Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
IBM iIBM i
IBM i
IBM i
Collect performance data from your IBM i Hosts via this Remote extension.
Extension
Free trialDocumentation
Packaged dashboardHost view - System overviewHost view - Memory pools and JobsHost view - Subsystem, Job queues, ASPsJob overviewASP and Disk viewMemory poolMessage queue
  • Product information
  • Release notes
Overview
Dynatrace offers remote monitoring of IBM i hosts via this ActiveGate extension.
The ingested data provides Dynatrace with real-time visibility into host performance through interactive visualization tools, dashboards, unified analysis and events. When combined with OneAgent monitoring, you gain the ability to understand how IBM i interacts with the other components in your stack.
Get started
For more information on the installation and configuration, please see IBM i extension in the Dynatrace Documentation.
Details
Compatibility information
  • Windows and Linux ActiveGates
  • Supported releases:
    • IBM i 7.3 Technology Refresh 12+ (must have PTF Group SF99703 Level 28+)
    • IBM i 7.4 Technology Refresh 6+ (must have PTF Group SF99704 Level 20+)
    • IBM i 7.5
For Linux ActiveGates:
  • unixODBC 2.3.12 and higher
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Total capacityibm_i.asp.total_capacityThe total number of used and unused megabytes in the ASP. A special value of -2 is returned if the size of this field is exceeded. Contains the null value if the capacity cannot be determined.MegaByte
Capacity availableibm_i.asp.total_capacity_availableThe total number of unused megabytes in the ASP. A special value of -2 is returned if the value was too big to return. Contains the null value if the capacity cannot be determined.MegaByte
Percent ASP usedibm_i.asp.percentage_asp_usedPercentage of ASP space used against total capacity.Percent
Protected capacityibm_i.asp.protected_capacityThe total number of used and unused megabytes in the ASP that are protected by mirroring or device parity. A special value of -2 is returned if the value was too big to return. Contains the null value if the capacity cannot be determined.MegaByte
Protected capacity availableibm_i.asp.protected_capacity_availableThe number of unused megabytes in the ASP that are protected by mirroring or device parity. A special value of -2 is returned if the value was too big to return. Contains the null value if the capacity cannot be determined.MegaByte
Percent protected ASP usedibm_i.asp.percentage_protected_asp_usedPercentage of protected ASP space used against protected total capacity.Percent
Unprotected capacityibm_i.asp.unprotected_capacityThe total number of used and unused megabytes in the ASP that are not protected by mirroring or device parity. A special value of -2 is returned if the value was too big to return. Contains the null value if the capacity cannot be determined.MegaByte
Unprotected capacity availableibm_i.asp.unprotected_capacity_availableThe number of unused megabytes in the ASP that are not protected by mirroring or device parity. A special value of -2 is returned if the value was too big to return. Contains the null value if the capacity cannot be determined.MegaByte
Unprotected ASP usedibm_i.asp.percentage_unprotected_asp_usedPercentage of unprotected ASP space used against unprotected total capacity.Percent
Threadsibm_i.job.threads_cntThe number of active threads in the job.Count
Temporary storageibm_i.job.temporary_storage_usedThe amount of temporary storage, in megabytes, that is currently allocated to this job.MegaByte
Total disk I/Oibm_i.job.disk_ioThe number of disk I/O operations performed by the job during the measurement time interval. This is the sum of the asynchronous and synchronous disk I/O.Count
CPU percentageibm_i.job.cpu_percentageThe percent of processing unit time attributed to this job during the measurement time interval.Percent
Response timeibm_i.job.response_timeThe total response time over the measurement time interval, in seconds. ONLY available to interactive jobs.Second
Instancesibm_i.job.instancesNumber of job instances (or job numbers) running under a user and job name. This number can indicate if too few instances or too many instances are running for a specific process.Count
Status countibm_i.job.status_cntA count of job status for each job. This will visualize how many job instances are in different status. If an event for status was configured to trigger during endpoint configuration, event will contain the specific job number.Count
Availabilityibm_i.system.availabilityPercentage of time this host was available or reachable from this extensionPercent
Time since server startibm_i.http_server.last_startThe number of seconds elapsed since the HTTP server instance was started.Second
Time since server restartibm_i.http_server.last_restartThe number of seconds elapsed since the HTTP server instance was last restarted.Second
Normal connectionsibm_i.http_server.normal_connections_countThe number of non-SSL connections that have been made to the HTTP server instance since it was started or restarted.Count
SSL connectionsibm_i.http_server.ssl_connections_countThe number of SSL connections that have been made to the HTTP server instance since it was started or restarted.Count
Active threadsibm_i.http_server.active_threadsThe number of threads currently active and processing requests in the HTTP server instance.Count
Idle threadsibm_i.http_server.idle_threadsThe number of threads in the HTTP server instance that are idle and waiting for requests.Count
