In Autodiscovery, the ingest rules count is now a link that shows the rules evaluated for that log source.
Always show the status column with the enable/disable toggle in rule-like settings tables.
Fixed an error when expanding a rule row in the rules evaluated on a log source dialog.
Renamed "entity" to "scope" in the autodiscovery log sources UI (scope details sheet, scope summary, row action menu and related messages).
Added an "Operation mode" option to Feature Flags that lets you configure the log ingest delay.
Fixed the CPU usage limit field to show validation errors while typing instead of only after unfocusing, and to replace the hint with the error consistently.
Removed the option to switch back from unified enrichment settings for tenants in phase 3 and above.
Fixed custom log source rules not highlighting invalid path or attribute fields when submitting a form with untouched required fields.
Warn when a custom log source path doesn't look like a valid Unix or Windows path.
Sources matched by ingest rules are now visible in the rules table.
Hide attributes in custom log source details for Windows Event Log sources.
Reverted preserving last opened tab in log module settings widget.
The auto-discovery sheet heading now shows the selected entity's name and type, and entity scope types in the log rule dialogs are shown as a "Type: …" chip instead of an icon.
Added an "Ingest rules" column to the auto-discovery log sources list showing how many ingest rules apply to each log source.
Replaced log ingestion coverage column with log file status column in auto-discovery log sources list.
Removed the coverage percentage from entity tiles and the average coverage column from entity lists in auto-discovery.
Log source summary now shows a warning instead of an error when you lack permission to read system logs.
Auto-populate enrichment value based on path and attribute key, and warn when the value references a wildcard that doesn't exist in the path.
Users with restricted IAM policies on the autodiscovery section were incorrectly blocked from accessing it. The app now sends the right context when checking permissions, so the server can give a clear yes or no instead of an inconclusive answer.
Tab navigation now uses URL paths (/sources, /ingest-rules, etc.) instead of query params, so deep links, back button, and browser history work per tab.
Matcher values are now displayed as compact chips for improved readability.
Matcher rule chip values now display their full text without truncation.
Autodiscovery: preserve expanded rows, search, filters and sorting when switching entity types.
Sorting the inner table no longer collapses the outer one, and the table no longer stretches to fill the whole screen when few rows are shown.
Added a regex tester to the sensitive data masking rule modal, using server-side evaluation to validate the expression and preview the masked result against sample logs. Gated behind the log-module-settings.regex-tester feature flag.
Added a link to regex examples in the sensitive data masking rule modal.
Added a "Sources configuration" sub-tab that lets users define rules controlling encoding, binary content, and log rotation per log source.
Added JSON rules management under the Processing rules tab.
Grouped processing rules settings under a single tab.
Added a binary detection algorithm select to advanced log settings.
Renamed the Event Suppression tab to SFM Events and updated the UI text to explicitly mention Self Monitoring Events (SFM).
Updated the SFM suppression tab description and added a documentation link anchor.
Single-object settings views (Discovery and processing, Opt-in feature flags, Resource allocation) now show a banner when child entities override the current scope's settings.
"Show entities" on the overriding settings banner now opens the platform's Custom settings panel instead of a separate entities list.
Hid the custom settings button in the widget's title bar, keeping the per-tab overriding entities banner as the single source of truth.
CPU usage limit field is now bounded between 0.01 and 100 and accepts decimal values; the hint shows the range and uses a "Learn more" link.
Replaced the documentation links in the advanced settings descriptions with a trailing "Learn more" link.
Added a documentation link to the CPU usage limit field description and to the opt-in feature flags section.
Moved the "Other OneAgent features" link into the advanced log settings section.
Improved the sub-tabs layout in the settings widget.
Updated the widget heading and feature flags tab title.
Added more meaningful placeholders.
Added a separate icon for system logs.
Allowed per-entity smartscape IDs (dt.smartscape.k8s_pod, dt.smartscape.k8s_namespace, dt.smartscape.k8s.entity, dt.smartscape.k8s_cluster) as show_log_sources intent params.
The show_log_sources intent now accepts classic namespace and pod id; added the alias dt.entity_source.id for the classic entity id, mirroring dt.smartscape_source.id.
Auto-expand the Advanced section for a custom log source path when it already has enrichment data.
Aligned the multiline search expression in masking rule details so wrapped text stays next to its label.
Fixed different log level values of an Ingest rule matcher all showing up as ALERT when editing.
Fixed a crash when opening autodiscovered log sources from an intent.
Fixed a crash in the custom log source settings widget when useWatch returns undefined on the first render.
Fixed quickly edited fields in log rules or resource allocation settings not triggering the unsaved-changes prompt.
