Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Amazon Bedrock AgentCore GatewayAmazon Bedrock AgentCore Gateway
Enable Bedrock agents to access Dynatrace for real‑time observability insights.
Technology
Free trialDocumentation
Integrate Dynatrace MCP server with AgentCore GatewaySchematic overview of Amazon Bedrock AgentCore Gateway
  • Product information
Overview
Give your Amazon Bedrock agents the power to make context‑aware decisions using real‑time observability data from Dynatrace.
With the Dynatrace MCP Server integrated into your Bedrock AgentCore Gateway, your agents can access service health, metrics, traces, problems, dependency information, and logs directly. This allows them to detect anomalies, understand system state, and act intelligently based on actual production conditions.
Using the Model Context Protocol (MCP), Dynatrace becomes a live source of truth that your agents can query through a standardized interface. This integration allows advanced agentic automation, operational awareness, and closed‑loop remediation workflows.
Use cases
  • Provide agents with real-time observability data: Agents can retrieve service metrics, entity data, logs, and distributed traces directly from Dynatrace.
  • Enable automated problem detection and response: Agents can query live problem feeds and take corrective action or escalate intelligently.
  • Enhance agent reasoning with root-cause-aware context: Give agents access to dependencies, topology, and causal data for more accurate decisions.
  • Support compliance, auditing, and governance workflows: Agents can gather observability evidence on demand for regulated processes.
  • Optimize performance and cost through agent-driven insights: Allow agents to reason about system health, latency, and resource usage in real time.
Get started
Setting up the integration between Amazon Bedrock AgentCore Gateway and Dynatrace MCP Server requires a few steps performed in your AWS environment.
  1. Set up the Dynatrace MCP Server: Configure the Dynatrace MCP Server and required OAuth credentials as described in the reference implementation. This allows secure agent access to Dynatrace APIs.
  2. Create an AgentCore Gateway: Use the AgentCore starter toolkit, AWS CLI, console, or SDK to create a gateway with MCP support and inbound authentication (Cognito or any OAuth 2.0 provider).
  3. Register Dynatrace MCP server as a target: Add the Dynatrace MCP Server as a Gateway Target, including OAuth credential provider configuration and scopes.
  4. Connect a Bedrock agent: Give your agent access to the Gateway and use the listTools method to verify that the MCP tools provided by Dynatrace are available.
  5. Start querying Dynatrace: Your agent can now retrieve problems, metrics, logs, traces, and other observability data exposed through the MCP Server.
The Amazon Bedrock AgentCore samples repository includes a complete, production-tested implementation of the Dynatrace MCP Server target. This implementation demonstrates how to create an MCP server that integrates with Dynatrace and can be used as a target within your AgentCore Gateway.
The reference implementation is available here
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Related to Amazon Bedrock AgentCore Gateway
AI Skills and MCP Tools logo
Dynatrace tools and skills for the AI agents you run in any MCP client.
Amazon Bedrock AgentCore logo
Monitor and trace your Amazon Bedrock AgentCore Agents.
Dynatrace Assist logo
Dynatrace Assist
Dynatrace MCP Server logo
More resources
Fuel Bedrock agents with observability data via the Dynatrace MCP Server
Give your Bedrock agents real-time system awareness
Read more
Dynatrace agentic ecosystem: Drive real outcomes, not AI pilots
Real agentic ecosystem use cases for developers, SREs, and IT Ops engineers you can implement today
Read more
Dynatrace MCP Server: Empower your AI assistants to interact with Dynatrace and access live production insights
Get real-time insights from your digital systems right inside your processes
Read more
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