Total requestsibm_i.http_server.total_requests_countThe total number of requests handled by the HTTP server instance since it was started or restarted.Count
Total requests rejectedibm_i.http_server.total_requests_rejected_countThe total number of requests rejected by the HTTP server instance since it was started or restarted.Count
Total responsesibm_i.http_server.total_responses_countThe total number of responses sent by the HTTP server instance since it was started or restarted.Count
Requests (by function)ibm_i.http_server.requests_countThe number of requests handled by the HTTP server instance for this HTTP function.Count
Responses (by function)ibm_i.http_server.responses_countThe number of responses sent by the HTTP server instance for this HTTP function.Count
Error responses (by function)ibm_i.http_server.error_responses_countThe number of error responses sent by the HTTP server instance for this HTTP function.Count
Non-cache responses (by function)ibm_i.http_server.noncache_responses_countThe number of responses not served from cache by the HTTP server instance for this HTTP function.Count
Bytes received (by function)ibm_i.http_server.bytes_received_countThe number of bytes received by the HTTP server instance for this HTTP function.Byte
Bytes sent (by function)ibm_i.http_server.bytes_sent_countThe number of bytes sent by the HTTP server instance for this HTTP function.Byte
Non-cache processing time (by function)ibm_i.http_server.noncache_processing_time_countThe total processing time in milliseconds for non-cached responses by the HTTP server instance for this HTTP function.MilliSecond
Cache processing time (by function)ibm_i.http_server.cache_processing_time_countThe total processing time in milliseconds for cached responses by the HTTP server instance for this HTTP function.MilliSecond
Total sizeibm_i.output_queue.total_sizeThe total size of spooled files in this output queue.KiloByte
Current sizeibm_i.memory_pool.current_sizeThe amount of main storage, in megabytes, in the pool.MegaByte
Reserved sizeibm_i.memory_pool.reserved_sizeThe amount of storage, in megabytes, in the pool reserved for system use (for example, for save/restore operations).MegaByte
Defined sizeibm_i.memory_pool.defined_sizeThe size of the pool, in megabytes, as defined in the shared pool, subsystem description, or system value QMCHPOOL. Contains the null value for a pool without a defined size.MegaByte
Max active threadsibm_i.memory_pool.maximum_active_threadsThe maximum number of threads that can be active in the pool at any one time.Count
Current threadsibm_i.memory_pool.current_threadsThe number of threads currently using the pool.Count
Ineligible threadsibm_i.memory_pool.current_ineligible_threadsThe number of ineligible threads in the pool. Ineligible threads are threads that are ready to run but the memory pool activity level is at its maximum.Count
Database faultsibm_i.memory_pool.database_faultsThe rate, in page faults per second, of database page faults against pages containing either database access paths or data.PerSecond
Non-database faultsibm_i.memory_pool.non_database_faultsThe rate, in page faults per second, of nondatabase page faults against pages other than those designated as database pages.PerSecond
Total faultsibm_i.memory_pool.total_faultsThe rate, in page faults per second, of database faults and non-database faults.PerSecond
Database pagesibm_i.memory_pool.database_pagesThe rate, in pages per second, at which database pages are brought into the storage pool.PerSecond
Non-database pagesibm_i.memory_pool.non_database_pagesThe rate in pages per second at which nondatabase pages are brought into the storage pool.PerSecond
Matched messagesibm_i.message_queue.matched_messagesNumber of messages that are in queue that match severity, message IDs and message types (if configured).Count
Unit capacityibm_i.disk.unit_storage_capacityStorage capacity for configured units.Byte
Unit space availableibm_i.disk.unit_space_availableSpace available on the unit for use.Byte
Unit percent usedibm_i.disk.percent_usedThe percentage that the disk unit has been consumed.Percent
SSD power-on daysibm_i.disk.ssd_power_on_daysThe number of days that the SSD device has been active in a system. Contains the null value if this disk is not SSD or if the information is not available.Count
SSD life remainingibm_i.disk.ssd_life_remainingThe percentage of the lifetime remaining for the SSD device. This estimates the percentage of usable function remaining for the drive before it should be replaced. Calculations for this percentage include more than just the number of bytes written and supported. Contains the null value if this disk is not SSD or if the information is not available.Percent
I/O requestsibm_i.disk.io_requestsThe average number of I/O requests for read and write operations that occurred per second during the elapsed time.PerSecond
Avg I/O request sizeibm_i.disk.request_sizeThe average size of an I/O request in KB during the elapsed time.KiloByte
Avg read requestsibm_i.disk.read_requestsThe average number of requests per second to transfer data from the disk unit during the elapsed time.PerSecond
Avg write requestsibm_i.disk.write_requestsThe average number of requests per second to transfer data to the disk unit during the elapsed time.PerSecond
Avg data readibm_i.disk.data_readThe average amount of data, in KB, transferred from the disk unit, per request, during the elapsed time.KiloByte
Avg data writtenibm_i.disk.data_writtenThe average amount of data, in KB, transferred to the disk unit, per request, during the elapsed time.KiloByte
