of corrupted blocks reported by V$DATABASE_BLOCK_CORRUPTION for each DatafileCount
Number of wait events by wait classcom.dynatrace.extension.sql-oracle.wait.countTotal number of waits by wait class, excluding 'Idle' eventsCount
Seconds waited by wait classcom.dynatrace.extension.sql-oracle.wait.time.countTotal amount of time waited by wait class, excluding 'Idle' eventsMicroSecond
FRA Usagecom.dynatrace.extension.sql-oracle.fra.usageThe percentage disk utilization in the fast recovery area.Percent
FRA limitcom.dynatrace.extension.sql-oracle.fra.limitMaximum amount of disk space (in bytes) that the database can use for the fast recovery area. This is the value specified in the DB_RECOVERY_FILE_DEST_SIZE initialization parameter.Byte
FRA usedcom.dynatrace.extension.sql-oracle.fra.usedAmount of disk space (in bytes) used by fast recovery area files created in current and all previous fast recovery areas. Changing fast recovery areas does not reset SPACE_USED to 0.Byte
FRA reclaimablecom.dynatrace.extension.sql-oracle.fra.reclaimableTotal amount of disk space (in bytes) that can be created by deleting obsolete, redundant, and other low priority files from the fast recovery areaByte
Input bytescom.dynatrace.extension.sql-oracle.backup-input_bytesSum of all input file sizes backed up.Byte
Output bytescom.dynatrace.extension.sql-oracle.backup-output_bytesOutput size of all pieces generated.Byte
Elapsed secondscom.dynatrace.extension.sql-oracle.backup-elapsed_secondsNumber of elapsed seconds.Second
Compression ratiocom.dynatrace.extension.sql-oracle.backup-compression_ratioCompression ratio.Percent
Input bytes per secondcom.dynatrace.extension.sql-oracle.backup-input_bytes_per_secondInput read-rate-per-second.BytePerSecond
Output bytes per secondcom.dynatrace.extension.sql-oracle.backup-output_bytes_per_secondOutput write-rate-per-second.BytePerSecond
Auto - backup countcom.dynatrace.extension.sql-oracle.backup-autobackup_count_numberNumber of autobackups performed by this job.Count
Backup statecom.dynatrace.extension.sql-oracle.backup.stateA state metric representing the details of a Backup Job.State
Time since last backupcom.dynatrace.extension.sql-oracle.backup.time_sinceThe time elapsed since the last backup completed successfully.Minute
Number of wait eventscom.dynatrace.extension.sql-oracle.wait.events.countTotal number of waits by wait event, excluding 'Idle' events. Only collects the top 20 most time consuming events.Count
Seconds waitedcom.dynatrace.extension.sql-oracle.wait.events.time.countTotal amount of time waited by wait event, excluding 'Idle' events. Only collects the top 20 most time consuming events.MicroSecond
Full version history
ReleaseDate
✨ New in this version:
  • Add a database-level com.dynatrace.extension.sql-oracle.datafile.max_parameter metric that contains the value of the DB_FILES database paramater. This metric, in combination with com.dynatrace.extension.sql-oracle.datafile.status, can be used to alert on when the number of datafiles is approaching the maximum.
🪲 Fixed in this version:
  • Fixed issue where execution plan collection would throw an error on RAC setups.
Note:
  • Requires a minDynatraceVersion (cluster) of 1.345.0 and a minEECVersion (ActiveGate) of 1.301.0 or later.
  • Alert templates have been optimized to work with New Smartscape.
  • Fixed health charts for Oracle nodes in the Infrastructure and Operations app.
🚀 Improved in this version:
  • Added container.name dimension to execution plan logs.
  • Added group.name dimension to ASM disk metrics.
  • Fixed issue where a relationship between Oracle RAC nodes and OneAgent hosts would sometimes not be properly established.
  • Fixed missing edges between DB_DATABASE_ORACLE and DB_INSTANCE_ORACLE for RAC setups.
  • Fixed issue where log.sql-oracle.top_n_queries.* would sometimes not be collected.
⚠️ Breaking changes:
⚠️ Possible breaking changes and warnings - PLEASE READ before upgrading to this version ⚠️:
  • This version requires a minimum Dynatrace version of 1.338.
