Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
MongoDB (local or remote monitoring)MongoDB (local or remote monitoring)
Monitor your MongoDB servers either locally or remotely!.
Extension
Free trialDocumentation
New MongoDB DashboardMongoDB DashboardMongoDB Process ListMongoDB Process DetailsMongoDB Database ListMongoDB Database Details
  • Product information
  • Release notes
Overview
The MongoDB Extension connects to your MongoDB servers either remotely and locally.
Collective batch of data is gathered every minute by this extension and sent to the Dynatrace platform for detailed analysis.
This is intended for users, who:
  • Would like to monitor database traffic for optimization plan
This enables you to:
  • Monitor database operations with a comprehensive dashboard
  • Take pre-emptive measures to avoid service degradations
Get started
For more information on the installation and configuration, please see MongoDB (local or remote monitoring) extension in the Dynatrace Documentation.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Cache - Pages Requestedmongodb.cache.pages_requestedNumber of pages reqeusted from the cacheCount
Cache - Pages Readmongodb.cache.pages_readNumber of pages read into the cacheCount
Current connectionsmongodb.current_connections-Count
Available connectionsmongodb.available_connections-Count
Insert operationsmongodb.insert_operations2.count-Count
Query operationsmongodb.query_operations2.count-Count
Update operationsmongodb.update_operations2.count-Count
Delete operationsmongodb.delete_operations2.count-Count
Getmore operationsmongodb.getmore_operations2.count-Count
Command operationsmongodb.command_operations2.count-Count
Resident memorymongodb.resident_memory-MegaByte
Virtual memorymongodb.virtual_memory-MegaByte
Current queuemongodb.current_queue-Count
Active clientsmongodb.active_clients-Count
Regular assertsmongodb.regular_asserts2.count-Count
Warning assertsmongodb.warning_asserts2.count-Count
Message assertsmongodb.message_asserts2.count-Count
User assertsmongodb.user_asserts2.count-Count
Rollover assertsmongodb.rollover_asserts2.count-Count
Page Faultsmongodb.page_faultsThe total number of page faultsCount
Uptimemongodb.uptimeThe number of seconds that the MongoDB process has been active.Second
Objectsmongodb.db.objects-Count
Indexesmongodb.db.indexes-Count
Data sizemongodb.db.db_data_size-Byte
Storage sizemongodb.db.db_storage_size-Byte
Index sizemongodb.db.db_index_size-Byte
Replica Set - Oplog Sizemongodb.rs.oplog_sizeThe range between the earliest and latest oplog entiresByte
Replica Set - Oplog Windowmongodb.rs.oplog_windowThe time window covered by the oplog (Replication headroom)Second
Locks - Current Global Queuemongodb.locks.global_current_queueThe number of operations queued because of a lock.Count
Locks - Global Total Timemongodb.locks.global_total_timeThe time, in microseconds, since the database last started and created the globalLock. This is roughly equivalent to total server uptime.MicroSecond
Locks - Current Global Acquired Locksmongodb.locks.global_acquireNumber of times the lock was acquired in the specified mode.Count
Locks - Current Global Aqcuired Waitsmongodb.locks.global_acquire_waitNumber of times the lock acquisitions encountered waits because the locks were held in a conflicting mode.Count
Locks - Global Time Acquired (Microseconds)mongodb.locks.global_time_acquireCumulative wait time in microseconds for the lock acquisitions.MicroSecond
Locks - Current Global Deadlocksmongodb.locks.global_deadlocksNumber of times the lock acquisitions encountered deadlocks.Count
Full version history
ReleaseDate
3.2.2
⚠️WARNING⚠️: Possible breaking changes and warnings - PLEASE READ before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC version of 1.313.0
    • <If ingesting metrics> With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline.
    • <If ingesting metrics> This means that any dynamic route configured to process any metrics from the extension will be dropped in favor of the dedicated pipeline. Please, refer to pipeline groups to continue using dynamic routes.
New in this version:
  • Smartscape on Grail.
