Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
SyntheticSynthetic
Synthetic
Synthetic
Monitor your application's health around the world and around the clock.
App
Try in PlaygroundDocumentation
List of synthetic monitors with powerful filters, key metrics, and a preview panel showing config details and recent execution resultsShows execution results for a test, highlighting availability and performance, with details at both monitor and step levelsCompare past HTTP monitor runs to spot slowdowns, failures, or improvements, with diffs in load times, codes, errors, and payloadsDefine this monitor’s scope and config: frequency, locations, success criteria, and rules for triggering problemsConfigure this private synthetic location: geo position, assigned ActiveGates, and rules for self‑monitoring problem triggers
  • Product information
  • Release notes
Overview
Synthetic is an application for managing all your synthetic tests. It's where you can analyze the latest and historical execution results of your synthetic tests, create new tests, and adjust the configuration of existing tests. Additionally, you can use the web UI to trigger on-demand execution of synthetic tests.
Use cases
  • Automatically monitor and test application availability and performance across production and development environments.
  • Fix issues and optimize digital experience before users are affected.
  • Synthetic capabilities are extended to monitor infrastructure and services that don't expose HTTPS-powered interfaces.sdsd
Get started
Start off by setting up a private location for executing your synthetic tests. Then, create a new monitor using a protocol of your choice.
Details
The Synthetic app allows proactive, around-the-clock checks of application availability and performance by simulating user interactions across environments and geographies. Synthetic supports multiple monitor types, including HTTP monitors for API checks, single-URL browser monitors for page-level testing, browser clickpaths for complex workflows, and NAM monitors for network availability. The app serves as a central control hub, offering a comprehensive view of all monitors with filtering, quick-overview panels, performance metrics, and execution history. Additionally, it supports on-demand executions and integration with Synthetic for Workflows to trigger tests based on event-driven automations, enabling tight release validation and resilience checks. Finally, it facilitates monitoring from both public and private locations, with secure communication architecture via ActiveGate and token-based encryption, ensuring data integrity across the monitoring infrastructure.
Dynatrace
Documentation
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
1.15.3
Patch Changes
  • 4f393fb: Fixed missing permissions warning on the monitor edit page for users with security context restricted access.
1.15.2
Patch Changes
  • b30f4d5: Fixed overriding frequency to 1 minute when editing HTTP and NAM monitors.
1.15.1
This version introduces linking to Distributed Tracing app from executions and requests on Analyze executions page for browser monitors. Additionally, latest maintenance windows are now marked over the availability chart on the monitor reporting page along the classic ones and tenant-level "Exclude periods with maintenance windows from availability calculation" setting is taken into account when calculating the average monitor availability.
Minor Changes
  • 2b46ba1: Added execution type (Standard or On-demand) column to the executions table on the Analyze executions page for browser monitors.
  • f4db57e: Added handling of new browser monitor error code (1309 - Wait for user actions timeout).
  • f4db57e: Added handling of new browser monitor error code (12232 - ERR_BLOCKED_BY_ORB).
  • 1fce2a7: Added cross-origin frame monitoring configuration to the browser monitor configuration page — users can now choose between same-origin and all frames.
  • aec50f8: Added per-step request timeout on HTTP monitors configuration page.
  • 73dbb91: Added support for assigning mobile frontends to HTTP monitors.
  • dbd4f78: Added health alert tooltips with details on the private locations page.
  • 293b706: Added ready-made dashboard for understanding Synthetic Monitoring usage and estimated cost.
Patch Changes
  • dae14fa: Fixed handling of unknown constraint names in NAM monitor steps configuration.
  • c324e61: Fixed outage settings not being reflected in the summary when creating a new browser monitor.
  • 1777143: Fixed handling of 403 error thrown when fetching tenant defaults for outage handling and browser monitors on latest Dynatrace settings on monitor configuration page.
  • a6842e5: Fixed error handling when location is not found on private locations page.
  • e1f8485: Fixed refreshing ActiveGate list when navigating between private location details.
  • c76f397: Fixed an issue where private locations with multiple execution engines incorrectly showed "Capacity" indicator alerts even when the actual load was within acceptable limits.
