Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
OpenTelemetry CollectorOpenTelemetry Collector
Collect, enrich and export your traces, metrics and logs, supported by Dynatrace
Technology
Free trialDocumentation
Review all the OTel Collector telemetry sources we supportDynatrace distributed tracing provides a unified and comprehensive view of your OpenTelemetry collected trace data for all of your data sources. You can monitor and troubleshoot errors and performance issues in complex distributed software systems, at scale.Maintain centralized control over all of your Opentelemetry service health, performance, and resources.
  • Product information
Overview
OpenTelemetry Collector is a component for receiving, processing, and exporting telemetry data. It supports many open source observability formats, such as Jaeger, Zipkin, Prometheus, StatsD, Syslog, and FluentD, and converts them to the OpenTelemetry Protocol (OTLP), supported by Dynatrace.
The Collector has various processors to enrich, transform, and filter. You can, for example, add attributes to connect your application telemetry to Kubernetes objects, drop low-value data for cost control reasons, and use the Collector for sensitive data masking and filtering.
You can deploy the Collector next to your application. This helps offload your applications by handling batching, retries, and encryption in the Collector.
The Collector can also export the same data into multiple backends simultaneously (multi-casting) if, for example, the development teams have different backend requirements than the central observability team.
Use cases
The following OTel Collector use cases with example configurations are covered in the Dynatrace documentation
  • Jaeger
  • Zipkin
  • Prometheus
  • StatsD
  • Syslog
  • FluentD
  • Log files
  • Kubernetes enrichment
  • Kubernetes pod logs
  • Batching
  • gRPC to HTTP
  • Memory limitation
  • Multicasting
  • Sampling
  • Transforming and filtering
Get started
Dynatrace distribution of the OpenTelemetry Collector is a customized Collector build tailored for typical Dynatrace use cases. It ships with a selected and verified set of OpenTelemetry Collector components, and it’s fully supported by Dynatrace.
To deploy the Dynatrace Collector in your environment, follow the deployment documentation.
Take a look at the Collector use cases to learn more about its capabilities and access configuration examples and best practices.
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Copy to clipboard
Customer story Northwestern Mutual
ā€œWith [Dynatrace] OneAgent OpenTelemetry, tracing automatically gets ingested. This lets us diagnose problems that are not only in our application, but also with external integrations.ā€
Justin Scherer
Senior Software Engineer
See their story
Related to OpenTelemetry Collector
Fluentd logo
Fluentd
Stream log data to Dynatrace via Fluentd for analysis.
Prometheus in Kubernetes logo
Collect metrics from Prometheus exporters in Kubernetes for Dynatrace analytics
OpenTelemetry logo
OpenTelemetry
Ingest and analyze OTel traces & metrics, set health alerts & view in context
Prometheus logo
Prometheus
Unlock Prometheus power with intelligent analytics and automated insights.
Syslog (Dynatrace OTel Collector) logo
Stream Syslog data via Dynatrace OpenTelemetry Collector Distribution.
StatsD logo
StatsD
The easiest way to get your custom application metrics into Dynatrace.
Dynatrace Hub
All (884)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Deployment model
SaaS
  • SaaS
  • Managed
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Documents logo
Documents
Manage Dashboards, Notebooks and other documents in your Dynatrace environment
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Cursor IDE logo
Cursor IDE
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
