Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
CPU Core MonitoringCPU Core Monitoring
CPU Core Monitoring
CPU Core Monitoring
Get insights into CPU Core utilization on your OneAgent hosts.
Extension
Free trialDocumentation
View CPU core usage for your Linux hosts in the Infrastructure & Operations app.View CPU core usage for your Windows hosts in the Infrastructure & Operations app.
  • Product information
  • Release notes
Overview
Monitor your CPU usage for your Linux and Windows hosts. This extension collects in-depth metrics on OneAgent monitored hosts by reporting CPU utilization for each core.
Use cases
  • Monitor utilization for each CPU core.
  • Identify high CPU utilization on specific CPU cores.
  • Break down the components of CPU core utilization:
    • See percentages of that make up CPU utilization with metrics for user time, kernel time, IRQ time and more.
Get started
Activate the extension in your environment from Dynatrace Hub, and configure which OneAgent hosts to monitor.
Details
This extension package contains:
  • Screen injections for OneAgent hosts in the Infrastructure and Operations app, as well as the Hosts Classic app.
  • Specific CPU core-related metrics for both Linux and Windows.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
CPU core I/O wait timehost.cpu_core.iowaitPercentage of CPU core time when the CPU core was idle during which the system had an outstanding I/O request (Linux only).Percent
CPU core idle timehost.cpu_core.idlePercentage of CPU core time, when the CPU core didn't have anything to do.Percent
CPU core steal timehost.cpu_core.stealAverage CPU core time, when a virtual machine waits to get CPU cycles from the hypervisor. In a virtual environment, CPU cycles are shared across virtual machines on the hypervisor server. If your virtualized host displays a high CPU steal, it means CPU cycles are being taken away from your virtual machine to serve other purposes. It may indicate an overloaded hypervisor (Linux only).Percent
CPU core system timehost.cpu_core.systemPercentage of CPU core time when CPU core was running in Kernel mode.Percent
CPU core user timehost.cpu_core.userPercentage of CPU core time when CPU core was running in User mode.Percent
CPU core IRQ timehost.cpu_core.irqPercentage of CPU core time when CPU core was running in IRQ mode (Linux only).Percent
CPU core software IRQ timehost.cpu_core.softirqPercentage of CPU core time when CPU core was running in software IRQ mode (Linux only).Percent
Cpu core nice timehost.cpu_core.nicePercentage of CPU core time when CPU core was running in nice mode (Linux only).Percent
CPU core guest total timehost.cpu_core.guest_totalPercentage of total CPU core time when CPU core was running in guest mode (Linux only).Percent
CPU core DPC timehost.cpu_core.dpcPercentage of CPU core time when CPU was running in define procedure call (DPC) mode. (Windows only).Percent
CPU core interrupt timehost.cpu_core.interruptPercentage of CPU core time when CPU was running in interrupt mode. (Windows only).Percent
CPU core informationhost.cpu_core.infoReturns a constant metric value of `1` every minute and supplies dimensions to be used as metadata, such as logical core count.Unspecified
CPU core usagehost.cpu_core.usagePercentage of CPU core time when CPU core was utilized. A value close to 100% means most host processing resources are in use, and host CPU cores can't handle additional work.Percent
Full version history
ReleaseDate
Requires Dynatrace version 1.343.0 and EEC (OneAgent) version 1.318.0.
New in this version:
New in this version
  • CPU time % Feature set added for related metrics (No new metrics have been added, this is just re-organizing existing metrics).
Fixed in this version
  • Fixes Could not retrieve type information error message seen in the Technologies and Processes Classic app in version 1.0.6 of the extension.
✨New in this version:
  • Initial release including Screen Injections for the Infrastructure & Operations app, as well as the Hosts Classic app.
Dynatrace Hub
All (958)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