1.15.2
Patch Changes
1.15.1
Minor Changes
Patch Changes
1.15.1
Minor Changes
Patch Changes
1.14.3
Patch Changes
  • 5187f94: Improved management zones to security contexts migration dialog with clarifying descriptions and a more intuitive layout. Added a link to documentation.
  • 682a124: Fixed the issue with no monitors displayed after migration to Smartscape on tenants without Dynatrace Platform Subscription.
  • 2c00106: Fixed incorrect ms/s unit conversion for HTTP monitor performance threshold that prevented performance alerts from triggering.
1.14.2
Minor Changes
  • 6014843: Added triggering automatic migration of management zones to security contexts for synthetic monitors (available from the gear icon in the app header).
  • 9121fed: Improved presentation of errors if any are returned when fetching data from Grail.
  • 58f25b0: Improved permissions handling in consumption info within Properties card on monitor reporting page.
  • ab07f95: Added filtering by primary Grail tags to the Smartscape monitor list.
  • a447209: Extended the group of permissions required to view the private locations page.
Patch Changes
  • 1777143: Fixed handling of 403 error thrown when fetching tenant defaults for settings in monitor wizard.
  • 1fe4c81: Fixed deserializer error in the monitor wizard.
  • 4b0623b: Fixed displaying onDomContentLoaded phase in the request waterfall on Analyze executions page for browser monitors.
  • c2d429e: Improved request types displayed in the request waterfall on Analyze executions page for browser monitors.
  • 68520aa: Fixed response time threshold line displaying at incorrect value on HTTP monitor performance charts.
  • 3096fce: Fixed handling of postMessage in the Synthetic Recorder.
  • c320f5d: Fixed filtering by locations on monitor reporting page.
  • 185d1bd: Fixed gap in data on Analyze executions page for HTTP monitors.
  • 158477c: Fixed dashboard tiles ignoring the global timeframe selector and always showing data for the last 24 hours.
1.14.2
Minor Changes
Patch Changes
1.13.1
This version introduces support for security context and new synthetic permissions, as well as support for Smartscape on Grail for synthetic monitoring. Learn more about access control in the documentation and about Smartscape on Grail in the documentation.
Minor Changes
  • 148118f: Unified monitor actions (edit, duplicate, enable/disable, delete) available from the three dot menu on monitor list.
  • e42940b: Added information about the monitor being currently disabled on the monitor reporting page.
  • c0cabb7: Added a comparison between expected and actual screenshots on Analyze executions page for browser monitors.
  • 6526dd9: Removed quantifier field in the constraints and adjusted operators to cover cases when quantifier was set to "Fail if" on HTTP monitor configuration page.
  • d53ea89: Added advanced settings of performance threshold to browser monitor configuration.
  • ecb8018: Auto-enabled the new browser monitor experience for new browser monitors.
  • af595fe: Auto-enabled "Capture performance metrics for pages loaded in frames" option for new browser monitors.
  • 4f298da: Added handling of outage handling settings origin in NAM monitors.
Patch Changes
  • 0a60709: Fixed missing information about synthetic actions/requests/data points consumption for a specific monitor in the selected timeframe on monitor reporting page.
  • eeeecb2: Fixed displaying multiple rows with the same page id and view id in pages chart on Analyze executions page for browser monitors.
  • 74aa9d4: Fixed displaying executions for deleted locations on Analyze executions page for browser monitors.
  • f9358cb: Fixed displaying unknown HTTP status code in the on-demand executions table.
  • 58b7e46: Fixed dragging JavaScript type steps to first position in browser monitor steps configuration.
  • 901c72f: Fixed passing HTTP headers during browser monitor clickpath recording.
  • 438b477: Fixed status code and regex validation in HTTP monitor step constraints.
  • 7c4d61b: Fixed how performance thresholds behave for HTTP monitor type after adding a step, removing it or duplicating it.
1.12.3
Patch Changes
  • ad68b7e: Fixed the handling of missing New Browser Monitoring Experience in browser monitor configuration.
1.12.2
Minor Changes
  • 45663d6: Added displaying user actions in requests waterfall on Analyze executions page for browser monitors.
  • f0161f4: Added highlighting pages related to selected step on Analyze executions page for browser monitors.
  • 71142f6: Added steps screenshots on Analyze executions page for browser monitors.
