Dynatrace Hub
Extend the platform,
empower your team.
Popular searches:
Home hero bg
Microsoft SentinelMicrosoft Sentinel
Microsoft Sentinel
Microsoft Sentinel
Ingest Microsoft Sentinel security findings.
App
Free trialDocumentation
Security findings dashboard.Coverage dashboard.Workflows sample.
  • Product information
  • Release notes
Overview
Dynatrace integrates with Microsoft Sentinel to enable visibility, orchestration, and prioritization of security findings across tools and environments.
Capabilities:
  • Single pane of glass: Ingest security findings from Microsoft Sentinel into Dynatrace (powered by OpenPipeline™)
  • Unified analysis: Dynatrace transforms and maps the security findings to a unified format (powered by Dynatrace Semantic Dictionary)
  • Findings operationalization: Prioritize, visualize, and automate security findings with runtime context
  • Unveil blind spots: Discover and eliminate coverage gaps in your Software Development Lifecycle (SDLC)
Use cases
  • Overview: Visualize and report your current security posture and trends around security findings across environments with Dashboards.
  • Prioritization: Analyze and prioritize security findings across multiple tools and products uniformly with Notebooks.
  • Automation: Create notifications and tickets for critical security findings with Workflows.
  • Investigation: Use security findings as an additional dimension for threat hunting and incident forensics using Investigations.
Get started
To ingest Microsoft Sentinel security findings into Dynatrace, you need to set up a data export using the Dynatrace-provided configuration template that leverages Azure Event Hubs.
For instructions, go to Ingest Microsoft Sentinel security events.
Details
This integration app delivers several sample dashboards and workflows to help you
  • Visualize security findings (dashboard)
  • Summarize product security coverage (dashboard)
  • Send email notification for critical security findings (workflow)
Compatibility information
Microsoft Sentinel security alert schema
Dynatrace
DocumentationMore Information
By Dynatrace
Dynatrace support center
Subscribe to new releases
Copy to clipboard
Related to Microsoft Sentinel
Dashboards logo
Dashboards
OpenPipeline logo
OpenPipeline
Configure ingest, processing, and persistence of data sent to Grail.
Workflows logo
Workflows
Full version history
ReleaseDate
Updated dependencies
Connection filter now only filters for the connection's name.
Initial release of Microsoft Sentinel integration.
Dynatrace Hub
All (922)Log Management and AnalyticsKubernetesAI and LLM ObservabilityInfrastructure ObservabilitySoftware DeliveryApplication ObservabilityApplication SecurityBusiness ObservabilityDigital Experience
Filter
Type
Built and maintained by
Dynatrace Assist logo
Dynatrace Assist
Smartscape logo
Smartscape
Compliance Assistant logo
Experience Vitals logo
Experience Vitals
Optimize UX with core vitals, frontend error tracking, and end-to-end visibility.
Error Inspector logo
Error Inspector
Users & Sessions logo
Users & Sessions
Analyze your data
Notebooks logo
Notebooks
Dashboards logo
Dashboards
Investigations logo
Investigations
Smartscape logo
Smartscape
Logs logo
Logs
Problems logo
Problems
Automate your processes
Workflows logo
Workflows
Jira logo
Jira
Slack logo
Slack
Secure your cloud application
Security Posture Management
Threats & Exploits logo
Threats & Exploits
More resources
Cursor logo
Cursor
Documents logo
Documents
GitHub Copilot Coding Agent
GitHub Copilot Custom Agent
Metrics logo
Metrics
Streamline incident management with automated Pageruty workflows.
Cursor IDE logo
Cursor IDE
Boost developer productivity and get real-time, code-level insights into Cursor.
Kick-start your app creation
Go to Dynatrace Developer
Learn More
Learn more
