Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Cloud FoundryCloud Foundry
Cloud Foundry
Cloud Foundry
Monitor your Cloud Foundry resource definitions by connecting to the foundation.
Extension
Free trial
Overview DashboardConfiguration SettingsExtension Feature SetsCloud Foundry Topology TypesCloud Foundry Foundation InfoCloud Foundry Foundation ResourcesCloud Foundry App Overview ScreenCloud Foundry App Resource Definition
  • Product information
  • Release notes
Overview
This extension uses the Cloud Foundry API (CAPI) to connect to the foundation and collect resource definitions and metadata. These can be ingested as metrics and events.
  • info
  • apps
  • builds
  • domains
  • droplets
  • organizations
  • organization_quotas
  • packages
  • processes
  • routes
  • service_instances
  • spaces
Use cases
  • Cloud Foundry resource topology
  • Overview dashboards and screens for Cloud Foundry workloads
Get started
For more information on the installation and configuration, please follow the Documentation link under Resources.
Dynatrace
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
CloudFoundry Process Instancescloudfoundry.processes.instancesThe number of instances of the processCount
CloudFoundry Process Memory Usagecloudfoundry.processes.memory_limitProcess memory limitMegaByte
CloudFoundry Process Disk Limitcloudfoundry.processes.disk_limitProcess disk usage limitMegaByte
CloudFoundry Process Log Rate Limitcloudfoundry.processes.log_rate_limitProcess Log Rate LimitBytePerSecond
Cloudfoundry Process resources collected as logscloudfoundry.processes.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Spacescloudfoundry.spaces.propertiesConstant metric used to report CloudFoundry Spaces properties as dimensions.Count
Cloudfoundry Space resources collected as logscloudfoundry.spaces.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry API Connectivitycloudfoundry.connectivityCloudfoundry API successful connection percentagePercent
CloudFoundry Routescloudfoundry.routes.propertiesConstant metric used to report CloudFoundry Route properties as dimensions.Count
Cloudfoundry Route resources collected as logscloudfoundry.routes.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry App Statecloudfoundry.apps.stateThe App state. STOPPED = 0, STARTED = 1. Use the state dimension for the string value.Count
Cloudfoundry App resources collected as logscloudfoundry.apps.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Service Instance Last Operation Statecloudfoundry.service_instances.last_operation.stateThe Service Instance last operation state. failed = 0, in progress = 1 succeeded = 2. Use the 'state' dimension for the string value.Count
Cloudfoundry Package resources collected as logscloudfoundry.service_instances.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Domainscloudfoundry.domains.propertiesConstant metric used to report CloudFoundry Domain properties as dimensions.Count
Cloudfoundry Domain resources collected as logscloudfoundry.domains.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Organizationscloudfoundry.organizations.propertiesConstant metric used to report CloudFoundry Organization properties as dimensions.Count
Cloudfoundry Organization resources collected as logscloudfoundry.organizations.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Build Statecloudfoundry.builds.stateThe state of the build. FAILED = 0, STAGING = 1, STAGED = 2. Use the 'state' dimension for the string value.Count
CloudFoundry Build Staging Memory Limitcloudfoundry.builds.staging_memory_limitThe staging memory limit for the buildMegaByte
CloudFoundry Build Staging Disk Limitcloudfoundry.builds.staging_disk_limitThe staging disk limit for the buildMegaByte
CloudFoundry Build Staging Log Rate Limitcloudfoundry.builds.staging_log_rate_limitThe staging log rate limit for the buildBytePerSecond
Cloudfoundry Build resources collected as logscloudfoundry.builds.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Package Statecloudfoundry.packages.stateThe Package state. FAILED = 0, AWAITING_UPLOAD = 1, READY = 2. Use the 'state' dimension for the string value.Count
Cloudfoundry Package resources collected as logscloudfoundry.packages.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Dropletscloudfoundry.droplets.propertiesConstant metric used to report CloudFoundry Droplet properties as dimensions.Count
Cloudfoundry Droplet resources collected as logscloudfoundry.droplets.logs_collectedHow many resource logs were collected in the last queryCount
CloudFoundry Org Quota Apps Total Memory Limitcloudfoundry.organization_quotas.apps.total_memory_limitTotal memory limit for all Apps in the quotaMegaByte
CloudFoundry Org Quota Apps Per Process Memory Limitcloudfoundry.organization_quotas.apps.per_process_memory_limitPer process memory limit for all Apps in the quotaMegaByte
CloudFoundry Org Quota Per App Task Limitcloudfoundry.organization_quotas.apps.per_app_tasksLimit for the total tasks per App in the quotaCount
CloudFoundry Org Quota Apps Total Instance Limitcloudfoundry.organization_quotas.apps.total_instancesLimit for the total number of Apps in the quotaCount
CloudFoundry Org Quota Apps Log Rate Limitcloudfoundry.organization_quotas.apps.log_rate_limitLog rate limit per App in the quotaBytePerSecond
CloudFoundry Org Quota Service Paid Allowedcloudfoundry.organization_quotas.services.paid_services_allowedThe number of paid services allowed in the quotaCount
CloudFoundry Org Quota Service Total Instancescloudfoundry.organization_quotas.services.total_service_instancesThe number of service instances allowed in the quotaCount
CloudFoundry Org Quota Service Total keyscloudfoundry.organization_quotas.services.total_service_keysThe number of service keys allowed in the quotaCount
CloudFoundry Org Quota Routes Totalcloudfoundry.organization_quotas.routes.total_routesThe total number of routes in the quotaCount
CloudFoundry Org Quota Routes Total Reserved Portscloudfoundry.organization_quotas.routes.total_reserved_portsThe total number of reserved ports in the quotaCount
CloudFoundry Org Quota Domains Totalcloudfoundry.organization_quotas.domains.total_domainsThe total number of domains allowed in the quotaCount
Cloudfoundry Organization Quota resources collected as logscloudfoundry.organization_quotas.logs_collectedHow many resource logs were collected in the last queryCount
Full version history
ReleaseDate
Update the certifi dependency to address CVE-2026-111943
✨ New in this version:
WARNING: Possible breaking changes and warnings - PLEASE READ before upgrading:
  • This version requires a minimum Dynatrace version of 1.338.0 and a minimum EEC version of 1.333.0.
    • With the inclusion of OpenPipeline processing rules, any metrics ingested from the extension will be processed by a dedicated OpenPipeline pipeline instead of the classic pipeline.
    • This means that classic rules will no longer be used on metrics ingested from the extension. Please be sure to migrate any you still need to OpenPipeline rules.
  • Smartscape on Grail.
  • Refactored feature sets according to the best practices established here.
  • Cloud Foundry API Integration for core resources such as Apps, Organizations, Spaces
  • Topology and Metadata information
  • Direct UAA Authentication using an oauth password grant
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