  • aeaaf23: Added execution end column on Analyze executions page for browser monitors.
  • 4362232: Added information tooltip for duration column on Analyze executions page for browser monitors.
  • 57a2690: Improved tooltips in pages chart on Analyze executions page for browser monitors.
  • 86a9019: Introduced minor improvements to the Analyze executions page for browser monitors like a search field and table toolbar for the list of executions.
  • 7999730: Handled the case when browser monitor execution analysis page is loaded from a link and the selected execution is outside the selected timeframe.
  • 7999730: Handled a case when timeframe for browser monitor execution analysis is changed to one that doesn't include the selected execution.
  • 5029e3a: Added possibility to use tenant-level outage handling settings on browser monitor configuration page.
  • 7225343: Added possibility to configure local outage for all locations assigned to monitor.
  • 87c5a2c: Added handling of new browser monitor error code (1308 - Wait for next step element timeout).
  • 0037cbb: Changed permissions required to view private locations page from environment:roles:manage-settings to environment:roles:viewer. Creating, modifying and removing a private location still requires environment:roles:manage-settings permission.
Patch Changes
  • 45663d6: Fixed displaying requests waterfall from start of the view on Analyze executions page for browser monitors.
  • 6d0718d: Fixed displaying soft navigations in pages chart on Analyze executions page for browser monitors.
  • 683d537: Fixed calculating processing duration on waterfall chart on Analyze executions page for browser monitors.
  • c083722: Fixed missing execution start time in browser monitor execution analysis, event timestamp is shown in such cases.
  • 95b13cd: Fixed handling of empty pages on Analyze executions page for browser monitors.
  • d8db99f: Fixed displaying view URL on Analyze executions page for browser monitors.
  • 380d9c5: Fixed handling third-party monitors on monitor list page.
  • bd778d0: Fixed issue with reading segments on monitor list page.
  • 5c51e99: Fixed parsing credentials in JavaScript steps on browser monitor configuration page.
  • e5e172f: Fixed validation of bandwidth profile on browser monitor configuration page.
  • c2fb9fe: Fixed possibility to edit monitor in script mode.
1.12.2
Minor Changes
  • af15b23: Added possibility to pin filters on monitor list page.
  • af15b23: Added displaying recently used filters on monitor list page.
Patch Changes
1.11.5
This version introduces the Overview page, which provides a comprehensive view of all monitor types with their status highlighted and links to recommended dashboards. The Overview page is now set as the default landing page. Additionally, this version includes a permissions information page that displays when users lack the minimum required permissions to use the app.
Minor Changes
  • 7d4d23e: Changed the browser monitor duration metric displayed in tables, charts and tiles to dt.synthetic.browser.duration. Also removed the no longer necessary information about the selected duration metric and the option to configure the browser monitor performance metric.
  • 0505b84: Added highlighting of requests on waterfall chart by selected step on Analyze executions page for browser monitors.
  • 0f2f5cb: Introduced minor improvements to the Analyze executions page for browser monitors (all sections are displayed right away, failing steps are marked in the step selector, waterfall section title indicates the selected page etc.).
  • 1e63cdf: Added the number of matches in filters on monitor list page.
  • fbf6df4: Added filtering monitor list by location IDs and frontend IDs.
  • b19420c: Added handling of View metric button on monitor list page.
Patch Changes
  • ea63f3d: Fixed flickering app header on narrow screens.
  • 7c055c0: Fixed respecting timeframe by Failed requests chart on monitor's preview.
  • 3012520: Removed options that are specific to numerical values from the frequency filter suggestions.
  • c3ffd79: Fixed calculating local cache in tooltip on waterfall chart on Analyze executions page for browser monitors.
1.10.1
This version introduces the browser monitor execution analysis page, which can help you detect and isolate specific resources in specific executions that compromise overall performance. Additionally, Primary Grail Tags are now supported in synthetic monitor configurations. Other changes include:
Minor Changes
  • 1b629af: Added "Ignore certificate errors" switch in advanced browser monitor configuration.
  • fabb9e6: Added history of changes in configuration to browser monitors' reporting pages.
  • 851c4ee: Included not triggered executions in the list of on-demand executions of synthetic monitors.
