Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
NVIDIA GPUNVIDIA GPU
NVIDIA GPU
NVIDIA GPU
Monitor base parameters of the GPU, including load, memory and temperature.
Extension
Free trialDocumentation
Built-in overview dashboardGPU tab adds charts in the host details screen
  • Product information
  • Release notes
Overview
This extension monitors base parameters of NVIDIA GPUs, tracking load, memory and resource utilization of the GPUs. The extension leverages Python access to NVIDIA toolset to provide details on GPU utilization.
This is intended for users, who:
Want to expand monitoring of their hosts onto GPU and have an overview of their utilization.
Use cases
This extension enables you to:
  • Monitor utilization of the GPU across your environment
  • Locate bottlenecks in GPU memory usage
Get started
For more information on the installation and configuration, please see NVIDIA GPU extension in the Dynatrace Documentation.
Details
Compatibility information
This extension relies on following external libraries, that need to be supported by your GPU (card and driver):
  • gpustat
  • nvidia-ml-py
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
GPU temperaturenvidia.gpu.temperatureTemperature of GPU unit as provided by NVIDIA librariesCelsius
GPU power drawnvidia.gpu.power_drawPower currently used by GPU unit as provided by NVIDIA librarieswatt
GPU used memorynvidia.gpu.memory_usedUsed memory of GPU unit as provided by NVIDIA librariesMebiByte
GPU total memorynvidia.gpu.memory_totalTotal memory of GPU unit as provided by NVIDIA librariesMebiByte
GPU utilizationnvidia.gpu.utilizationUtilization of GPU unit as provided by NVIDIA librariesPercent
GPU processesnvidia.gpu.processesNumber of processes running on GPU unit as provided by NVIDIA librariesCount
Full version history
ReleaseDate
2.0.3
Version 2.0.2
Adds recommended feature sets.
Introduces three recommended feature sets to allow selective metric collection:
  • GPU Performance — utilization rate and active process count.
  • GPU Memory — total capacity and current memory usage.
  • GPU Power and Thermal — power draw and temperature.
All three feature sets are recommended and enabled by default.
Version 3.0.0
Adds Smartscape on Grail support.
This version introduces Smartscape on Grail support, with the following nodes and edges:
  • NVIDIA_GPU (was nvidia:gpu in the classic topology)
    • runs_on HOST
Notes
  • This feature is only relevant to SAAS customers.
  • This version requires a minimum Dynatrace version of 1.340 and a minimum ActiveGate/OneAgent version of 1.338.
  • You must have migrated OpenPipeline configurations to the Settings API, the extension can't be installed otherwise.
  • The existing classic entities still exist and are supported
Version 1.1.3
  • Fix an issue where the extension would fail to reinitialize the driver after an initial failure, requiring an extension restart
🐛 Bugs fixed in this version:
  • Configure Extension link on classic dashboard points to correct extension
🚀 Improved in this version:
  • Error codes added to logged errors
  • Add support for the dt.security_context attribute
  • Add new platform and classic dashboards
  • Add platform screens
Version 1.0.3
🐛Bugfixes
  • Fix an issue where the extension would fail if a GPU did not report certain metrics.
v1.0.2
  • Report 0 when there are no processes for a specific GPU
Added power consumption metric
Support for Nvidia GPU monitoring based on latest Extension Framework. Monitors temperature, memory, number of processes and utilization. Creates host screens for these metrics.
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
