Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
OpenClaw MonitoringOpenClaw Monitoring
OpenClaw Monitoring
OpenClaw Monitoring
Monitor OpenClaw agent activity with AI observability in Dynatrace.
Technology
Free trialDocumentation
Dynatrace dashboard showing OpenClaw gateway messages, token usage, sessions, channels, and average response time.
  • Product information
Overview
OpenClaw Monitoring enables teams to observe and analyse OpenClaw agent behaviour using Dynatrace AI Observability. OpenClaw includes a built‑in OpenTelemetry diagnostics plugin that exports traces, metrics, and logs over OTLP/HTTP, allowing agent activity to be routed directly into Dynatrace with minimal configuration.
Once enabled, OpenClaw sessions automatically emit telemetry covering model usage, token consumption, estimated cost signals, execution latency, session state changes, and tool interactions. This data can be explored in Dynatrace using dashboards, the Metrics browser, distributed traces, and the Log & Event Viewer to understand how OpenClaw behaves across real workloads.
By centralising OpenClaw telemetry in Dynatrace, platform and engineering teams can analyse agent performance, troubleshoot failures, and track usage patterns using the same observability workflows they apply to applications and platforms.
Use cases
Understand OpenClaw agent behavior
Follow each OpenClaw session end to end, including model invocations, token usage, session state transitions, and tool activity, to understand how the agent operates in practice.
Monitor performance and latency
Track run duration, model latency, message processing times, and webhook execution to identify slow paths, bottlenecks, or stuck sessions.
Track usage and cost signals
Analyse token consumption and estimated cost per model to understand usage patterns and identify inefficient or unexpected agent behaviour.
Troubleshoot failures and errors
Use distributed traces and structured logs to investigate webhook errors, failed runs, message processing issues, or abnormal session states.
Visualize OpenClaw activity in Dynatrace
Explore OpenClaw telemetry using dashboards, metrics, traces, and logs to gain a consolidated view of agent activity alongside other platform signals.
Get started
Follow the Quick Start steps on Github. The guide covers required configuration, environment variables, and dashboard setup for analyzing OpenClaw agent activity using Dynatrace AI Observability.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (955)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