1.9.3
Patch Changes
  • b342fae: Fixed issue with app crashing for user without 'environment:roles:viewer' permission.
1.9.2
Patch Changes
  • 2ae618d: Fixed passing manually provided credentials to the browser monitor recorder.
1.9.1
Patch Changes
  • a2049ec: Fixed issue after clicking "Analyze executions" button on HTTP monitor execution analysis page.
1.9.0
This version introduces a redesigned monitor list with health alerts, more powerful filtering, including support for segments.
Patch Changes
  • c5792b6: Fixed displaying plain text values in Keystroke steps on browser monitor configuration page.
  • 8c13655: Fixed issue with editable steps during recording or testing clickpath in browser monitor configuration.
  • 86f1d44: Fixed issue with deleting step from HTTP monitor configuration.
  • f17cf2b: Fixed filtering by monitor name that includes quote marks.
1.8.5
Patch Changes
  • 5454735: Fixed metric name used in dashboards.
1.8.0
This version introduces the browser monitors executions analysis, as well as new browser monitoring experience powered by the latest JavaScript Agent. The configuration of containerized private locations like Kubernetes and OpenShift is now available right in the app. Other changes include:
Minor Changes
  • 131c88e: Added a column displaying location health alerts to the private locations table.
  • 518788c: Added Diagnostics section to private location details.
  • b4016ce: Added search functionality to the Device select in browser monitor configuration.
  • 447ff57: Made performance metric shown in browser monitor reporting dependent on the settings selected for the tenant or a single monitor.
Patch Changes
  • c7e3f37: Fixed not visible data points in aggregated performance chart.
  • a293862: Fixed the displaying of per-step performance metrics for browser monitors.
  • bc4f5ff: Fixed a credential appearing twice in the credentials pop-up when it is used in two different steps.
  • 087004e: Fixed an issue where a disabled monitor could be unintentionally enabled after a configuration change.
  • 0c9b2aa: Fixed incorrectly labeled column (Error rate to Success rate) in the Web availability and performance dashboard.
  • 2099741: Fixed error thrown on the reporting page when 'subtype' property is missing.
  • 854eaed: Fixed manually provided credentials in the initial step being passed to the recorder.
1.8.4
Patch Changes
1.8.0
Minor Changes
Patch Changes
1.7.5
Patch Changes
  • 862ff8d: Fixed the displaying of per-step performance metrics for Browser Monitors
1.7.4
This version introduces the configuration of Browser monitors: you can now create and edit Browser monitors right in the app. Other changes include:
Minor Changes
  • 8ce6263: Improved ready-made synthetic dashboards, which included rearranging tiles, adjusting visualizations and colors, adding descriptions and links, fixing filters.
  • 684db7d: Added annotation for location offline in the availability chart on monitor details page.
  • 98eb09b: Improved average availability query replacing average with weighted average.
  • ab63986: Changed the format of the selected time range in the URL.
  • 359b145: Redesigned summary step in monitor configuration wizard.
Patch Changes
  • afcb2e0: Fixed consumption info for the timeframe of last 7 days on monitor details page.
  • bd21546: Fixed adding https prefix for target selection in HTTP monitor configuration wizard.
  • 199bba2: Fixed incorrect number of all locations for the local outage in monitor configuration wizard.
  • 294dc0f: Fixed an issue for private locations where the geographic location stays empty due to an undefined value.
  • 88c4fe3: Fixed error thrown on the reporting page when 'subtype' property is missing from the monitor configuration.
1.6.5
Patch Changes
  • b22f2b9: Updated network availability monitoring dashboard.
  • 86ee912: Fixed link to create NAM monitor from help menu.
1.6.0
Minor Changes
  • 190c7c7: Added history of changes section on HTTP and NAM details page.
  • 41ac6d0: Added frontends section on HTTP and browser monitors details page.
  • f168493: Moved locations section from properties to a separate section on monitor details page.
  • b375953: Added 'Disabled' status for inactive monitors on details page.
  • 422f371: Improved on-demand execution table with handling changes of execution stages and additional table options.
  • 8c8790c: Improved triggering of new on-demand executions according to user permissions.
  • dc8fd46: Improved handling of permissions for creating, modifying and deleting synthetic monitors.
