Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Juniper MistJuniper Mist
Juniper Mist
Juniper Mist
Monitor Juniper Mist sites, access points, gateways, switches, and alarms.
Extension
Free trialDocumentation
Juniper Mist Overview dashboard: currently monitored entities and organization detailsJuniper Mist Overview dashboard: access point clients, CPU, and memorySites inventory in Infrastructure & OperationsSite details: device connectivity per device typeSmartscape: a site with its organization and network devices
  • Product information
  • Release notes
Overview
The Juniper Mist extension brings the network infrastructure managed by the Juniper Mist cloud into Dynatrace. Running on an ActiveGate, it polls organization and site metrics through the Mist REST API and streams device metrics in near real time through the Mist WebSocket API, covering access points, gateways, and switches down to individual wired and wireless interfaces. It builds the Smartscape topology, can import Mist alarms as Dynatrace events, and comes with a ready-to-use overview dashboard and unified analysis screens for analyzing the health of your Mist-managed network.
Use cases
  • Device availability — monitor connected and disconnected access points, gateways, and switches at organization and site level.
  • Device health — track CPU, memory, and uptime for access points, gateways, and switches.
  • Wireless performance — analyze channel utilization breakdown, noise floor, and clients per radio.
  • Interface monitoring — watch traffic and status of the interfaces of every device.
  • Alarm import — receive Mist alarms as Dynatrace events, attached to the affected device, site, or organization.
  • Topology-driven investigation — follow the organization → site → network device → interface model to understand dependencies and surface root causes.
Get started
You need a Juniper Mist organization and an Environment ActiveGate with outbound HTTPS and secure WebSocket (WSS) access to the Mist API endpoint of your cloud region, directly or through a proxy. On the Mist side, generate an organization API token with the Observer (read-only) privilege that lets Dynatrace connect and collect the data.
For step-by-step instructions on the installation and configuration on both Juniper Mist and Dynatrace sides, please see Juniper Mist extension in the Dynatrace Documentation.
Details
The Juniper Mist extension collects metrics and topology data for:
  • Juniper Mist organizations
  • Juniper Mist sites
  • Access points, gateways, and switches
  • Wired interfaces and access point radios
  • Mist alarms, in a form of Dynatrace events (optional)
The extension brings the Juniper Mist Overview dashboard and unified analysis screens for organizations, sites, network devices, and network interfaces.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
BLE powerjuniper-mist.network_device.ble_powerBluetooth Low Energy power of the network deviceDecibelMilliWatt
BLE received bytesjuniper-mist.network_device.ble_rx_bytesNumber of bytes received over Bluetooth Low Energy by the network deviceBytes
BLE transmitted bytesjuniper-mist.network_device.ble_tx_bytesNumber of bytes transmitted over Bluetooth Low Energy by the network deviceBytes
BLE received packetsjuniper-mist.network_device.ble_rx_pktsNumber of packets received over Bluetooth Low Energy by the network deviceCount
BLE transmitted packetsjuniper-mist.network_device.ble_tx_pktsNumber of packets transmitted over Bluetooth Low Energy by the network deviceCount
BLE transmit resetsjuniper-mist.network_device.ble_tx_resetsNumber of Bluetooth Low Energy transmit resets by the network deviceCount
-com.dynatrace.extension.network_device.if.bytes_in.count--
-com.dynatrace.extension.network_device.if.bytes_out.count--
-com.dynatrace.extension.network_device.if.in.pkts.count--
-com.dynatrace.extension.network_device.if.out.pkts.count--
-com.dynatrace.extension.network_device.if.status--
CPU idlejuniper-mist.network_device.cpu_idleCPU idle percentage of the network devicePercent
CPU interruptjuniper-mist.network_device.cpu_interruptCPU interrupt percentage of the network devicePercent
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.memory_usage--
-com.dynatrace.extension.network_device.sysuptime--
Access Point countjuniper-mist.site.num_apNumber of Access Points belonging to the siteCount
Connected Access Point countjuniper-mist.site.num_ap_connectedNumber of connected Access Points belonging to the siteCount
Client countjuniper-mist.site.num_clientsNumber of active clients in the siteCount
Device countjuniper-mist.site.num_devicesNumber of devices belonging to the siteCount
Connected device countjuniper-mist.site.num_devices_connectedNumber of connected devices belonging to the siteCount
Gateway countjuniper-mist.site.num_gatewaysNumber of Gateways belonging to the siteCount
Connected Gateway countjuniper-mist.site.num_gateways_connectedNumber of connected Gateways belonging to the siteCount
Switch countjuniper-mist.site.num_switchesNumber of Switches belonging to the siteCount
Connected Switch countjuniper-mist.site.num_switches_connectedNumber of connected Switches belonging to the siteCount
-com.dynatrace.extension.network_device.memory_total--
-com.dynatrace.extension.network_device.memory_used--
-com.dynatrace.extension.network_device.memory_free--
Client countjuniper-mist.network_device.num_clientsNumber of clients connected to the network deviceCount
Device countjuniper-mist.org.num_devicesNumber of devices belonging to the organizationCount
Connected device countjuniper-mist.org.num_devices_connectedNumber of connected devices belonging to the organizationCount
Disconnected device countjuniper-mist.org.num_devices_disconnectedNumber of disconnected devices belonging to the organizationCount
Inventory countjuniper-mist.org.num_inventoryNumber of inventories belonging to the organizationCount
Site countjuniper-mist.org.num_sitesNumber of sites belonging to the organizationCount
LLDP power allocatedjuniper-mist.network_device.lldp_power_allocatedPower allocated by Link Layer Discovery Protocol on the network deviceDecibelMilliWatt
LLDP power drawjuniper-mist.network_device.lldp_power_drawPower draw by Link Layer Discovery Protocol on the network deviceDecibelMilliWatt
LLDP power request countjuniper-mist.network_device.lldp_power_request_countNumber of power requests by Link Layer Discovery Protocol on the network deviceCount
LLDP power requestedjuniper-mist.network_device.lldp_power_requestedPower requested by Link Layer Discovery Protocol on the network deviceDecibelMilliWatt
-com.dynatrace.extension.network_device.if.in.errors.count--
Interface speedjuniper-mist.network_device.if.speedSpeed of the network interfaceBitsPerSecond
Interface full duplexjuniper-mist.network_device.if.full_duplexWhether the network interface is full duplexBoolean
Interface utilizationjuniper-mist.network_device.if.utilUtilization of the network interfacePercent
Non-WiFi interface utilizationjuniper-mist.network_device.if.util_non_wifiUtilization of the non-WiFi network interfacePercent
Unknown WiFi interface utilizationjuniper-mist.network_device.if.util_unknown_wifiUtilization of the unknown WiFi network interfacePercent
Transmit interface utilizationjuniper-mist.network_device.if.util_txTransmit utilization of the network interfacePercent
Receive in BSS interface utilizationjuniper-mist.network_device.if.util_rx_in_bssReceive in BSS utilization of the network interfacePercent
Receive other BSS interface utilizationjuniper-mist.network_device.if.util_rx_other_bssReceive other BSS utilization of the network interfacePercent
Undecodable WiFi interface utilizationjuniper-mist.network_device.if.util_undecodable_wifiUtilization of the undecodable WiFi network interfacePercent
Interface noise floorjuniper-mist.network_device.if.noise_floorNoise floor of the wireless network interfaceDecibelMilliWatt
Interface client countjuniper-mist.network_device.if.num_clientsNumber of clients connected to the wireless network interfaceCount
Full version history
ReleaseDate
Initial release. Looking forward for your feedback via the Dynatrace Community!
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
