Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
OpenCode MonitoringOpenCode Monitoring
OpenCode Monitoring
OpenCode Monitoring
Visibility into OpenCode sessions, LLM calls, tools, and performance.
Technology
Free trialDocumentation
Dynatrace dashboard showing OpenCode sessions, token usage, LLM requests, tool execution, and request latency.
  • Product information
Overview
OpenCode Monitoring provides centralised observability into OpenCode agent sessions using its built‑in OpenTelemetry support. OpenCode exports OpenTelemetry traces natively over OTLP/HTTP (binary Protobuf), allowing agent activity to be sent directly to Dynatrace without requiring a collector for trace data.
Once enabled, OpenCode emits detailed trace spans covering LLM requests, tool execution, session lifecycle events, message processing, and file snapshot operations. This data can be explored in Dynatrace using distributed traces, dashboards, and the AI Observability app to understand how OpenCode behaves during real development workflows. Log data is currently exported in JSON format and can be ingested by routing through an OpenTelemetry Collector. Direct OTLP log ingestion will be supported once OpenCode adds binary Protobuf log export.
Use cases
Understand OpenCode agent behaviour
Follow OpenCode sessions end to end, including LLM calls, tool executions, and session lifecycle events, to understand how the agent operates during real usage.
Monitor performance and latency
Track request latency for LLM calls, tool execution duration, and message processing spans to identify slow operations or bottlenecks.
Analyse tool usage and workflows
See which tools are invoked, how often they are used, and how they contribute to the overall agent workflow.
Investigate failures and errors
Use distributed traces to drill into failed or slow LLM requests, tool executions, or session processing steps.
Visualise OpenCode activity in Dynatrace
Explore OpenCode telemetry using distributed traces, dashboards, and AI observability views to correlate agent behaviour with other platform signals.
Get started
Follow the OpenCode example on GitHub to enable OpenTelemetry export and explore OpenCode activity in Dynatrace.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