  • d26363b: Added information about missing user permissions to the map of locations with last execution statuses.
  • 7dd5cdb: Added a tooltip for tags that exceed display limits, displaying the full value.
  • 4d51a55: Added reordering and resizing columns in monitor list and private locations list.
  • 8ca939a: Added sorting to location table on the monitor configuration wizard in the step "Frequency and locations".
  • 8e50251: Improved the description of required permissions to use Synthetic app.
  • 9a3a67b: Replaced the app icon.
Patch Changes
  • 93a7432: Fixed displaying selected inaccessible credential in HTTP monitor configuration.
  • 7a58a8c: Fixed handling invalid monitor id or type in the URL.
  • 874590f: Fixed truncation long request names in the errors section.
  • 71da1b1: Fixed performance issues for queries fetching outage and slowdown data.
  • 67ee8cd: Fixed validation of HTTP urls without top level domain.
1.5.3
Patch Changes
  • dfc21f8: Temporarily removed the option to exclude maintenance window periods from average availability calculation.
1.5.2
Minor Changes
  • 8f463f6: Added warning about capabilities unsupported by a location on private locations page.
  • a569196: Added zoom for screenshots in "Synthetic steps and actions" section on browser monitors reporting page.
  • 17e5bfb: Used the 'Exclude periods with maintenance windows from availability calculation' tenant setting in calculating the average availability value.
  • 7a7fa6a: Updated the label for the location outage handling switch to reflect the changes in the scope of this flag (problems will also be generated when a capability required to execute monitors of a given type is missing).
  • be96350: Added displaying performance threshold violation on the step level in the browser monitor details page.
Patch Changes
  • 019a366: Improved calculation of monitor's total downtime.
  • e064991: Fixed redirection of "Analyze Errors" button in the browser monitor details page.
  • 644abd2: Fixed saving automatically applied tags while editing network availability monitors.
  • 93f28ea: Added alphabetical sorting for tags.
1.5.2
Minor Changes
Patch Changes
1.4.1
Minor Changes
This version introduces the reporting of Browser monitors, as well as the features shown below.
  • adde7f5: Displayed performance data for requests executed within the selected timeframe but no longer present in the monitor configuration.
  • bbfb5a0: Added links to the Distributed Tracing app on the HTTP monitor reporting and execution analysis pages.
  • 72615a4: Added a column displaying the location ID in the private locations list table.
  • 900d536: Added a world map showing monitor locations to the reporting page.
  • 6cec913: Added a map to the "Frequency and Locations" step when editing a monitor.
Patch Changes
  • 01c42b8: Updated the ready-made dashboards and added the word "Synthetic" to their names.
  • 4f753c5: Fixed the preservation of timeframes originating from intents.
1.3.1
Minor Changes
  • de606e1: Added annotations in the availability chart for new execution statuses like "Attempted but no result", "Suppressed by maintenance window", "Discarded without execution attempt", and "Missing location capability".
  • 71cb329: Added timeframe to URL so shared links open the app with the desired timeframe selected.
  • 24a4806: Moved timeframe selector, create new monitor, and create new location buttons from the app header to the respective pages content.
  • 5466a64: Added requirement of "manage settings" role with no restrictions to create a synthetic monitor.
  • 06fb5ea: Updated ready-made dashboards.
Patch Changes
  • 6dfbce5: Fixed error code in the legend and missing data on either end of X axis in the failed requests chart for HTTP monitor
  • 0b0a3a6: Changed the default value for Accept any SSL certificate property in the HTTP monitor step configuration to false.
  • 0d2f6c6: Fixed events chart - an event is shown in all intervals it appeared instead of just in the last one.
  • 45d384a: Fixed calculation of affected locations and last known status for long time ranges.
