Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Security EnrichmentSecurity Enrichment
Security Enrichment
Security Enrichment
Connect any HTTP-based threat intelligence source to enrich observables.
App
Free trialDocumentation
Flow diagram.Security Enrichment Overview
  • Product information
  • Release notes
Overview
Dynatrace Security Enrichment enables you to integrate threat intelligence services — commercial, open-source, or proprietary — to enrich security observables such as IP addresses with reputation, geolocation, and contextual data.
Security Enrichment provides a unified management interface to define HTTP-based enrichment connections, configure vendor-specific options, map responses to a normalized schema, and share connections across your team.
Key capabilities
  • Custom connections: Define HTTP request templates (method, URL, headers, query parameters, body) to call any REST-based threat intelligence API. Use placeholder variables such as {{observable.value}} and {{authentication.secret}} for dynamic request composition.
  • Vendor blueprints: Get started faster with pre-configured templates for popular providers such as AbuseIPDB and VirusTotal. Blueprints prefill the connection wizard with recommended defaults — just add your API key.
  • Response mapping: Transform raw vendor JSON responses into Dynatrace's normalized enrichment report schema (mappedResponse) using DQL-based mapping. This ensures consistency of enrichment results across vendors and prepares the data for downstream use.
  • Caching: Reduce latency and external API quota consumption through caching of enrichment results.
  • Workflow action: Use the included workflow action in Workflows to enrich observables in automated triage, response and remediation playbooks.
  • Custom options: Configure vendor-specific parameters (for example, maxAgeInDays or verbose for AbuseIPDB). These are validated and applied at execution time.
Use cases
Security Enrichment–powered contextualization of observables enables:
  • Threat-informed security investigations: Enrich IP addresses with reputation data, geolocation, abuse reports, and additional context to detect anomalous and malicious activity in Investigations.
  • Automated threat-alert triaging: Classify and prioritize security alerts using enriched threat intelligence in Workflows. Build automated SOAR playbooks that branch on reputation scores, escalate malicious findings, and suppress known-benign noise.
  • Enhanced threat detection findings: Add external enrichment data to IP addresses in Threats & Exploits for faster, more accurate decision-making.
  • Bring your own enrichment: Connect proprietary intelligence feeds, such as MISP or internal services, that are not natively supported to operationalize your existing threat intelligence feeds and internal data sources inside Dynatrace.
Are you looking for additional use cases and functionality? Let us know in the Dynatrace Community Forum!
Get started
For setup and configuration instructions, see Security Enrichments.
Details
Vendor blueprints
Blueprints are Dynatrace-governed, read-only templates shipped with the app. They prefill the connection wizard with tested configurations for specific vendors. Blueprint updates are delivered through new app versions and apply only to newly created connections — existing connections are not modified.
Currently available blueprints:
  • AbuseIPDB — IP reputation checks using the AbuseIPDB Check endpoint.
  • VirusTotal — IP address reports from the VirusTotal API.
Migration
Users of the standalone AbuseIPDB or VirusTotal apps can migrate to the built-in blueprint connection. See migration guide
Outbound connectivity
Custom enrichment connections call external endpoints from the Dynatrace platform. Depending on your network setup, you may need to allowlist the outbound domains used by your enrichment connections.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Full version history
ReleaseDate
Fixes and maintenance
  • Dependency updates
1.10.0
  • Fix the test connection dialog showing two scrollbars and scrolling past the Close button after a connection test
  • Update the Strato design system components
  • Bump dependencies to their latest versions
What's Changed
  • Migrate from SIE client v1 to v2
1.8.0
  • Bump dependencies for vulnerability fixes
What's Changed
1.5.0
Feature updates
  • Add test connection step to connection creation stepper and migrate to v2 test endpoint.
  • Add outbound resolved request.
1.4.1
  • Fix discard modal in intent mode
  • Improve connection create stepper
1.3.1
Feature updates
  • Split the code editor for query parameters and headers into key-value input-fields
  • Allow empty header and query parameter values
1.2.0
Feature updates
  • Add workflows template section to connection overview
  • Update to strato v3
1.1.0
  • Initial release
Dynatrace Hub
All (954)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Arize AX logo
Arize AX
AI Observability logo
AI Observability
Dynatrace Assist logo
Dynatrace Assist
SRE Agent logo
SRE Agent
Analyze and triage incidents.
Smartscape logo
Smartscape
Clouds logo
Clouds
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor (Live-Debugger) logo
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
