Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Fortinet FortiManagerFortinet FortiManager
Observe FortiManager managed devices, config sync, policy packages, and tasks.
Extension
Free trialDocumentation
FortiManager managed devicesFortiManager policiesFortiManager tasksFortiManager smartscapeFortiManager Policy Package analysis
  • Product information
  • Release notes
Overview
The Fortinet FortiManager extension brings the management-plane state held by a Fortinet FortiManager into Dynatrace. Running on an ActiveGate, it polls the FortiManager JSON-RPC API, reports metrics on the appliance, its ADOMs, managed devices and policy packages, builds the Smartscape topology, and streams task, configuration revision, and FortiAnalyzer alert details as structured logs. Ready-to-use dashboards, unified analysis screens, and alert templates enable analysis of reachability, configuration drift, policy deployment, and change activity across your Fortinet estate. Managed devices share Smartscape nodes with the Fortinet FortiGate extension, so management-plane state and device performance meet on the same device.
Use cases
  • Management-plane reachability — see which managed firewalls FortiManager has lost contact with, per ADOM, before a change window depends on them.
  • Configuration drift — catch devices whose running configuration no longer matches FortiManager's copy, and devices with uninstalled changes in the device database.
  • Policy deployment assurance — confirm that every policy package is installed on every device and VDOM it's assigned to.
  • Change activity and failures — see how many installs, imports, and firmware upgrades run, how long they take, and which fail, by task type and administrator.
  • Change audit — record who created each ADOM configuration revision, when, and why.
  • Appliance health — watch the FortiManager appliance's own CPU, memory, and disk before a full disk stops configuration revisions and logging.
  • Extension health — confirm the extension is collecting cleanly, and spot API failures or slow collection as they build up.
Get started
You need a FortiManager 7.2.2 or later appliance or VM, or a FortiManager Cloud instance, and an Environment ActiveGate that can reach it over HTTPS. On the FortiManager side, create a dedicated read-only administrator with JSON API access (or a FortiCloud IAM API user for FortiManager Cloud) that lets Dynatrace connect and collect the data.
For step-by-step instructions on the installation and configuration on both FortiManager and Dynatrace sides, please see Fortinet FortiManager extension in the Dynatrace Documentation.
Details
The Fortinet FortiManager extension collects metrics and topology for:
  • FortiManager appliance and its interfaces
  • Managed devices and their configured interfaces
  • FortiManager ADOM
  • FortiManager Policy Package
  • FortiManager HA Member
  • Per-task, per-configuration-revision, and FortiAnalyzer alert details, in a form of logs.
The extension brings four dashboards — Managed Devices, Policy & ADOMs, Task Activity, and Appliance & Integration Health — and eight alert templates.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Managed device inventoryfortimanager.devicesPresence signal (constant 1) per managed device, carrying its full identity, platform, firmware, connection/config-sync/database-modified/device status codes and HA role. The canonical per-device inventory record the Managed Devices dashboard and the ADOM screen's device list are built on. Managed devices get no Smartscape node of their own, because FortiManager reports no health or performance for them; the device is reported here and on its ADOM rather than as an empty network device page. os.version is composed from the device's os_ver (the major version alone), mr and patch fields, giving the same form the FortiGate GUI shows.Count
Device connection statusfortimanager.device.connection_statusWhether a managed device is currently connected to FortiManager (1) or not (0). The device-level availability signal. is_model marks a device that was added to FortiManager but has never connected — exclude those from device-down alerting so that staged devices do not raise problems before they are deployed.State
Device configuration sync statusfortimanager.device.config_sync_statusWhether a managed device's configuration is in sync with FortiManager's database (1 = in sync, 0 = out of sync/unknown). Flags configuration drift that has not yet been pushed to or pulled from the device.State
Device database modified flagfortimanager.device.db_modifiedWhether FortiManager's database record for a device has pending local modifications not yet installed to the device (1 = modified, 0 = not modified). Distinct from config_sync_status, which reflects the device's own reported sync state rather than FortiManager's pending changes.State
HA cluster membersfortimanager.device.ha_membersPresence signal (constant 1) per HA cluster member nested under its parent device, carrying the member's serial number, role and priority. Only clustered devices emit rows here; standalone devices emit none. Identity keys on member.serial, never member.name (member.name may repeat the parent device's name); the member's node belongs to its ADOM.Count
-com.dynatrace.extension.network_device.cpu_usage--
-com.dynatrace.extension.network_device.memory_usage--
-com.dynatrace.extension.network_device.if.status--
FortiManager connectivityfortimanager.connectivityWhether the extension's last poll of this FortiManager succeeded (1) or failed (0) at the authentication and system-status level. The primary availability signal for this monitoring configuration.State