1.2.5
Patch Changes
  • 917d696: Unified average availability values and colors in monitor list and quick overview
  • 09a3d83: Fixed the link to browser monitor creation wizard on the welcome page
  • 687de98: Fixed monitor types supported by an ActiveGate shown in ActiveGates section of private locations details
  • 59d222c: Fixed showing browser monitors screenshots thumbnails on monitors list page
  • 38ffc19: Fixed enabling performance thresholds for NAM when no thresholds are set
  • 7201583: Fixed 'subquery read too much data' error when a longer time frame is selected for querying problems
1.2.4
Patch Changes
  • b4f74f9: Improved validation for private location name - the name is required and can consist of at most 64 characters
  • 1c88416: Improved response time for creating, updating and deleting private locations
  • 63819db: Added ActiveGates column to private location list
  • c881485: Fixed queries that timed out when a longer time frame was selected
  • e76bb94: Added information about configured locations on the monitor reporting page
  • 582b0d1: Improved handling of missing permission to fetch geographic location data
  • 4b166f5: Added a link to on-demand executions page for SKU based tenants
1.2.3
Patch Changes
  • 87fd4e9: Fixed access to relevant actions on executions chart, changed the default chart mode to breakdown by status and used status colors for series in this mode
  • bc1cf91: Fixed access to step configuration for HTTP monitors
  • 998e4ee: Fixed the color of links in private location list
  • 89c2399: Fixed differences in querying data for table and chart in Events section for HTTP monitor
  • e1e17e8: Unified icon colors depending on the selected app appearance mode
1.2.2
Patch Changes
  • 6d8661f: Added chart to "Failed requests" section for HTTP monitors
  • de3dad5: Updated the monitor configuration form validation method
  • 69cde7d: Added an icon representing the location type in the private location listing
  • 0a4e05b: Performance of fetching filters for monitor list improved
  • e2ab8ca: Fixed settings visible for containerized locations.
  • 13bc851: Problem card improvements - added affected locations and steps
  • 7e6e2e7: Fixed calculation of monitor total downtime
  • 54b38a6: Fixed opening details for third party monitors
  • 8291b2d: Unified aggregation mode toggles for charts
  • cf87e92: Security context access validation added
  • 9905261: New help menu
1.2.1
Patch Changes
  • 0b0c797: Limit on the number of monitors for bulk actions
  • 8d4722f: Fixes for execution details page issues
  • a67e896: Fix for location list refreshing issues
1.2.0
This version introduces configuration, reporting and execution analysis for HTTP monitors and private synthetic locations management.
Minor Changes
  • d6501da: Comparing two HTTP monitor executions
  • b031a70: Added analyze executions page with executions chart for HTTP monitors
  • a89b755: Presenting problems in requests table for HTTP monitors
  • 1edc292: Added assigning frontends to HTTP monitor
  • ad2b8d4: Added custom geolocation modal
  • 18e0c0b: Blocked editing HTTP monitor containing not accessible credentials
  • 05c8477: Added private location expandable details view
  • 9ac2a2f: Added update functionality for private location details view
  • f57ee1c: Added table with ActiveGates to configure classic private location
  • 6e16dd3: Allow multiple constraints of the same type for HTTP monitors
  • 1bbe957: Enabled deleting private location
  • e2baca3: Enabled saving synthetic private location
  • c74ca44: History of changes in HTTP monitor configuration
  • cab999f: Created page for configuring classic private location
  • 3512863: Availability section for HTTP monitor
  • d093cd4: HTTP monitor steps configuration
  • 43e61aa: Response size section in HTTP monitor reporting
  • 02a9442: Performance section in HTTP monitor reporting
  • 2a3a28d: HTTP requests section on reporting page
Patch Changes
  • dfcfedb: Availability and performance indicators are not chips anymore
  • 7911de8: HTTP monitor execution details include data from both base and detailed synthetic events
  • 71304f8: Showing only assignable ActiveGates in ActiveGates table
  • d393fff: Improved data refresh in private location list and private location details
  • c8a0d95: On demand execution page header improvements
1.2.4
Patch Changes
1.2.3
Patch Changes
1.2.2
Patch Changes
1.2.1
Patch Changes
1.2.0
Minor Changes
Patch Changes
1.2.3
Patch Changes
1.2.2
Patch Changes
1.2.1
Patch Changes
1.2.0
Minor Changes
Patch Changes
1.2.2
Patch Changes
1.2.1
Patch Changes
1.2.0
Minor Changes
Patch Changes
1.2.1
Patch Changes
1.2.0
Minor Changes
Patch Changes
1.1.1
Patch Changes
  • 240c628: Microguide has been added
  • ec25909: Fixed table layout
  • e3193e1: Added dashboard definitions
  • c74ca44: Changes history for HTTP monitors
  • c8a0d95: On demand execution header improvements
  • cd41b30: Fixed saving DNS monitor with subnet
  • bde4649: Fixed displaying creation date when author is not available
  • d80e149: Monitors list sorting logic improved
  • 56427a6: Moved selection of monitor type to be created to dropdown menu
  • 5be41e6: Visual improvements to outage and performance wizard step
  • f69fbbb: Enabled multiple selection for DNS record type
  • f9e7679: Added welcome page
  • ca79e43: Improvement of welcome page
  • 154c5de: Adding download as csv button to: monitor list table (main page), on-demand executions table, NAM requests table
  • 7c670a7: Adding function for converting date to csv summary
  • 19b4b23: Adding tooltip for MonitorList name filter
  • 5b72c4e: Hiding relevant settings in the wizard for missing read permissions to a given schema
1.1.0
This version includes improvements for the monitor list and network availability monitor configuration as well as bug fixes.