  • This version includes a breaking change for 3rd gen environments:
    • With the inclusion of OpenPipeline pipelines, any logs emitted by this extension will be processed by a dedicated OpenPipeline pipeline instead of the classic pipeline. This means that classic rules will no longer be used on logs emitted by the extension. Please be sure to migrate any you still need to OpenPipeline rules.
    • Some field names are handled differently in OpenPipeline, e.g. capitalization. Please double-check any custom dashboards and alerts you have created for this extension.
    • Any dynamic pipelines that were configured to route metrics or logs coming from this extension will no longer be used as data will be statically routed to the extension-shipped pipeline.
    • Finally, you must opt-in to OpenPipeline configuration via Settings API – see documentation.
  • Smartscape 2.0 topology support.
  • Updated entity links in Platform dashboard to point to the Infrastructure and Operations app.
  • Entity creation rules now explicitly filter out null dimension values.
  • Added the following metrics to the memory feature set:
    • com.dynatrace.extension.sql-oracle.memory.consistentGetsFromCache.count
    • com.dynatrace.extension.sql-oracle.memory.dbBlockGetsFromCache.count
    • com.dynatrace.extension.sql-oracle.memory.physicalReadsCache.count
  • Updated the calculation for buffer cache hit ratio to reflect current Oracle documentation.
🪲Fixed in this version:
  • Fixed issue where RAC instance local IP address would not be properly reported on the right entity.
  • The relationship between OneAgent host and Oracle instances now supports RAC instances as well. For local IP discovery to work correctly, the extension needs access to the UTL_INADDR.get_host_address function. Please see the official documentation for more information on how to assign these additional permissions.
    ⚠️This feature is available under the RAC feature set. If you have this feature set enabled and start seeing permission error warnings in the extension logs after updating the extension to the latest version, there is no cause for concern. No data is being lost, simply update the permissions as described above to take advantage of the new feature, or disable the RAC feature set if it is not relevant for your use case.
  • Added feature set descriptions and recommendations.
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app.
For internal alignment reasons, versions 3.1.3 to 3.7.5 will no longer be available on the Hub for installation. For users currently on any of these versions there is no immediate need to take any action, as they will continue to work fine.
For users upgrading to the latest version from any of those versions, previous release notes are provided below:
Version 3.7.5
  • Server version is now correctly set as an entity attribute for the instance entity type.
  • Fixed issue where requesting an execution plan from the Databases app could result in a 405.
  • Fixed issue where tablespace content type dimension would sometimes split properly in the Data Explorer.
  • Fixed tablespace charts showing wrong values for large timeframes.
Version 3.7.1
  • The dt.security_context parameter is now propagated to all entities created by the extension. When definition entity permissions based on dt.security_context ensure you set the Grail security context destination property to dt.security_context
  • The dt.security_context is now a dimension of all the log. metrics created by the extension.
  • Fixed uptime metric chart in databases app not showing.
  • Fixed typo in the uptime metric name.
Version 3.6.2
  • Added a new metric com.dynatrace.extension.sql-oracle.uptime.
  • The instance unavailable alert now relies on the new uptime metric instead of the status metric.
  • Reworked top statement charts in the Databases app.
Version 3.5.0
  • Added an extra variable tablespace-filter which can be used to filter the tablespaces to be monitored.
  • Log data collected by the extension (top and blocking statements) now have the endpoint_metadata variable as an attribute.
  • Adjusted the way foreground and background CPU metrics are collected.
  • Fixed Instance entities not showing correctly in the databases list view.
Version 3.4.2
  • Fixed issue where backup data would be captured for too long in cases where the ActiveGate timezone did not match the database timezone.
Version 3.4.0
  • Added out-of-the-box Platform dashboard for Oracle DB monitoring. This dashboard can be found under Ready-made dashboards in the Dashboards app.
  • Added SAME_AS relationship between sql:com_dynatrace_extension_sql-oracle_instance and Oracle Listener PGI
  • Fixed com.dynatrace.extension.sql-oracle.io.bytesRead.count and com.dynatrace.extension.sql-oracle.io.bytesWritten.count being switched.
Version 3.3.4
  • Tablespace charts now show in the Databases app for RAC instances and as well as for non-RAC instances.
Version 3.3.3
  • Added default alert template for Data Guard gap monitoring.
  • The failed backup alert template now uses a 5/3/5 alerting strategy to better fit with the collected data.
  • The query under the asm (detailed) feature set runs with frequency heavy-query-interval. This fixes an issue where setting the heavy-query-timeout variable to more than 60s would cause this query to break.
