Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Dynatrace BindplaneDynatrace Bindplane
Dynatrace Bindplane
Dynatrace Bindplane
Optimize and manage your telemetry at the edge before it reaches Dynatrace.
Technology
Free trialDocumentation
Dynatrace Bindplane architecture overviewDynatrace Bindplane pipeline management
  • Product information
Overview
Bindplane is a vendor‑agnostic telemetry pipeline management solution that centralizes collection, transformation, and routing of metrics, logs, traces, and events into Dynatrace and other destinations. It helps SIEM, APM, and operations teams reduce tool and agent sprawl, optimize data volumes, and enforce security and compliance at the source. With AI‑powered pipeline intelligence and centralized fleet management, Bindplane streamlines OpenTelemetry‑based observability for complex hybrid and multi‑cloud environments.
Use cases
  • Consolidate fragmented log and telemetry pipelines into a single control plane.
  • Centrally manage and update OpenTelemetry collectors and other gateways or log collectors at scale.
  • Optimize data volumes, routing, and destination costs with AI‑driven pipeline management assistance.
  • Manage security, compliance, and data residency policies at the source.
  • Ingest legacy telemetry (for example, Syslog) while standardizing on OpenTelemetry seamlessly.
Get started
  • Sign in to your Bindplane management console or sign-up for a trial.
  • Add Dynatrace as a destination and define telemetry routes, according to product documentation linked.
  • Validate data flow in Dynatrace.
Details
Supports routing metrics, logs, traces, and events from cloud native and on‑prem sources to Dynatrace and other destinations. Centralizes OpenTelemetry collector and gateway lifecycle management using the OpAMP protocol. Enables multi‑destination routing, in‑agent transformations, and cost‑optimized volume reduction. Designed for secure, large‑scale and air‑gapped environments with separation of control and data routing planes.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Dynatrace Bindplane
Amazon CloudWatch Logs logo
Monitor, store, and access your log files from instances, AWS CloudTrail, Route 53, and other sources.
Amazon S3 log forwarder logo
Stream log data from Amazon S3 to Dynatrace for analysis and automation.
Auth0 Log Streaming logo
Auth0 Log Streaming
Stream Auth0 identity logs using webhooks for unified observability.
AWS logs via CloudWatch logo
Stream logs from AWS services via Amazon CloudWatch into Dynatrace.
Azure Data Catalog logo
Azure Data Catalog
Fully managed cloud service that lets users discover the data sources they need and understand the data sources they find.
Azure Logic Apps logo
Azure Logic Apps
Cloud service that helps you schedule, automate, and orchestrate tasks across enterprises or organizations.
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