Minor Changes
  • 20eadf9: Problems column and indicators added to the monitor list. Updated queries for problems and events.
  • df4a841: Consumption calculation for an existing network availability monitor added to the properties section.
  • d694915: Added interface for other Dynatrace Platform apps.
  • 52501cd: Both target list and target filter can be set at the same time for network availability monitors.
  • 398472c: Added warning for locations not supporting the type of monitor being created or modified.
  • 8895460: Two-way linking to the new Problems app
  • 4be232c: New UI for network availability monitor performance threshold configuration
  • 392eecc: Allow IPv6 address as a target
Patch Changes
  • b7f930c: Fixed error raised when pressing Enter with no monitor selected.
  • 5bf6fb3: Fix for on-demand executions refresh
  • 71a0a55: Fix for displaying tags with escaped chars
  • c2e6fb9: Added information whether performance thresholds are enabled in the wizard summary step.
  • 92ac5b6: Allowed underscores in target domains.
  • 164a31a: Fixed missing performance metric for third party monitors.
  • 01b8a0b: Minor improvements for locations filter (sorted by name and cloud provider shown next to location name)
  • 978e15c: Improved handling of on-demand executions triggered outside currently selected time frame.
  • e8160ba: Fixed TCP port unreachable constraint causing validation error.
  • d6974e7: Fixed saving outage handling settings.
  • e7ad1dc: Fixed 404 error returned when going to problem details.
1.1.0
Minor Changes
Patch Changes
1.0.1
The first version of Synthetic app released. Synthetic is an application for managing all your synthetic tests. It is the place where you can analyze latest and historical execution results of your synthetic tests as well as create new tests and adjust configuration of existing ones. This version fully supports network availability monitors only, while detailed information and configuration for HTTP and browser monitors are temporarily delivered with the Synthetic Classic app. The app is released as on-demand.
1.0.0
Minor Changes
  • 71def31: Availability and Success Rate sections are collapsed when metric values are 0% or 100%
  • 998b7c8: Threshold indicator on performance chart and problem annotations added for NAM monitors
  • 660a5c7: Added duplicating HTTP and NAM monitors
  • 5bcbb0e: Fetching on-demand executions as app function
  • a89c2a4: Added new tab and logic to NAM Performance chart
Patch Changes
  • df27a2f: Changing active property to enabled for NAM monitors
  • 6e74a66: Refactoring query keys assignment
  • 8d42d8c: Locations available in wizard and on-demand execution limited the ones the monitor can be executed on
  • 0eeb3a4: Narrow performance aggregation options to avg, min, max
  • bd82716: Improvements and fixes to charts on NAM reporting page
  • fdaa98f: Fix for fetching on-demand executions and locations
  • 917016b: Updated query for on-demand executions
  • eef3a41: Http request type selection removed
  • 9669e93: Enabled editing checked monitor
  • a1c47c2: DNS validation improvements
  • c8a7a8b: add on-demand page
  • d3e9bf2: Duration for NAM monitors depends on monitor subtype
  • 5531bfc: minor improvements
  • db7ef5f: add estimated cost for nam monitors
Dynatrace Hub
All (959)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
