Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
HP Nimble SANHP Nimble SAN
HP Nimble SAN
HP Nimble SAN
Gain insights into the performance of your HP Nimble SAN devices.
Extension
Free trial
A New Overview Dashboard is included for HP Nimble Storage Clusters, and their volumes and interfaces, providing an overview of the monitoring coverage. Use this as a starting point for troubleshooting and further drilldowns into the extension's data.A Classic Overview Dashboard is included for HP Nimble Storage Clusters, and their volumes and interfaces, providing an overview of the monitoring coverage. Use this as a starting point for troubleshooting and further drilldowns into the extension's data.The extension also includes Unified Analysis screens for all of the provided entities, including the Storage Cluster, Interfaces, and Volumes.
  • Product information
  • Release notes
Overview
This extension leverages the SNMP protocol to provide a complete solution to monitor HP Nimble Storage Devices. The complete configuration is provided out-of-the-box.
This is intended for users, who:
  • Would like to monitor health state and performance of their HP Nimble Storage devices and provide unified analysis for Ops, DevOps and IT Admins.
This enables you to:
  • Monitor health and performance of your HP Nimble Storage devices
  • Use an included alert configuration to be alerted if a monitored interface goes into a 'down' state.
  • Set up alerts to be notified by traffic anomalies
Use cases
  • Monitor HP Nimble Storage Devices by polling data for Network Devices and Interfaces.
  • Enable alerting on detected anomalies
  • Monitor the performance of Storage Volumes, using metrics such as I/O Latency for read and writes.
Get started
Simply activate the extension in your environment using in-product Hub, provide device configuration and you’re all set up.
More information can be found in the SNMP Extension Documentation
Details
This extension is built on top of the Extension 2.0 Framework.
The extension package contains:
  • SNMP Data Source configuration
  • New and Classic Dashboard Overviews
  • Unified Analysis Screens
  • Topology definition and entity extraction rules
  • Generic Network Topology Support
More information can be found in the Product News Blog:
  • Simplified observability for your SNMP devices
License consumption
This extension queries for metrics every minute. In both Classic and DPS Licensing models, license consumption is based on metric datapoints.
To estimate the amount of metric datapoints produced by an extension configuration per minute, use the following list which estimates a number of metrics per featureset and a multiplier value depending on which entity the metric is split by.
By adding these together an estimation of metric datapoints ingested per minute can be formed.
default: 1 x HP Nimble Cluster
Basic Volume Stats: 12 x HP Nimble Storage Volume
Global Stats: 15 x HP Nimble Cluster
Interfaces: 7 x HP Nimble Storage Interface
Volume Read Stats: 21 x HP Nimble Storage Volume
Volume Write Stats: 18 x HP Nimble Storage Volume
Consumption Formula
Approximate yearly datapoints = <metric datapoints per minute> * 60 minutes * 24 hours * 365 days
Classic licensing
In the classic licensing model, metric ingestion will consume Davis Data Units (DDUs) at the rate of .001 DDUs per metric data point.
To get an estimation of the amount of data points the extension will produce over a year, multiply the above formula by .001.
Troubleshooting
  • To troubleshoot this extension, use the guide(s) in the Dynatrace Community.
Compatibility information
  • This extension is to be used with HP Nimble Storage Devices only.
  • SNMPv2c and SNMPv3 supported only.
Dynatrace
More Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Uptimehp-nimble.sys.uptimesysUpTimeInstanceSecond
Total Writeshp-nimble.vol.io.total.writes.countTotal cumulative number of Write I/Os.Count
Write Timehp-nimble.vol.io.write.time.countTotal cumulative time for Write operation (sequential and random).MicroSecond
Total Write Byteshp-nimble.vol.io.total.write.bytes.countTotal cumulative number of Write I/O bytes (sequential and random).Byte
Sequential Writes Counthp-nimble.vol.io.seq.write.countTotal Number of Sequential Write I/O operations.Count
Sequential Write Byteshp-nimble.vol.io.seq.write.bytes.countNumber of Sequential Write I/O bytes.Byte
Write Latency Count - O to 100uhp-nimble.vol.io.write.latency.0To100u.countNumber of Write I/O operations with latency between 0 and 100 microseconds.Count
Write Latency Count - 100u To 200uhp-nimble.vol.io.write.latency.100uTo200u.countNumber of Write I/O operations with latency between 100 and 200 microseconds.Count
