Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
AristaArista
Arista
Arista
Monitor your Arista devices using SNMP.
Extension
Free trialDocumentation
Get a high level overview of your monitored Arista Infrastructure with the included dashboard.Monitor Arista device health with pre-built charts for all of your relevant metrics.
  • Product information
  • Release notes
Overview
The Arista extension leverages SNMP to gather performance and health metrics from your Arista devices every minute. This data is seamlessly integrated into Dynatrace’s Infrastructure & Operations app, offering Network and Ops Administrators quick, actionable insights at a glance.
Use cases
  • Quickly identify problematic interfaces that are dropping or corrupting packets.
  • Pinpoint hardware faults, misconfigurations or congestion issues affecting performance or reliability down to the TCP/UDP level.
  • Track real-time and historical bandwidth usage to understand traffic patterns.
  • Monitor CPU and memory consumption on Arista devices to detect potential leaks or resource exhaustion.
Get started
For more information on the installation and configuration, please see Arista extension in the Dynatrace Documentation.
Details
Compatibility information
  • SNMP v2c or SNMP v3
  • Dynatrace version 1.341+
  • ActiveGate version 1.333+
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Feature sets
Uptimecom.dynatrace.extension.network_device.sysuptimeThe time, in system ticks (1/100 second), since the last system reboot.Count
CPU usagecom.dynatrace.extension.network_device.cpu_usageThe system's CPU usage expressed as a percentagePercent
Used memorycom.dynatrace.extension.network_device.memory_usedThe amount of memory, in kilobytes, used by the deviceKiloByte
Total memorycom.dynatrace.extension.network_device.memory_totalThe total (used and free) amount of memory, in kilobytes, available on the deviceKiloByte
Interface statuscom.dynatrace.extension.network_device.if.statusA state metric representing a network interface, whose value is always 1 and its dimensions indicate its state details.State
SNMP Messages deliveredcom.dynatrace.extension.network_device.snmp.in.pkts.countTotal number of messages delivered to the SNMP entity from the transport serviceCount
SNMP Messages passedcom.dynatrace.extension.network_device.snmp.out.pkts.countTotal number of messages passed from the SNMP entity to the transport serviceCount
Silently dropped SNMP PDUscom.dynatrace.extension.network_device.snmp.silent_drops.countNumber of silently dropped SNMP PDUs due to the large reply sizeCount
Proxy dropped SNMP PDUscom.dynatrace.extension.network_device.snmp.proxy_drops.countNumber of silently dropped SNMP PDUs due to the other than a time-outCount
Unsupported SNMP version messagescom.dynatrace.extension.network_device.snmp.in.bad_versions.countTotal number of messages delivered with an unsupported SNMP versionCount
Messages with bad SNMP community namescom.dynatrace.extension.network_device.snmp.in.bad_community_names.countNumber of messages with an unknown SNMP community nameCount
Messages not allowed for SNMP community namescom.dynatrace.extension.network_device.snmp.in.bad_community_uses.countNumber of messages not allowed for the used SNMP community nameCount
'noSuchName' SNMP errorscom.dynatrace.extension.network_device.snmp.in.no_such_names.countNumber of delivered SNMP PDUs with 'noSuchName' errorCount
'badValue' SNMP errorscom.dynatrace.extension.network_device.snmp.in.bad_values.countNumber of delivered SNMP PDUs with 'badValue' errorCount
SNMP Traps processedcom.dynatrace.extension.network_device.snmp.in.traps.countTotal number of SNMP Trap PDUs accepted and processedCount
SNMP Traps generatedcom.dynatrace.extension.network_device.snmp.out.traps.countTotal number of SNMP Trap PDUs generatedCount
LLDP Neighbor Informationcom.dynatrace.extension.network_device.lldp.infoConveys information about the existing LLDP neighbor connections.State
Traffic incom.dynatrace.extension.network_device.if.bytes_in.countThe volume of traffic, in bytes, inboud to the network interface.Byte
Traffic outcom.dynatrace.extension.network_device.if.bytes_out.countThe volume of traffic, in bytes, outbound from the network interface.Byte
Errors incom.dynatrace.extension.network_device.if.in.errors.countThe number of errors, inboud to the network interface.Count