    • ⚠️ When updating an existing configuration to the new version, the ASM disk metrics will now be collected every 5 minutes by default. Alerts may need adjustment. This does not apply to ASM disk group metrics. ⚠️
  • To prevent hitting dimension tuple limits, the following dimensions were removed from the metric com.dynatrace.extension.sql-oracle.dataguard.seqDifference:
    • primary.current.seq
    • primary.archived.seq
    • standby.applied.seq
  • Fixed issue where the ASM disk group name would sometimes not show on the Dynatrace ASM disk group entity.
Version 3.2.1
  • Sorting SQL statements in the Databases app would retrieve duplicate results
Version 3.2.0
  • Introduced two new monitoring configuration variables, query-interval and heavy-query-interval to control the extension's monitoring queries' execution frequency.
  • Added a new feature set Tablespaces (detailed) in order to better control the extension's resource consumption on the database. The current query for tablespaces monitoring has been moved to Tablespaces (detailed) and the the Tablespaces feature set now contains a simpler, less resource-intensive query to monitor tablespaces. This query drops the com.dynatrace.extension.sql-oracle.tablespaces.allocatedSpace metric and only monitors tablespaces with more than 50% used space.
    • ⚠️ When updating an existing configuration to the new version, the new Tablespaces (detailed) feature set will be disabled by default. To continue collecting tablespace metrics as before enable this new feature set in existing configurations and disable the Tablespaces feature set. ⚠️
  • Added link to OneAgent monitored host to the Oracle DB Instance screen.
  • Fixed bug where tablespace and datafile metrics were not properly associated with the sql-oracle_database entity.
ℹ️ This version requires ActiveGate version 1.301.0 or higher.
Version 3.1.3
  • Fixed execution plan monitoring fetching sometimes not working for RAC setups.
  • Fixed ASM entities not being created for certain non-RAC setups.
  • Fixed OneAgent HOST to Oracle DB Instance entity SAME_AS relationship not being established properly.
ℹ️ This version requires ActiveGate version 1.293.0 or higher.
  • Added internal metadata.
  • Fixed cluster wait events visualization in built-in Platform dashboard.
  • Cleaned up duplicate topology rule.
  • Added inter-instance ping metrics and charts for RAC setups
  • Added charts for cluster interconnects and cluster wait events to the cluster screen.
  • Adjusted the DataGuard severe events chart.
  • New feature set asm (detailed) introduced in order to better control license consumption for ASM disks. ASM disk metrics are moved to this new feature set, while ASM disk group metrics remain in the asm feature set.
    • ⚠️ When updating an existing configuration to the new version, the new asm (detailed) feature set will be disabled by default. To continue collecting ASM disk metrics enable this new feature set in existing configurations. ⚠️
  • Changed default dashboard to include ASM disk groups as well as ASM disks.
  • Fixed Cluster instance name sometimes showing empty for RAC setups.
  • Fixed Dataguard metrics not being splittable by instance.
  • Fixed non-RAC Dataguard gaps metric chart always showing empty.
  • New topology to accommodate for RAC setups:
    • The host entity, sql:com_dynatrace_extension_sql-oracle_host, was dropped and its data is now shown on the Oracle Instance screen.
    • The database-instance relationship was changed from runsOn to calls.
    • OneAgent detected hosts, dt.entity.host, now have a sameAs relationship with instances.
  • Query performance metrics are now collected at the database/container level instead of at the instance level.
  • Top query log attributes are no longer collected as a rate, but rather as the value reported in SQLAREA. This will also change the value of the log.sql-oracle.top_n_queries. metrics.
  • Oracle RAC setups are now supported. By configuring the extension to connect to a SCAN listener, Dynatrace will auto-detect the instances and databases without needing to individually configure endpoints for each instance.
    • A cluster entity, sql:com_dynatrace_extension_sql-oracle_cluster, was added and will be active whenever a RAC setup is detected.
  • Query performance charts now show in the database screen as well as in the instance screen. In the case of RAC, metrics for all instances running that database will be shown.
  • On multitenant setups the CDB$ROOT is now detected as a container. Tablespaces and datafile charts for the CDB$ROOT are now show in the CDB$ROOT's database screen as opposed to in the instance screen.
⚠️ This release requires ActiveGate version 1.293.0 or higher. Please check your version before upgrading.
  • Fixed certain backup monitoring metrics not working for Oracle Database 12c.