Write Latency Count - 200u To 500uhp-nimble.vol.io.write.latency.200uTo500u.countNumber of Write I/O operations with latency between 200 and 500 microseconds.Count
Write Latency Count - 500u To 1mshp-nimble.vol.io.write.latency.500uTo1ms.countNumber of Write I/O operations with latency between 1/2 and 1 milliseconds.Count
Write Latency Count - 1ms To 2mshp-nimble.vol.io.write.latency.1msTo2ms.countNumber of Write I/O operations with latency between 1 and 2 milliseconds.Count
Write Latency Count - 2ms To 5mshp-nimble.vol.io.write.latency.2msTo5ms.countNumber of Write I/O operations with latency between 2 and 5 milliseconds.Count
Write Latency Count - 5ms To 10mshp-nimble.vol.io.write.latency.5msTo10ms.countNumber of Write I/O operations with latency between 5 and 10 milliseconds.Count
Write Latency Count - 10ms To 20mshp-nimble.vol.io.write.latency.10msTo20ms.countNumber of Write I/O operations with latency between 10 and 20 milliseconds.Count
Write Latency Count - 20ms To 50mshp-nimble.vol.io.write.latency.20msTo50ms.countNumber of Write I/O operations with latency between 20 and 50 milliseconds.Count
Write Latency Count - 50ms To 100mshp-nimble.vol.io.write.latency.50msTo100ms.countNumber of Write I/O operations with latency between 50 and 100 milliseconds.Count
Write Latency Count - 100ms To 200mshp-nimble.vol.io.write.latency.100msTo200ms.countNumber of Write I/O operations with latency between 100 and 200 milliseconds.Count
Write Latency Count - 200ms To 500mshp-nimble.vol.io.write.latency.200msTo500ms.countNumber of Write I/O operations with latency between 200 and 500 milliseconds.Count
Write Latency Count - 500ms To Maxhp-nimble.vol.io.write.latency.500msToMax.countNumber of Write I/O operations with latency above 500 milliseconds.Count
Total Readshp-nimble.global.io.total.read.countTotal cumulative number of Read I/Os (sequential and random).Count
Sequential Readshp-nimble.global.io.seq.read.countTotal cumulative number of Sequential Read I/Os.Count
Total Writeshp-nimble.global.io.total.write.countTotal cumulative number of Write I/Os.Count
Sequential Writeshp-nimble.global.io.seq.write.countTotal cumulative number of Sequential Write I/Os.Count
Total Read Timehp-nimble.global.io.read.time.countTotal cumulative microseconds the system has spent processing Read I/Os. This includes system and disk latency, but not any network latency back to the initiator.MicroSecond
Total Write Timehp-nimble.global.io.write.time.countTotal cumulative microseconds the system has spent processing Write I/Os. This includes system and disk latency, but not any network latency back to the initiator.MicroSecond
Total Read Byteshp-nimble.global.io.total.read.bytes.countTotal cumulative number of Read I/O bytes (sequential and random).Byte
Sequential Read Byteshp-nimble.global.io.seq.read.bytes.countTotal cumulative number of Sequential Read I/O bytes.Byte
Total Write Byteshp-nimble.global.io.total.write.bytes.countTotal cumulative number of Write I/O bytes (sequential and random).Byte
Sequential Write Byteshp-nimble.global.io.seq.write.bytes.countTotal cumulative number of Sequential Write I/O bytes.Byte
Volume Bytes Used - Lowhp-nimble.global.disk.vol.bytes.used.low.countTotal number of bytes used on disk for volumes - low order bytes.Byte
Volume Bytes Used - Highhp-nimble.global.disk.vol.bytes.used.high.countTotal number of bytes used on disk for volumes - high order bytes.Byte
Snapshot Bytes Used - Lowhp-nimble.global.disk.snapshot.bytes.used.low.countTotal number of bytes used on disk for snapshots - low order bytes.Byte
Snapshot Bytes Used - Highhp-nimble.global.disk.snapshot.bytes.used.high.countTotal number of bytes used on disk for snapshots - high order bytes.Byte
Non-Sequential Read Hitshp-nimble.global.io.nonseq.read.hits.countTotal cumulative number of cache hits for Non-Sequential Read I/Os.Count
Interface Last Changehp-nimble.if.lastchange-Second
Interface In Octetshp-nimble.if.in.octets.count-Count
Interface Out Octetshp-nimble.if.out.octets.count-Count
Interface In Errorshp-nimble.if.in.errors.count-Count
Interface In Discardshp-nimble.if.in.discards.count-Count
Interface Out Errorshp-nimble.if.out.errors.count-Count
Interface Out Discardshp-nimble.if.out.discards.count-Count
Volume Size - Lowhp-nimble.vol.size.lowMaximum defined size of a volume in bytes - low order bytes.Byte
Volume Size - Highhp-nimble.vol.size.highMaximum defined size of a volume in bytes - High order bytes.Byte
Volume Usage - Lowhp-nimble.vol.usage.lowCurrent number of bytes a volume is using - low order bytes.Byte
Volume Usage - Highhp-nimble.vol.usage.highCurrent number of bytes a volume is using - high order bytes.Byte
Volume Reserved - Lowhp-nimble.vol.reserved.lowNumber of bytes reserved for a volume - low order bytes.Byte
