Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
OGX (Llama Stack)OGX (Llama Stack)
OGX (Llama Stack)
OGX (Llama Stack)
Trace OGX agents and model calls with OneAgent or OpenTelemetry.
Technology
Free trialDocumentation
Prompts stream showing LLM interactions with model version, token count, and prompt and response content.Trace-level debug view showing span hierarchy, tool calls, and prompt and response content for a single AI request.AI Agents topology and dependency map with per-agent LLM request counts, token usage, and response time.
  • Product information
Overview
OGX (formerly Llama Stack) is an open-source runtime for building AI applications and agents. It powers the GenAI Playground and GenAI Studio in Red Hat OpenShift AI 3.x and exposes the OpenAI-compatible Responses API on top of pluggable inference providers such as Ollama and vLLM.
Dynatrace monitors OGX applications with either OneAgent auto-instrumentation or OpenTelemetry. Model calls are captured as gen_ai.* chat spans, and OGX's own ogx.* metrics and tool spans are exported over OTLP, so model performance, token usage, and cost show up in the AI Observability app.
Use cases
Monitor model performance and cost
  • Track latency and token usage per model with gen_ai.client.operation.duration and gen_ai.client.token.usage.
  • Compare inference providers behind OGX by gen_ai.provider.name and gen_ai.request.model.
Trace Responses API requests end to end
  • Follow each request from your service through the OGX Responses API to the underlying LLM call in a single distributed trace.
  • Inspect OGX tool invocations (invoke_tool) alongside the chat spans they trigger.
Choose your instrumentation path
  • Use OneAgent for zero-code capture of model calls on hosts and Kubernetes.
  • Use OpenTelemetry (opentelemetry-instrument) to export traces and OGX runtime metrics directly to Dynatrace.
Get started
  1. Run OGX with your inference provider (for example, Ollama) using a distribution config.yaml.
  2. Either install Dynatrace OneAgent on the host, or follow the OGX telemetry guide and export OTLP to Dynatrace with an API token that has the openTelemetryTrace.ingest and metrics.ingest scopes.
  3. Send a request and open the AI Observability app to explore models, prompts, and traces.
For runnable samples, see the OGX examples on GitHub.
Details
OGX does not emit GenAI agent spans, so invoke_agent spans and gen_ai.agent.name are not available for OGX agents.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (955)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
