Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
CursorCursor
Cursor
Cursor
Monitor Cursor usage, tokens, cost, and errors with a premade dashboard.
Technology
Free trialDocumentation
Premade Cursor dashboard: requests, errors, conversations, users, token usage, estimated cost, and latency by model
  • Product information
Overview
Dynatrace AI Observability provides insights into Cursor usage through Cursor's native Enterprise OpenTelemetry export. Cursor sends logs and metrics only (no traces), covering API requests and errors, token consumption, estimated cost, tool and MCP tool calls, skills, hooks, plugins, and Cloud Agent activity.
Export is configured server-side by a Cursor administrator in Team Settings > OpenTelemetry Export: there is no SDK, editor extension, or instrumentation package to install. Because Cursor does not emit spans, its data does not appear in the AI Observability app. Instead, the example includes a premade Cursor monitoring dashboard that you import into Dynatrace to analyse requests, tokens, cost, latency, conversations, tools, users, and surfaces.
Use cases
  • Understand Cursor activity: See how developers use Cursor across surfaces, including requests, conversations, tool and MCP tool calls, skills, and hooks, without relying on fragmented local logs or ad‑hoc scripts.
  • Monitor cost and token usage: Track input, output, and cache token usage and estimated cost by model to find expensive or inefficient usage as teams adopt Cursor.
  • Track reliability and latency: Follow API errors and average request latency to spot slow or failing interactions early.
  • Support consistent adoption across teams: Use the premade dashboard as a shared view of Cursor usage by user and surface, helping platform and engineering leaders compare usage patterns and maintain governance as adoption grows.
Get started
  1. Follow the Cursor example in the Dynatrace AI agent instrumentation examples repository on GitHub.
  2. In Cursor Team Settings > OpenTelemetry Export, add Dynatrace as a destination and enable the logs and metrics telemetry families.
  3. Import cursor-monitoring-dashboard.json from the example into Dynatrace Dashboards.
Details
Telemetry exported by Cursor
  • Metrics: cursor.token.usage (by token type), cursor.tool.calls (built-in and MCP tools), and cursor.cost.usage (a best-effort estimate, not an invoice). Metrics use delta temporality and contain no request or conversation IDs.
  • Logs: cursor.api.request, cursor.api.error, cursor.api.correction, skills, hooks, plugins, Cloud Agent lifecycle events, Grok Bot actions, and opt-in cursor.conversation.* messages. Logs are delivered at least once; deduplicate on cursor.event.id.
Requirements
Cursor Enterprise with team telemetry administration permission, and a Dynatrace API token with log and metric ingest permissions.
Privacy
Conversation content export is off by default. Enable it only after privacy and security approval. It currently covers Cloud Agents and Grok Bot, not IDE, CLI, or desktop conversations.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (950)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