Volume Reserved - Highhp-nimble.vol.reserved.highNumber of bytes reserved for a volume - high order bytes.Byte
Volume Onlinehp-nimble.vol.onlineVolume Online (true or false).Count
Volume Connectionshp-nimble.vol.num.connectionsNumber of iSCSI connections to the volume.Count
Disk Volume Used Bytes - Lowhp-nimble.vol.disk.vol.bytes.used.low.countTotal number of bytes used on disk for volumes - low order bytes.Byte
Disk Volume Used Bytes - Highhp-nimble.vol.disk.vol.bytes.used.high.countTotal number of bytes used on disk for volumes - high order bytes.Byte
Disk Snapshot Used Bytes - Lowhp-nimble.vol.disk.snapshot.bytes.used.low.countTotal number of bytes used on disk for snapshots - low order bytes.Byte
Disk Snapshot Used Bytes - Highhp-nimble.vol.disk.snapshot.bytes.used.high.countTotal number of bytes used on disk for snapshots - high order bytes.Byte
Total Readshp-nimble.vol.io.total.reads.countTotal cumulative number of Read I/Os (sequential and random).Count
Read Timehp-nimble.vol.io.read.time.countTotal cumulative time for Read operation (sequential and random).MicroSecond
Total Read Byteshp-nimble.vol.io.total.read.bytes.countTotal cumulative number of Read I/O bytes (sequential and random).Byte
Sequential Read Counthp-nimble.vol.io.seq.read.countTotal Number of Sequential Read I/O operations.Count
Sequential Read Byteshp-nimble.vol.io.seq.read.bytes.countTotal cumulative number of Sequential Read I/O bytes.Byte
Non-Sequential Read Total Hitshp-nimble.vol.io.nonseq.read.total.hits.countTotal number of Nonsequential Read I/O hits (to Memory and SSD).Count
Non-Sequential Read Memory Hitshp-nimble.vol.io.nonseq.read.memory.hits.countTotal number of Nonsequential Read I/O hits to Memory.Count
Non-Sequential Read SSD Hitshp-nimble.vol.io.nonseq.read.ssd.hits.countTotal number of Nonsequential Read I/O hits to SSD.Count
Read Latency Count - O to 100uhp-nimble.vol.io.read.latency.0To100u.countNumber of Read I/O operations with latency between 0 and 100 microseconds.Count
Read Latency Count - 100u To 200uhp-nimble.vol.io.read.latency.100uTo200u.countNumber of Read I/O operations with latency between 100 and 200 microseconds.Count
Read Latency Count - 200u To 500uhp-nimble.vol.io.read.latency.200uTo500u.countNumber of Read I/O operations with latency between 200 and 500 microseconds.Count
Read Latency Count - 500u To 1mshp-nimble.vol.io.read.latency.500uTo1ms.countNumber of Read I/O operations with latency between 1/2 and 1 milliseconds.Count
Read Latency Count - 1ms To 2mshp-nimble.vol.io.read.latency.1msTo2ms.countNumber of Read I/O operations with latency between 1 and 2 milliseconds.Count
Read Latency Count - 2ms To 5mshp-nimble.vol.io.read.latency.2msTo5ms.countNumber of Read I/O operations with latency between 2 and 5 milliseconds.Count
Read Latency Count - 5ms To 10mshp-nimble.vol.io.read.latency.5msTo10ms.countNumber of Read I/O operations with latency between 5 and 10 milliseconds.Count
Read Latency Count - 10ms To 20mshp-nimble.vol.io.read.latency.10msTo20ms.countNumber of Read I/O operations with latency between 10 and 20 milliseconds.Count
Read Latency Count - 20ms To 50mshp-nimble.vol.io.read.latency.20msTo50ms.countNumber of Read I/O operations with latency between 20 and 50 milliseconds.Count
Read Latency Count - 50ms To 100mshp-nimble.vol.io.read.latency.50msTo100ms.countNumber of Read I/O operations with latency between 50 and 100 milliseconds.Count
Read Latency Count - 100ms To 200mshp-nimble.vol.io.read.latency.100msTo200ms.countNumber of Read I/O operations with latency between 100 and 200 milliseconds.Count
Read Latency Count - 200ms To 500mshp-nimble.vol.io.read.latency.200msTo500ms.countNumber of Read I/O operations with latency between 200 and 500 milliseconds.Count
Read Latency Count - 500ms To Maxhp-nimble.vol.io.read.latency.500msToMax.countNumber of Read I/O operations with latency above 500 milliseconds.Count
Full version history
ReleaseDate
Enhancements
  • Updated entity links in Platform dashboards to redirect to the Infrastructure & Operations app.
Bugfixes
  • Adjusted required dimensions for entity creation to prevent null entities from being created.
⚠️ Note:
  • This release requires a Minimum Dynatrace Version of 1.318.0 or higher.
New in this version:
  • Internal metadata updated.
Initial release of HP Nimble SAN Extension.
Dynatrace Hub
All (875)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Problems logo
Problems
Logs logo
Logs
Investigations logo
Investigations
Business Flow logo
Business Flow
Cost & Carbon Optimization logo
Track, analyze, and optimize your IT carbon footprint and public cloud costs.
Anomaly Detection logo
Anomaly Detection
Detect and alert on anomalies and custom patterns using any DQL time series.
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