Percent busyibm_i.disk.percent_busyThe estimated percentage of time the disk unit is being used during the elapsed time.Percent
Number of filesibm_i.output_queue.number_of_filesThe total number of spooled or printer files currently on this output queue.Count
Number of writersibm_i.output_queue.number_of_writersThe number of printer writers that have been started to this output queue.Count
Number of jobsibm_i.job_queue.number_of_jobsThe number of jobs in the queue.Count
Active jobsibm_i.job_queue.active_jobsThe current number of jobs that are active that came through this job queue entry. Contains the null value if this job queue is not associated with an active subsystemCount
Held jobsibm_i.job_queue.held_jobsThe current number of jobs that are in *HELD status.Count
Released jobsibm_i.job_queue.released_jobsThe current number of jobs that are in *RELEASED status.Count
Scheduled jobsibm_i.job_queue.scheduled_jobsThe current number of jobs that are in *SCHEDULED status.Count
CPU rateibm_i.system.cpu_rateThe average CPU rate expressed as a percentage where 100% indicates the processor is running at its nominal frequency. A value above or below 100% indicates how much the processor has been slowed down (throttled) or speeded up (turbo) relative to the nominal frequency for the processor model.Percent
Avg. CPU utilizationibm_i.system.avg_cpu_utilizationThe average CPU utilization for all the active processors in 15 seconds elapsed time.Percent
Min. CPU utilizationibm_i.system.min_cpu_utilizationThe CPU utilization of the processor that reported the minimum amount of CPU utilization in 15 seconds elapsed time.Percent
Max. CPU utilizationibm_i.system.max_cpu_utilizationThe CPU utilization of the processor that reported the maximum amount of CPU utilization in 15 seconds elapsed time.Percent
Total sizeibm_i.output_queue.spooled_file.total_sizeThe size of the spooled file.Byte
Total pagesibm_i.output_queue.spooled_file.total_pagesThe total number of pages in the file.Count
Remaining copiesibm_i.output_queue.spooled_file.total_remaining_copiesThe number of copies remaining to print.Count
Interface statusibm_i.interface.statusA counter of 1 for every network interface that is on host. Used for returning all metadata about an interface.Unspecified
Total jobsibm_i.system.total_jobsThe total number of user and system jobs that are currently in the system.Count
Active jobsibm_i.system.active_jobsThe number of jobs active in the system (jobs that have been started, but have not yet ended), including both user and system jobs.Count
Percentage total jobsibm_i.system.percentage_total_jobsThe percentage of current total jobs over maximum jobs allowed.Percent
% Interactive performanceibm_i.system.interactive_jobsThe percentage of interactive performance assigned to this logical partition. This value is a percentage of the total interactive performance available to the entire physical system.Percent
System ASP usedibm_i.system.system_asp_usedThe percentage of the system storage pool (ASP number 1) currently in use.Percent
Maximum temporary storage usedibm_i.system.maximum_temporary_storage_usedThe largest amount of storage, in megabytes, used for temporary objects at any one time since the last IPL.MegaByte
Current temporary storage usedibm_i.system.current_temporary_storageThe current amount of storage, in megabytes, in use for temporary objects.MegaByte
Active threadsibm_i.system.active_threadsThe number of initial and secondary threads in the system (threads that have been started, but have not yet ended), including both user and system threads.Count
Total sizeibm_i.spooling.total_sizeSum size of all spooled files by user.KiloByte
Matched messagesibm_i.history_log.matched_messagesNumber of messages in History log that matched severity, message IDs and message types (if configured).Count
Active jobsibm_i.subsystem.current_active_jobsThe number of jobs currently active in the subsystem. This number includes held jobs but excludes jobs that are disconnected or suspended because of a transfer secondary job or a transfer group job. If STATUS is INACTIVE, returns 0.Count
Idle timeibm_i.network.idle_timeThe length of time, in seconds, since the last activity on this connection.Second
Bytes sentibm_i.network.bytes_sent_countThe number of bytes sent to the remote host.Byte
Bytes receivedibm_i.network.bytes_received_countThe number of bytes received from the remote host.Byte
Round trip timeibm_i.network.round_trip_timeThe smoothed round-trip time interval in milliseconds. This is a measure of the time required for a segment on the connection to arrive at its destination, to be processed, and to return an acknowledgment to the client. Contains null if PROTOCOL is UDP.MilliSecond
Round trip varianceibm_i.network.round_trip_varianceThe variance in milliseconds from the previous round-trip time. Contains null if PROTOCOL is UDPMilliSecond
Retransmissionsibm_i.network.retransmissions_countThe number of times the local system retransmitted a segment because an acknowledgement was not received. This is a count of all segments resent during the entire time the connection has been active. Contains null if PROTOCOL is UDP.Count
TCP connections establishedibm_i.network.tcp_connections_currently_establishedThe number of TCP connections for which the current state is either ESTABLISHED or CLOSE-WAIT. Contains null if PROTOCOL is UDP.Count
Full version history
ReleaseDate
⚠️ Important Change:
  • This version requires a minimum Dynatrace version of 1.345.0
Changes in this version:
  • Improved alignment of alerting for Smartscape nodes.
