Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
GitHub Copilot MonitoringGitHub Copilot Monitoring
End-to-end insight into Copilot model calls, tools, latency, and tokens.
Technology
Free trialDocumentation
Copilot in the AI Observability app: models, agents, traces, token usage, latency, and cost
  • Product information
Overview
Dynatrace AI Observability provides visibility into GitHub Copilot through Copilot's native OpenTelemetry support. Copilot emits traces, metrics, and events using the OpenTelemetry GenAI semantic conventions, covering agent invocations, LLM calls, tool and hook execution, token usage, latency, and errors. No code instrumentation is required: you configure telemetry and use Copilot normally.
Two setups are covered. Applications built on the GitHub Copilot SDK pass a telemetry configuration to the client and export through an OpenTelemetry Collector, which handles Dynatrace authentication and maps token metrics for the AI Observability app. VS Code Copilot Chat exports directly to Dynatrace using standard OTLP environment variables or enterprise-managed settings. In both cases, Copilot activity appears in the AI Observability app with models, token usage, agents, and traces.
Use cases
Understand LLM behavior
See each LLM call Copilot makes, including requested and response models, token usage, finish reasons, and latency.
Monitor tool execution
Track tool and hook calls, how long they take, and how they contribute to each agent invocation.
Analyze agent sessions
Follow agent invocations, turns, and conversations to understand how Copilot handles requests across the CLI, VS Code, and SDK applications.
Troubleshoot performance issues
Use traces and metrics in Dynatrace to spot slow models, token-heavy prompts, and errors.
Explore Copilot in AI Observability
View Copilot as an AI app in the AI Observability app, with models, agents, token usage, and traces available out of the box.
Get started
Choose the example that matches how you use Copilot:
  • Copilot SDK applications: Follow the GitHub Copilot SDK example to run the included OpenTelemetry Collector and enable the SDK's built-in telemetry.
  • VS Code Copilot Chat: Follow the VS Code Copilot Chat example to export telemetry directly from VS Code to Dynatrace.
Details
Requirements
  • A Dynatrace API token with the openTelemetryTrace.ingest and metrics.ingest scopes, plus logs.ingest for VS Code Copilot Chat events.
  • Delta temporality for metrics, which Dynatrace requires.
Privacy
Prompt, response, tool-argument, and tool-result content is not exported by default. Enable content capture only after privacy and security approval, as it can include source code and other sensitive data.
Cost
Copilot does not emit a native monetary cost attribute.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