  • Added ability to set Primary Tags and Fields for Additional Processes within a monitoring configuration.
2.2.2
  • Updated pymongo dependency
  • Added support for Python 3.14
  • Added required dimensions to topology rules
  • Updated links in the Ready-made Platform Dashboard
2.1.5
What's New:
  • Added keyword key value pairs to extension
  • Update metric metadata for .count metrics to have count unit
NOTE:
  • This version requires ActiveGate version 1.313 or newer.
Improved in this version:
  • Improved error handling (Dynatrace Error Codes) and Endpoint Statuses.
New in this version
  • Updated screens for the latest Dynatrace.
⚠️ NOTICE:
  • Requires minimum Dynatrace version of 1.309
✨ New in this version:
Metrics
  • Page Faults (mongodb.page_faults) The total number of page faults (as Count)
  • Uptime (mongodb.uptime) The number of seconds that the MongoDB process has been active. (as Second)
  • Cache - Pages Requested (mongodb.cache.pages_requested) Number of pages reqeusted from the cache (as Count)
  • Cache - Pages Read (mongodb.cache.pages_read) Number of pages read into the cache (as Count)
  • Locks - Current Global Queue (mongodb.locks.global_current_queue) The number of operations queued because of a lock. (as Count)
  • Locks - Global Total Time (mongodb.locks.global_total_time) The time, in microseconds, since the database last started and created the globalLock. This is roughly equivalent to total server uptime. (as MicroSecond)
  • Locks - Current Global Acquired Locks (mongodb.locks.global_acquire) Number of times the lock was acquired in the specified mode. (as Count)
  • Locks - Current Global Deadlocks (mongodb.locks.global_deadlocks) Number of times the lock acquisitions encountered deadlocks. (as Count)
  • Locks - Current Global Aqcuired Waits (mongodb.locks.global_acquire_wait) Number of times the lock acquisitions encountered waits because the locks were held in a conflicting mode. (as Count)
  • Locks - Global Time Acquired (Microseconds) (mongodb.locks.global_time_acquire) Cumulative wait time in microseconds for the lock acquisitions. (as MicroSecond)
  • Replica Set - Oplog Size (mongodb.rs.oplog_size) The range between the earliest and latest oplog entires (as Byte)
  • Replica Set - Oplog Window (mongodb.rs.oplog_window) The time window covered by the oplog (Replication headroom) (as Second)
Authentication Mechanism
  • Added support for MONGODB-X509
Dashboard
  • Added New Dashboard
  • Fixed a bug when setting a custom hostname.
  • Fix for setting custom hostname in monitoring configuration.
⚠️ BREAKING CHANGE ⚠️
Upgrading existing monitoring configurations from previous versions to this version will not be possible and will require recreating those monitoring configurations. New monitoring configurations will not be affected.
In this version:
  • Added Support for TLS client certificate file (tlsCertificateKeyFile)
  • Fixed issue where credentials were not able to be retrieved from credential vault for additional monitored processes
Version 1.5.13
  • Removed the OCSP dependency, which made the extension not be able to connect to certain mongo instances
Version 1.5.12
🐛 Bug fixes
  • Fix an issue where the extension could not retry a connection after failure.
  • Fixed issue with cryptography library version requirement
  • Added toggle to enable debug logging
  • Added support for Credential Vault
v1.5.2
  • DXS-1351
    • Added support for Replica Sets
    • Added support for multiple MongoDB Processes (ports) in a single monitoring configuration
  • DXS-1601
    • Added support for Insecure TLS connections via the configuration
  • DXS-1762
    • Fix how IP address is reported for MongoDB Host entities when using the Remote Activation
v1.2.0
  • #277460
    • Changes to how entity names are captured, to avoid showing DBs as localhost
v1.1.0
  • Updates to correctly encode User and Password
v1.0.0
  • Initial Version of the Extension
Dynatrace Hub
All (931)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Replay how users experience your frontend. Analyze behavior and outcomes.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