  • Adjusted CommitMode to NONE in connection string as this extension only does reads.
  • Added filtering to inventory screens.
  • Added health chart to entity inventory screens.
  • This version requires a minimum Dynatrace version of 1.343.0
New in this version
Important
If you are upgrading from version 2.x, please read the Release Notes in version 3.0.0 as subsequent patches are cumulative and this version includes those changes.
New in this release
  • Added support for IBM i 7.6
Fixed in this version
  • Reduced Message Queue and Message Queue Library field length in configuration as the max should be 10 characters.
  • Reduced default query timeout from 60 to 40 seconds.
⚠️WARNING: Possible breaking changes - Please read before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC (ActiveGate) version of 1.318.0.
    • With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline.
    • This means that any dynamic route configured to process any metrics from the extension will be dropped in favor of the dedicated pipeline. Please, refer to pipeline groups to continue using dynamic routes.
  • With the inclusion of OpenPipeline processing rules, any logs ingested from the extension will be processed by a dedicated OpenPipeline pipeline instead of the classic log pipeline.
    • This means that classic rules will no longer be used on logs ingested from the extension. Please be sure to migrate any you still need to OpenPipeline rules.
New in this version:
  • Smartscape 2.0 nodes and edges on Grail.
Requires Dynatrace 1.318 and ActiveGate 1.313
Features:
  • New HTTP server metrics feature set
Updates:
  • Includes support for Python 3.14
  • Feature set metadata definition
  • This release requires a Minimum Dynatrace Version version of 1.318.0 or higher.
  • Added ALERT_TEMPLATES for anomaly detectors in the Davis Anomaly Detection app (latest Dynatrace only).
Improved in this version:
  • Internal metadata updated.
  • Multiple Endpoint status within monitoring configuration can now report.
  • Internal error codes to facilitate more efficient troubleshooting.
Fixed in this version:
  • Issue where Remote network traffic was not collecting.
Fixes
  • URL encode password for use in connection string
    • Special characters in password could result in Remote address could not be resolvedconnection errors
On this version:
  • Resolved an issue where connections would grow exponentially on Linux ActiveGates due to connection pooling issues with unixODBC.
  • Various enhancements to align conformity of dashboards and entities with new generation dashboards.
Issues resolved in this version:
  • Resolved issue where Jobs were not collected after upgrading from a previous version.
  • Added Credential Vault support.
  • Added User status monitoring to send log events when certain users are disabled.
  • Modified parameters to connection string to support KeepAlive.
  • Fixed an issue with multi-threading.
  • Added Task bucket size feature to allow ActiveGates to create multiple tasks per group of endpoints and potentially spread across multiple ActiveGates in a group.
  • Resolved issue where restarts were occurring due to No KeepAlive errors.
  • Fixed issue with initial version check
  • Fixed issue with Message Queues not collecting data when not sending lot events
⚠️New entities for Jobs will be created as internal IDs have changed. They will have the same name so any alerting rules you previously created will continue to work just fine. However, you may see duplicate job entities for a few hours. ⚠️
  • History Log has been added.
  • Output queue size metric has been moved to its own feature set. If you are interested in this metric, please be sure to select it in your feature sets.
  • Adjusted Job metric aggregations.
  • Modified CPTimeout check parameter for Linux deployments.
  • Added extra fields to log events.
  • Adjusted disk metric aggregations
  • Resolved issue with only one message queue reporting events.
  • Resolved issue with jobs failing to retrieve when a custom subsystem was entered.
  • Updated out-of-the-box dashboard to remove limit of Hosts listed.
  • Resolved issue with CPU metric not always reporting.
  • Added support for Linux ActiveGates
  • Added management zone support to metrics.
  • Various UI enhancements and metadata
  • Increased Message IDs field filter
  • Added Percentage of Total Jobs over Max Jobs metric
  • Added More metadata to log events
  • Changes to UI to reflect above changes.
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