  • Fixed Dataguard no logging query always showing empty results.
  • Changed unit from Count to Byte for some PDB metrics.
  • Execution plan analysis is now available for the long running queries, and can be accessed by navigating to Databases app > Instances > Statement performance. This feature is only available for Dynatrace SaaS customers.
  • Blocked sessions and deadlock monitoring
    • Metrics for number of blocked sessions and deadlocks are part of the sessions feature set
    • Blocked session details are ingested as logs as part of the Blocked sessions feature set. Records can be filtered by event.group == "blocked_sessions" in the log query.
  • Datafile monitoring now includes number of corrupt blocks and datafile recovery status.
  • Alerts have been added around Data Guard for severe events, nologging activity, and archive destination status
  • Longest running query metrics are part of the TopN feature set
    • This helps visualize trends over time before using the Logs card to identify individual SQL statements
  • New configuration parameter - endpoint metadata
    • This parameter will populate the endpoint_metadata attribute of the Oracle Instance entity and can be used in entity selectors (to facilitate tagging, for example).
  • Out-of-the-box alerts have been adjusted to use current metrics
  • FRA and Tablespaces metric charts display values using the KiB/MiB/GiB (binary) unit scale. This is in-line with DBA expectations and Oracle Enterprise Manager. The raw values remain collected in Bytes.
  • Data guard chart cards only appear if data guard is enabled on the instance. This can be checked in the instance attributes.
  • Dropped the event dimension from com.dynatrace.extension.sql-oracle.wait.count and com.dynatrace.extension.sql-oracle.wait.time.count to prevent inadvertently high DDU consumption. To replace the previous functionality a new feature set, waitEvents (detailed), was added with metrics com.dynatrace.extension.sql-oracle.wait.events.count and com.dynatrace.extension.sql-oracle.wait.events.time.count which report total waits and total wait time for the top 20 wait events. When updating monitoring configs to the new version, make sure you enable the new feature set if you want to continue getting event level details.
  • ASM Disks tiles in the dashboard were using outdated metric names
  • ASM Disk Groups & ASM Disks queries would not run due to syntax
  • Fast Recovery Area (FRA) occupation tracking
  • Tablespaces are monitored per container (CDB & PDB)
  • ASM Disk Groups monitored as their own entity, related to ASM Disks
  • Status of data & temp files are tracked per container (CDB & PDB)
  • Data guard monitoring
    • Severe events
    • Gap between primary and standby applied sequences
    • Nologging activity counts
    • Archive destination error status
  • Tablespace utilization is calculated against maximum possible size including auto-extents
  • Tablespace utilization is reflected from CDB_TABLESPACE_USAGE_METRICS which takes into account the underlying filesystem (same as Oracle Enterprise Manager)
  • Sessions & Processes utilization reported as % of the configured limit
  • The extension data is now usable with the Database Overview App
  • Backup Jobs register additional details based on their backup sets
  • The time since the last backup of a given type is now recorded as a metric
  • Query timeout configuration parameter is more clearly described
  • Tablespaces chart on the Instance page showed a long metric expression name
  • Not all backups were detected and listed on the Instance page
Due to the topology changes mentioned below, your environment may create new entities to replace the ones created by older versions of the extension.
Any custom configuration relying on the following entity types will not work:
  • sql:com_dynatrace_extension_sql-oracle_cdb
  • sql:com_dynatrace_extension_sql-oracle_pdb (replace with sql:com_dynatrace_extension_sql-oracle_database)
  • sql:com_dynatrace_extension_sql-oracle_service
  • Additional attributes reported for Oracle Instances
  • When the extension is configured to connect to the Container (CDB), all Databases (PDBs) are automatically monitored
  • A new alert has been added for backup job failures
  • The topology has been simplified:
    • Oracle Instance now represents either a standalone instance or container
    • IDs of these entities are more accurately calculated
    • Oracle Database now represents either a standalone or pluggable database
    • The Oracle CDB, Oracle PDB, and Oracle Service entities have been removed
  • Database backups are visible on the Instance details page
  • All entity lists support filtering
  • The Oracle Server details page displays data about Oracle processes if the host has a OneAgent deployed
  • All metrics have the tag "Oracle" which can be used in the Metrics menu
  • Backups would not be detected if the process crashed before the first sub-job could complete
  • Backups would be aggregated if performed during the same session
Dynatrace Hub
All (950)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