FortiManager system statusfortimanager.system.statusPresence signal (constant 1) carrying the FortiManager appliance's own identity and platform attributes (hostname, serial, firmware version/build, HA mode, ADOM mode) — use it to look up which appliance a given series belongs to.Count
FortiManager appliance interfacesfortimanager.system.interfacesPresence signal (constant 1) per physical interface on the FortiManager appliance itself, carrying interface name, type, administrative status and configured speed/address. Distinct from managed-device interfaces reported by fortimanager.device.interfaces; the FortiManager's own operational link state has no source field on this endpoint and is permanently unset here. Carries fmg.serial — the appliance's own serial number, because no endpoint this extension reads reports a MAC address for the appliance — so this identifies the appliance's interface nodes the same way fortimanager.system.status identifies the appliance.Count
Managed devices by ADOM and connection statusfortimanager.managed_devicesCount of managed devices grouped by ADOM and connection status (up/down/unknown) — answers "how many devices in each ADOM are currently reachable" without needing per-device detail.Count
Administrative domainsfortimanager.adomsCount of Administrative Domains (ADOMs) configured on this FortiManager, grouped by restricted product set — a low-cardinality inventory signal for sizing ADOM scope.Count
Appliance CPU utilizationfortimanager.appliance.cpu.utilizationCPU utilization of the FortiManager appliance itself. This is the management appliance watching its own health — it is not a managed-device metric, and a busy FortiManager slows installs and API responses for every device it manages.Percent
Appliance memory utilizationfortimanager.appliance.memory.utilizationMemory utilization of the FortiManager appliance itself, derived from its reported used and total values rather than from an embedded percentage string, since that string's formatting varies between firmware builds.Percent
Appliance hard disk utilizationfortimanager.appliance.hard_disk.utilizationHard disk utilization of the FortiManager appliance itself. A full disk stops configuration revisions and logging before it stops device management, so it fails quietly rather than obviously.Percent
Appliance flash disk utilizationfortimanager.appliance.flash_disk.utilizationFlash disk utilization of the FortiManager appliance itself. Not present on every platform — where the appliance does not report it, the metric is simply not sent for that cycle rather than reported as zero.Percent
FortiManager tasksfortimanager.tasksPresence signal (constant 1) per task inside the configured lookback window whose state or percentage changed since the previous cycle, carrying its current state, type and initiating user. A task that has not moved reports nothing that cycle — the same dedup that keeps task IDs out of metric dimensions — so read this as change activity, not as a census of the window.Count
Policy packagesfortimanager.policy_packagesPresence signal (constant 1) per policy package defined in an ADOM, carrying its name, type (package vs. folder) and parent folder. The package inventory that fortimanager.policy_package.install_status cross-references by name.Count
Policy package install statusfortimanager.policy_package.install_statusWhether a specific policy package's installation is in sync (1 = installed) or not (0 = out of sync or any other reported state) on a given device/VDOM target. The largest-cardinality metric in this extension (one series per package x device x VDOM target) — narrow the adom_scope configuration field to control series count.State
ADOM device inventory by OS versionfortimanager.adom.devicesCount of devices within an ADOM grouped by restricted product set and OS version. Answers "how many devices in this ADOM are on which firmware" for upgrade-campaign planning.Count
ADOM workspace lock statusfortimanager.adom.workspace_lockedWhether an ADOM's workspace is currently locked for editing, and by whom. A locked workspace blocks other administrators from making changes until it is released.State
FortiManager API successful callssfm.fortimanager.api.successful_callsNumber of FortiManager JSON-RPC calls that returned status.code 0 in the last self-monitoring window, split by endpoint. A health signal for the extension's own connectivity, not for the managed estate.Count
FortiManager API failed callssfm.fortimanager.api.failed_callsNumber of FortiManager JSON-RPC calls that failed (non-zero status.code or HTTP error) in the last self-monitoring window, split by endpoint, vendor error code and error class. The first place to look when the extension reports a non-OK status.Count
FortiManager API response timesfm.fortimanager.api.response_timeMean elapsed time of FortiManager JSON-RPC calls in the last self-monitoring window, split by endpoint. Flags a slow or overloaded FortiManager before it starts timing out.MilliSecond
FortiManager session re-authenticationssfm.fortimanager.session.reauthNumber of forced session re-logins in the last self-monitoring window, split by reason (idle timeout, invalid session, forced). Session auth mode only — token mode never reports this metric.Count
Collection cycle durationsfm.fortimanager.collection.durationWall-clock duration of each feature set's collection callback in the last self-monitoring window. Identifies which feature set is slow before it risks overrunning its interval.Second
Full version history
ReleaseDate
New in this version
  • This is the first release of the Fortinet FortiManager extension.
Improved in this version
  • Not applicable — initial release.
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