Discards incom.dynatrace.extension.network_device.if.in.discards.countThe number of discarded packets, inbound to the network interface.Count
Errors outcom.dynatrace.extension.network_device.if.out.errors.countThe number of errors, outbound from the network interface.Count
Discards outcom.dynatrace.extension.network_device.if.out.discards.countThe number of discarded packets, outbound from the network interface.Count
Interface speedcom.dynatrace.extension.network_device.if.speedThe configured speed of the network interface in megabits per second.MegaBitPerSecond
Last changecom.dynatrace.extension.network_device.if.lastchangeThe value of sysUpTime at the time the interface entered its current operational state.Count
TCP active openscom.dynatrace.extension.network_device.tcp.activeopens.countNumber of transitions of TCP connections from CLOSED to SYN-SENTCount
TCP passive openscom.dynatrace.extension.network_device.tcp.passiveopens.countNumber of transitions of TCP connections from CLOSED to SYN-RCVDCount
TCP failed attemptscom.dynatrace.extension.network_device.tcp.attemptfails.countNumber of transitions of TCP connections from SYN-SENT/SYN-RCVD to CLOSED and from SYN-RCVD to LISTENCount
TCP resetscom.dynatrace.extension.network_device.tcp.estab.resets.countNumber of transitions of TCP connections from ESTABLISHED/CLOSE-WAIT to CLOSEDCount
TCP connectionscom.dynatrace.extension.network_device.tcp.curr.estabNumber of TCP connections in the ESTABLISHED/CLOSE-WAIT stateCount
TCP segments retransmittedcom.dynatrace.extension.network_device.tcp.retrans.segs.countTotal number of segments retransmittedCount
TCP segment errorscom.dynatrace.extension.network_device.tcp.in.errors.countTotal number of segments received in errorCount
TCP segment resetscom.dynatrace.extension.network_device.tcp.out.rsts.countNumber of TCP segments sent containing the RST flagCount
UDP datagrams received without portcom.dynatrace.extension.network_device.udp.noports.countNumber of received UDP datagrams (no application at the destination port)Count
UDP datagram errorscom.dynatrace.extension.network_device.udp.in.errors.countNumber of received and not delivered UDP datagrams (other than no application at the destination port)Count
Multicast packets incom.dynatrace.extension.network_device.if.in.multicast_pkts.countThe number of multicast packets, inbound to the network interface.Count
Multicast packets outcom.dynatrace.extension.network_device.if.out.multicast_pkts.countThe number of multicast packets, outbound from the network interface.Count
Broadcast packets incom.dynatrace.extension.network_device.if.in.broadcast_pkts.countThe number of broadcast packets, inbound to the network interface.Count
Broadcast packets outcom.dynatrace.extension.network_device.if.out.broadcast_pkts.countThe number of broadcast packets, outbound from the network interface.Count
Unicast packets incom.dynatrace.extension.network_device.if.in.ucast_pkts.countThe number of unicast packets, inbound to the network interface.Count
Unicast packets outcom.dynatrace.extension.network_device.if.out.ucast_pkts.countThe number of unicast packets, outbound from the network interface.Count
BGP Peer Connection Statecom.dynatrace.extension.network_device.bgp4.stateThe current state of the BGP peer connection. Possible values are idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6).State
BGP Peer Admin Statuscom.dynatrace.extension.network_device.bgp4.admin.statusThe desired state of the BGP connection for this peer. Possible values are stop(1), start(2).State
BGP Peer Established Timecom.dynatrace.extension.network_device.bgp4.established_timeThe time in seconds this peer has been in the established state or how long since this peer was last in the established state.Second
Full version history
ReleaseDate
✨ New in this version:
Initial extension release including:
  • Overview of Arista devices and detailed metrics and topology info about resources, traffic and peers using rich visualization features.
  • Bundled overview dashboard to view Arista data at a glance.
  • Classic and smartscape 2.0 nodes created for network devices and interfaces.
Warnings/action required:
  • This version requires a minimum Dynatrace version of 1.341 and a minimum ActiveGate EEC version of 1.333
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
