Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
SnykSnyk
Snyk
Snyk
Ingest Snyk vulnerability findings, scans, and audit logs.
Extension
Free trialDocumentation
Vulnerability findings overview.Security coverage overview.Sample Jira workflow.Sample Slack workflow.
  • Product information
  • Release notes
Overview
Dynatrace integrates with Snyk products to enable visibility, orchestration, and prioritization of code, library, and container vulnerability findings.
Capabilities:
  • Single pane of glass: Ingest vulnerability findings, scan events, and audit logs from Snyk products into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps the findings to a unified format for vulnerability findings (powered by Dynatrace Semantic Dictionary)
  • Findings operationalization: Prioritize, visualize, and automate vulnerability findings with runtime context
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC)
Use cases
  • Overview: Visualize and report your current security posture and trends around vulnerability findings across vulnerability scanners with Dashboards.
  • Prioritization: Analyze and prioritize vulnerability findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical vulnerability findings with Workflows.
  • Investigation: Use vulnerability findings as an additional dimension for threat hunting and incident forensics using Security Investigator.
Get started
For more information on the installation and configuration, please see Snyk extension in the Dynatrace Documentation.
Details
Compatibility information
  • Snyk REST API v2
  • Snyk v1 API
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Snyk
ActiveGate logo
ActiveGate
Route traffic, monitor clouds and remote technologies & run Synthetic monitors
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Extensions logo
Extensions
Manage Dynatrace extensions for hundreds of technologies.
Full version history
ReleaseDate
🚀 Improved in this version:
  • Vulnerability finding events now have vulnerability.cvss.base_score and vulnerability.cvss.vector fields.
ℹ️ This version requires ActiveGate version 1.313.0 or higher.
  • Ingested security events are now enriched with the fields dt.security_context, dt.cost.costcenter and dt.cost.product defined in the monitoring configuration.
  • Adjusted mappings for vulnerability findings and scan events:
    • Added a new field finding.type.
    • Events for which object.type was mapped to snyk.project now have object.type mapped to a semantic dictionary type. ⚠️ Dashboards and automations which were explicitly filtering for object.type == snyk.project will need to be updated ⚠️
    • object.name is now aligned with artifact.name.
    • Mapped artifact and code namespaces where relevant.
  • Added proxy support to connect to the Dynatrace environment.
  • Updated dashboards.
  • Added an optional filter for issue severity type.
  • Added an optional filter for project origin.
🪲 Fixed in this version:
  • Fixed issue where audit logs would not be properly collected when monitoring multiple organizations.
  • Fixed another issue where events would be missed due to ActiveGate timezone mismatches.
  • The field finding.url is now populated with the issue URL for finding events.
  • Fixed issue where events would sometimes be missed if the extension execution time exceeded the configured value.
  • Fixed issue where events would be missed due to ActiveGate timezone mismatches.
  • Fixed some of the out-of-the-box dashboard tiles showing errors.
  • The fields dt.extension.config.id and extension.config.name were added to the ingested audit logs.
  • To align with the new security.events OpenPipeline endpoint, the bundled ready-made dashboards now query this table instead of events. We recommend all users to adjust their monitoring configurations to ingest data to this new endpoint. You can find the official guidance here.
  • Project tags for scan events are now properly formatted.
ℹ️ This version requires ActiveGate version 1.299.0 or higher.
  • Improved logging when no Snyk organizations are found.
✨ New in this version:
  • Added five ready-made dashboards which are deployed upon installing the extension.
  • It is now possible to separately toggle audit log and security events ingest.
⚠️ Breaking change -- This change requires monitoring configurations to be recreated upon upgrading the extension as the auto-update will fail ⚠️
  • Fixed bug where an organization with no projects would cause the extension to crash.
  • Fixed bug where container image digest would not be properly reported for scan events.
  • Improvements to avoid memory-usage issues when working with a large number of projects
  • When container related findings are reported, the container ID is reported as well as the container digest, since the digest is sometimes not available. Since this fix requires access to a new API, the permissions required have been updated. Please refer to the official documentation.
  • The Dynatrace severity score for vulnerability findings is now mapped from the severity level provided by Snyk instead of the CVSS score, due to a misalignment between the two.
  • Added vulnerability finding and scan event monitoring.
  • Added audit log monitoring.
Dynatrace Hub
All (883)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
