Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
AWS Strands AgentsAWS Strands Agents
AWS Strands Agents
AWS Strands Agents
Observe your AWS Strands Agents AI agents with Dynatrace AI Observability.
Technology
Free trialDocumentation
Get visibility into Agent Topology and dependency for your AWS Strands instrumented AI servicesPrompts stream showing all Agent and LLM interactions with model version, token count, agent topology, and full prompt/response contentDistributed trace showing the full Strands agent execution.
  • Product information
Overview
Get full-stack visibility into your AWS Strands Agents with Dynatrace AI Observability. Strands emits OpenTelemetry traces out of the box, but uses non-standard span attribute names for prompt and completion content. This integration normalises them into native gen_ai.* semantic conventions so you can monitor model performance, token costs, agent behaviour, and conversation flows in Dynatrace without writing custom instrumentation code.
Three instrumentation paths are supported:
  • OneAgent — auto-instrumentation with zero configuration for Python agents running on monitored hosts.
  • OpenTelemetry Collector — send traces via OTLP with attribute normalisation handled by a pre-configured collector pipeline.
  • OpenPipeline — export traces directly to Dynatrace via OTLP (no collector required) and let Dynatrace OpenPipeline normalise attributes at ingestion time.
This is intended for users who:
  • Build AI agent or multi-agent applications using AWS Strands Agents.
  • Want end-to-end tracing of agent orchestration — including prompt content, tool calls, and token usage — without writing custom instrumentation code.
Use cases
Monitor AI agent health and performance
  • Track request latency, error rates, and token consumption across models and providers.
  • Manage AI costs with token-level usage breakdowns by model and agent.
  • Enable alerting based on latency anomalies, cost thresholds, or error rate spikes in your AI workloads.
Debug agentic AI end-to-end
  • Trace complex agent orchestration with distributed traces showing prompt content, tool calls, and model handoffs across Strands cycles.
  • Pinpoint exact failure points in multi-agent pipelines with span-level detail.
  • Capture full prompt and completion content for root cause analysis.
Track agent behaviour across cycles
  • Follow multi-cycle agent reasoning loops end-to-end.
  • Isolate individual tool call performance across your agent fleet.
  • Correlate regressions with model version changes or prompt updates.
Get observability with minimal configuration
  • Use OneAgent for zero-config auto-instrumentation on monitored hosts.
  • Or run the pre-configured OTel Collector pipeline to normalise attributes before export to Dynatrace.
  • No custom instrumentation code required in either path.
Get started
Requirements
  • Python 3.10+.
  • An AWS account with Amazon Bedrock access.
  • Dynatrace SaaS with Traces powered by Grail and Metrics powered by Grail enabled.
  • A Dynatrace API token with openTelemetryTrace.ingest and metrics.ingest scopes (OTel Collector path), or a OneAgent installation (OneAgent path).
  • Do not set OTEL_SEMCONV_STABILITY_OPT_IN=gen_ai_latest_experimental. This opt-in moves prompt and completion content from span attributes into OTel log events, which are not yet supported. Leave this variable unset to ensure prompt content is captured correctly.
For detailed instructions, see the instrumentation examples on GitHub. To install the AI Observability app, see the app installation docs.
Details
OneAgent Deploy OneAgent on the host running your Strands agent. No code changes or environment variables required. See the OneAgent example.
OpenTelemetry Collector Run the pre-configured collector alongside your agent. The collector pipeline normalizes Strands' non-standard attribute names (gen_ai.prompt, gen_ai.completion, gen_ai.usage.prompt_tokens, etc.) into the gen_ai.* semantic conventions that Dynatrace AI Observability queries. See the OpenTelemetry example.
OpenPipeline Export traces directly from your agent to Dynatrace via OTLP (no collector required) and let Dynatrace OpenPipeline handle the attribute normalization at ingestion time. Deploy the pre-configured OpenPipeline definition from the OpenPipeline example to your tenant before running the agent.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Copy to clipboard
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
